GPS clearance puzzle
Old December 2nd 04, 09:13 PM
Andrew Gideon
Roy Smith wrote:
Sounds like a good plan, thanks!
Yes, thanks! I was going over the 430 manual last night trying to find
something of this sort, but I missed it.
Those flying behind the navcoms in newer Cessnas have a similar/easier
option. The nav side can be set to display the to/from radial instead of
the standby frequency. I liked the awareness that provided, given that I
could see "how close I was" to some chosen radial even before the needle
had "come alive".
- Andrew
Old December 2nd 04, 10:26 PM
Roy Smith
had "come alive".
You can do that on the CNX-80 too. In NAV mode, hit the MON soft-key
to put it in monitor mode. It then shows you the from radial of the
VOR in the standby slot.
Old December 4th 04, 08:07 PM
Greg Esres
It will if you use distance, e.g., CMK275023, the last three digits
being the distance from Carmel on the 275 until you intercept the
039.
I know, but the radial to radial is more elegant.
Old December 4th 04, 08:09 PM
Greg Esres
input would be CMK.CMK275..SAX039.SAX
Cool. Do you disagree with Newps in that the DME would NOT appear on
the flight progress strip (unless it was input) ?
Old December 8th 04, 06:43 AM
Steven P. McNicoll
"Greg Esres" wrote in message
DME would appear on the strip only if it was entered.
Old December 9th 04, 01:22 AM
Greg Esres
Thank you.
No SID in clearance, fly it anyway? Roy Smith Instrument Flight Rules 195 November 28th 05 11:06 PM
Clearance: Direct to airport with /U Judah Instrument Flight Rules 8 February 27th 04 07:02 PM
Q about lost comms on weird clearance Paul Tomblin Instrument Flight Rules 34 February 2nd 04 10:11 PM
Picking up a Clearance Airborne Brad Z Instrument Flight Rules 30 August 29th 03 02:31 AM
Big John Bites Dicks (Security Clearance) Badwater Bill Home Built 27 August 21st 03 01:40 AM
