#31
Bob Moore writes:
Except in an airplane where the trim system moves the horizontal stabilizer instead of a trim tab. In that case, there is no feel feedback to the yoke. One must release the pressure and see if the airplane attitude remains where desired. Is that common? I note that there are slots in front of the stabilizers on a 737, implying that they pivot (for trim?). Is that in fact what they are doing? It's hard to see on the sim. -- Transpose mxsmanic and gmail to reach me by e-mail. |
#32
Bob,
Can you explain that a little further? I don't see any difference in feel feedback between a Cessna 182 (trim tab) and 185 (stab trim). Why should there be a difference? Karl "Curator" N185KG "Bob Moore" wrote in message . 121... Jay Beckman wrote Trimming is a "feel" thing. You trim to relieve control pressures and you can't see pressure, you can only feel it. Except in an airplane where the trim system moves the horizontal stabilizer instead of a trim tab. In that case, there is no feel feedback to the yoke. One must release the pressure and see if the airplane attitude remains where desired. Bob Moore |
#33
karl gruber wrote
Bob, Can you explain that a little further? I don't see any difference in feel feedback between a Cessna 182 (trim tab) and 185 (stab trim). Why should there be a difference? Karl, I have no experience with in the smaller a/c, but as a Boeing instructor (B-707, B-727), it took a good amount of time to teach a new jet pilot how to trim because of this effect. If from level flight, you want to raise the nose for a climb, you pull back and obviously feel the back pressure from the elevator being displaced relative to the stabilizer, at this point, trimming just changes the stabilizer position without putting the elevator in a new position relative to the stabilizer and releiving the pressure. Large trim changes (as in a go-around) consisted of a large number of trim/release cycles in order to find the exact amount required. Bob Moore |
#34
Mxsmanic wrote
Bob Moore writes: Except in an airplane where the trim system moves the horizontal stabilizer instead of a trim tab. In that case, there is no feel feedback to the yoke. One must release the pressure and see if the airplane attitude remains where desired. Is that common? In jetliners...Yes I note that there are slots in front of the stabilizers on a 737, implying that they pivot (for trim?). Is that in fact what they are doing? It's hard to see on the sim. Yes And, so far, no one has mentioned that in a jetliner, the main landing gear wheels are located far behind the aerodynamic center of rotation when the a/c is rotated for takeoff. If the a/c is trimmed for a low- force rotation, it will be out of trim for the initial climb. The initial trim setting for a jetliner must be computed for each takeoff based on the amount of load and its distribution. As I recall, the takeoff trim setting was for the V2+10 initial climb speed. Bob Moore ATP B-707 B-727 PanAm (retired) |
#35
"Skywise" wrote in message ... "Robert M. Gary" wrote in news:1157992218.361147.166330 @d34g2000cwd.googlegroups.com: Snipola Mike, I think trim is just academic is MSFS because there is no control feedback. The OP is probably setting the elevator with too much back pressure but doesn't know it because he doesn't have the feedback. Honestly, if you asked me what position the yoke is in on take off, I probably couldn't tell you. In real life we expect the yoke to go to its trim position, something that doesn't make sense in a simulator that does not have feedback controls. -Roebrt I have a force feedback stick and if I don't trim right for the phase of flight I'm in I have to provide excessive input to maintain flight attitude. As I adjust the trim the feedback moves the stick. Trim buttons are on my stick. I can press them while lightly holding the stick and feel the stick move. I know I am in trim when the stick is centered and I have a feather touch on the stick. When properly trimmed I can let go of the stick and maintain flight attitude for 10's of seconds. I can even conrol climb and descent with power adjustment without ever touching the elevator. Or sometimes I maintain altitude with single clicks of trim. Before I got the force feedback stick, trim didn't make sense since you couldn't feel it in the controls. The hundred bucks I spent on mine were well worth the enhanced simulation experience. Flight is much smoother and landings are greased much more often. Brian I don't understand what non-force feedback joysticks you guys are using but my MS stick is not force feedback and if I don't trim I have to move the stick to a non-centered position which requires constant force to keep it there. Are you guys using joysticks with no centering springs? |
#36
stabilizer instead of a trim tab. In that case, there is no feel feedback to the yoke. One must release the pressure and see if the airplane attitude remains where desired. This makes no sense to me. If the airplane attitude remains "where desired" (I presume that is the same as where you put it, using pressure) when you release the pressure, then the pressure isn't doing anything. How do you fly such an aircraft? Jose -- There are more ways to skin a cat than there are cats. for Email, make the obvious change in the address. |
#37
"Jose" wrote in message news:1MzNg.443 This makes no sense to me. If the airplane attitude remains "where desired" (I presume that is the same as where you put it, using pressure) when you release the pressure, then the pressure isn't doing anything. How do you fly such an aircraft? The way I look at it is that you have to use a different combination of sensory data than if you were flying a small aircraft with direct cable controls and elevator trim. In the 727, my recollection is that there is not a complete lack of feedback feeling; there is a little, but it is different from flying traditional trim tabs. On the 727 (and, I presume, on the 707) you have a movable stabilizer, an elevator, and elevator trim tabs. The elevator trim tabs are locked out of the trim system as long as the electric stab trim motors are functional. When locked out, they function as balance tabs. There is an elevator feel computer in the 727 whose main purpose is not to provide yoke force feedback, but it does give some little feeling to the yoke as a side effect. The bottom line, at least in my perception, is that with some experience in the aircraft you can become very adept at simultaneously positioning your attitude, and adjusting the trim so you don't have to keep positioning your attitude. Of course, as the craft accelerates or decelerates you have to repeat the process as configuration and speed change. As a practical matter, you are [almost] flying with the stab trim. |
#38
Bob Moore writes:
Yes So aircraft that pivot the entire stabilizer also keep the entire travel of the elevator available for flight, right? Seems like a pretty bit advantage. If you use trim tabs, you sacrifice at least part of the elevator travel when you trim to a non-neutral setting; but if the whole stabilizer moves for trim, the entire travel of the elevator is still there for you to use. I wonder why smaller planes don't do this. Also ... why does a plane like the Baron 58 have a stick pusher? I presume you can't use it for instruction flights that teach about stalls, since it refuses to adopt an attitude that will cause a stall. And, so far, no one has mentioned that in a jetliner, the main landing gear wheels are located far behind the aerodynamic center of rotation when the a/c is rotated for takeoff. If the a/c is trimmed for a low- force rotation, it will be out of trim for the initial climb. The initial trim setting for a jetliner must be computed for each takeoff based on the amount of load and its distribution. As I recall, the takeoff trim setting was for the V2+10 initial climb speed. How do all these calculations get done? It seems like there are a lot of things that have to be calculated for every flight. Do pilots sit with calculators and do it, or do they have some less time-consuming way to cook up the necessary numbers? -- Transpose mxsmanic and gmail to reach me by e-mail. |
#39
Mxsmanic wrote
So aircraft that pivot the entire stabilizer also keep the entire travel of the elevator available for flight, right? Ah-Ha....you broke the code. :-) I wonder why smaller planes don't do this. Generally speaking, they don't have as broad a cg range as a jetliner. How do all these calculations get done? It seems like there are a lot of things that have to be calculated for every flight. Do pilots sit with calculators and do it, or do they have some less time-consuming way to cook up the necessary numbers? Most airlines have a 'Load Control Center' with computers to do the work, but I have worked for small charter companies where the flight- crew (generally the copilot) works-up a Weight and Balance Form just prior to departing the gate since a copy must remain on file in operations. Bob Moore |
#40
"Mxsmanic" wrote in message ... Jay Beckman writes: That's because unless there is a specific marking (as there is for takeoff on the C172 both in RL and in FS9), there is no such thing as a specific way to set the trim for each situation. Trimming is a "feel" thing. You trim to relieve control pressures and you can't see pressure, you can only feel it. But if you have an unusual load aboard, it would seem that you wouldn't be able to feel it until you're already in the air. Unless you mean that you'd be able to extrapolate from previous experience with other loads. Define "Unusual Load." ??? If you are way over MGW or loaded well aft of the CG limit, you're already in a very dangerous place and no amount of trim will help. I'd just like to be able to rotate more smoothly. Don't pull so hard... Seriously, for most GA aircraft, when you reach Vr, you pull just enough to set an attitude and let the plane do the work. It sounds like the dynamics of flying "heavy iron" are a little different due to the placement of the mains versus the CG/CL but it can't be all THAT different. I had to modify the contact points on the 737 just because I was plowing the tail into the runway on take-off (and the standard model doesn't take any note of this, which meant I was cheating for a long time and didn't realize it). The B58 pitches upward even more quickly. Your simply being too aggressive and over rotating. I think if I can get good at putting the stick forward in just the right way as the nose rises I will be able to rotate smoothly, eventually, but I will try the trim stuff. Like I said, don't try to horse the plane off the ground...set a proper attitude at rotation and let the plane fly itself off the ground. Once you are airborne and accelerating, then you can worry about pitch and power to acheive a specific airspeed (Vx, Vy, etc...) Jay Beckman PP-ASEL Chandler, AZ |
| Thread Tools | |
| Display Modes | |
| The danger of assumption | Jay Honeck | Piloting | 26 | September 15th 05 01:37 PM |
| Thermal Rotation - Revisited.... | Mark Zivley | Soaring | 3 | July 3rd 04 03:11 PM |
| Fighter takeoff rotation | Boomer | Military Aviation | 10 | March 17th 04 07:43 PM |
| Cessna 150 Price Outlook | Charles Talleyrand | Owning | 80 | October 16th 03 03:18 PM |
| Airmen in Europe may go back to three-month rotation schedules | Otis Willie | Military Aviation | 0 | August 23rd 03 12:47 AM |
