Brazil 737-Embraer Crash
Old October 5th 06, 05:41 PM posted to rec.aviation.piloting
Larry Dighera
Default Brazil 737-Embraer Crash
On Thu, 05 Oct 2006 09:22:08 -0500, James Robinson
wrote in :
TCAS only works with both transponders working.
Is the operating TCAS aboard the aircraft that is receiving a
transponder signal from another aircraft in its vicinity totally
incapable of outputting ANY useful information?
Old October 5th 06, 06:23 PM posted to rec.aviation.piloting
Frank Ch. Eigler
James Robinson writes:
TCAS only works with both transponders working. One was not working.
Are you sure? Even a TCAS-II system installed on a machine with an
inoperative transponder should still provide traffic alerting, no?
- FChE
Old October 5th 06, 06:26 PM posted to rec.aviation.piloting
Larry Dighera
(Let me try to make my question a little clearer.)
wrote in :
incapable of outputting ANY useful information when it's transponder
is not operating?
Old October 5th 06, 07:02 PM posted to rec.aviation.piloting
karl gruber[_1_]
YOU........don't know that!
"James Robinson" wrote in message
Kevin Clarke wrote:
Then of course I am really scratching my head about 2 TCAS "failures" or
at least TCAS being ignored. Sad.
Old October 5th 06, 07:28 PM posted to rec.aviation.piloting
news.charter.net
http://www.nytimes.com/2006/10/03/bu...ewanted=2&_r=1
"karl gruber" wrote in message
Old October 5th 06, 07:37 PM posted to rec.aviation.piloting
James Robinson
"karl gruber" wrote:
"James Robinson" wrote:
"failures" or at least TCAS being ignored. Sad.
Quite right. I don't personally know whether the transponder was working
or not.
I should have said that it was reported to have ceased transmitting before
the collision, and started transmitting again after the collision. This
was part of a statement from a Brazilian Air Force representative in a news
conference. The BAF is heading the investigation into the accident. It was
one of the reasons given for holding the passports of the US pilots.
Old October 5th 06, 07:39 PM posted to rec.aviation.piloting
Neil Gould
Recently, Larry Dighera posted:
wrote in :
is not operating?
As I understand it, it is the transponder signal of other aircraft that
TCAS reports. If other aircraft in the area either don't have a
transponder or it is inoperative, there is nothing for the TCAS to lock
onto, ergo, no useful information about traffic position.
Neil
Old October 5th 06, 08:00 PM posted to rec.aviation.piloting
Larry Dighera
On Thu, 5 Oct 2006 10:28:46 -0700, "news.charter.net"
wrote in
Thanks for the link to the New York Times story (even if I did have to
use bugmenot.com to access it). Unfortunately it doesn't mention the
TCAS system which was the subject of the article to which you were
following up. But it did contain this nugget:
A Brazilian military inspector standing by surprised me by his
willingness to talk, although the conversation was limited by his
weak English and my nonexistent Portuguese.
He was speculating on what happened, but this is what he said:
Both planes were, inexplicably, at the same altitude in the same
space in the sky. The southeast-bound 737 pilots spotted our
Legacy 600, which was flying northwest to Manaus, and made a
frantic evasive bank. The 737 wing, swooping into the space
between our wing and the high tail, clipped us twice, and the
bigger plane then went into its death spiral.
It sounded like an impossible situation, the inspector
acknowledged. “But I think this happened,” he said. Though no one
can say for certain yet how the accident occurred, three other
Brazilian officers told me they had been informed that both planes
were at the same altitude.
Old October 5th 06, 08:10 PM posted to rec.aviation.piloting
Larry Dighera
On Thu, 05 Oct 2006 12:32:31 -0500, James Robinson
wrote in :
Not as I understand it. Here are some quotes from an ARINC description
of TCAS-II:
"A Mode S transponder is required to be
installed and operational for TCAS II to be
operational. If the Mode S transponder fails,
the TCAS Performance Monitor will detect
this failure and automatically place TCAS
into Standby."
The Mode S requirement is suspect, as I have had jet aircraft indicate
that they could see me on their TCAS units while the transponder
installed in the aircraft I was operating was not even squawking Mode
C, but it was squawking.
"TCAS does not alter or diminish the pilot’s
basic authority and responsibility to ensure
safe flight. Because TCAS does not respond
to aircraft that are not transponder-equipped
or aircraft with a transponder failure, TCAS
alone does not ensure safe separation in
every case."
That statement does not support your assertion, that both aircraft
must have transponders operating for TCAS to provide avoidance
information.
I would guess, that if the transponder in a TCAS equipped aircraft
were turned off, the TCAS unit in that aircraft would still provide
information about other transponder equipped (and squawking) aircraft
in the area, but that wouldn't do those aircraft with operational
transponders any good unless the pilot receiving the TCAS information
took evasive action.
jet vs jet crash in brazil - 155 likely dead [email protected] Soaring 4 October 11th 06 09:17 PM
VQ-1's P4M-1Q crash off China - 1956 Mike Naval Aviation 0 May 7th 06 12:13 AM
Pilot claims no blame in July crash Mortimer Schnerd, RN Piloting 48 March 15th 06 10:00 PM
Air Force One Had to Intercept Some Inadvertent Flyers / How? Rick Umali Piloting 29 February 15th 06 05:40 AM
Yet another A36 crash H.P. Piloting 10 April 23rd 05 06:58 PM
