more bitching about the IFR written - CDI left/right versus north/south/etc
Old January 6th 05, 09:43 PM
C J Campbell
m...
C J Campbell wrote:
"G. Sylvester" wrote in message
A month or two ago there was a thread about CDI indicating north/south
vs. left/right in particular on front course and back course LOC.
I'm studying for the IFR written and not in a single place
does the FAA use north/south.
What in heck are you referring to? The CDI refers only to right or left
of
the course indicated by the OBS and the TO/FROM window. You have to know
how
to use the CDI when it appears to be reverse sensing.
The OBS has no meaning to a CDI when using a localizer.
It's left or right of the localizer beam where "left and right" is defined
as looking inward on the front course. It's only when the pilot's left
and
right is reversed (as they are looking inward on the back course) that
things
are "reversed."
That is all true.
Old January 6th 05, 09:51 PM
C J Campbell
On Thu, 06 Jan 2005 16:38:45 GMT, "Hilton"
I'll bite. What is a p-t-d entry? Parallel, Teardrop, Direct??? So
it's
now one entry? Or are you saying you can go fly holds and enter any
which
way you want? If so, you'll end up doing one of these (or some version
thereof) anyway.
I'm saying exactly that. The only requirement is to stay within
holding airspace.
The FAA finally wised up a few years back, and removed the requirement
from the PTS. Nevertheless, it remains a part of the written
It also remains a requirement on most FAA approved part 141 syllabi, so the
entries have to be taught to competency whether they are part of the PTS or
not. The standard entries do guarantee that you will remain in the protected
holding airspace and are recommended in AIM, the FAA Instrument Flying
Handbook, and the FAA Instrument Procedures Handbook, all of which is where
the FAA draws its test questions from. The operations manuals for FAA
approved commercial IFR operators also often specify what holding pattern
entries the operator's pilots will use. Since these are the standard methods
and many students will be required by their employers to use them, there is
little point in teaching anything else.
If you want to do something else, of course, you are perfectly free to do
so.
Old January 6th 05, 10:16 PM
Roy Smith
C J Campbell wrote:
The operations manuals for FAA approved commercial IFR operators
also often specify what holding pattern entries the operator's
pilots will use. Since these are the standard methods and many
I don't see anything wrong with teaching or learning them, but I can
also see how it's much more important for a commercial pilot flying
high performance aircraft than for a spam can driver.
If you're holding at 210 kts (and maybe limited to less than standard
rate turns by your FD), you're going to eat up a lot of sky. The
correct entry may be the only thing keeping you from blowing out of
the protected area. This is much less likely to be an issue at 90
kts.
Old January 6th 05, 10:22 PM
On Thu, 06 Jan 2005 15:40:45 -0500, Andrew Gideon
And I've only been doing this for a few years
Precisely.
Old January 6th 05, 10:24 PM
On Thu, 6 Jan 2005 12:43:20 -0800, "C J Campbell"
om...
of
how
and
things
are "reversed."
That is all true.
Almost.
The OBS has much meaning to a CDI when using a localizer course, if
you just know how to interpret said meaning.
Old January 6th 05, 11:28 PM
C J Campbell
defined
left
and
things
are "reversed."
That is all true.
Almost.
It has no meaning to the CDI, which after all is an inanimate object. If you
are properly trained it should have some meaning for you.
  #30
Old January 7th 05, 01:07 AM
C J Campbell
you
When I use words, they mean exactly what I mean for them to mean,
nothing more and nothing less.
Very well, what does the OBS mean to the CDI on a localizer?
IR written Primary/Secondary instrument questions Jeremy Instrument Flight Rules 35 February 21st 04 12:02 AM
Another Instrument written question.... [email protected] Instrument Flight Rules 14 October 29th 03 06:47 PM
IFR written passed Tune2828 Instrument Flight Rules 3 August 12th 03 11:01 PM
Thinking about getting my IFR rating - Written test programs???? Grey Stone Instrument Flight Rules 6 July 22nd 03 02:08 AM
