Go Back   Home » AviationBanter forum » rec.aviation newsgroups » General Aviation
ARC RT385A CDI Adjustment
Old October 16th 06, 10:07 AM
facpi facpi is offline
Junior Member
First recorded activity by AviationBanter: Sep 2006
Default ARC RT385A CDI Adjustment
Anyone knows how can I adjust the CDI needle of VOR with an old ARC's RT385A? Nobody has a manual of RT385A around me and I could not find the information on the net.
Thank you,
Old October 16th 06, 01:01 PM posted to rec.aviation.misc
Bill Zaleski
On Mon, 16 Oct 2006 09:07:19 +0100, facpi
Thank you,
The VOR and localizer adjustments are internal inside the indicator.
The nav/com itself does not process the signal. The procedure is
contained in the IN-386 indicator manual.
Old October 20th 06, 12:52 AM
Rich Anderson Rich Anderson is offline
Junior Member
First recorded activity by AviationBanter: Aug 2006
Quote:
Thank you,
If you should need it, I have a manual for the RT385A. Contact me at The Gyro House, www.tghaviation.com. It is an old manual which we never use anymore and I would be glad to send you a copy should you need it.
Rich Anderson
SZD-55 Wheel Brake Adjustment WDM Soaring 2 January 20th 11 10:25 AM
Using an old RT385A as a base station. Avery Wagg Home Built 2 June 22nd 06 02:08 AM
Adjustment driver for King VOR head Robert M. Gary Piloting 12 August 24th 05 07:34 AM
KI-209 VOR/LOC/GS Indicator adjustment kontiki Owning 13 April 26th 05 12:35 AM
Adjustment of Altimeter Ron Home Built 5 April 5th 04 04:12 AM
