Common instruments on small aircraft
Old October 22nd 06, 10:16 AM posted to rec.aviation.piloting,rec.aviation.student
Mxsmanic
Default Common instruments on small aircraft
Judah writes:
I could be wrong, but I believe the Cruising Speed of a Baron is about 175 -
185Kts, or about 200-215MPH.
I get a ground speed of about 195-200 kts in many cases, which would
be as much as 230 mph.
The speed limit on most US Highways is 65-75MPH.
In no-wind conditions, if both vehicles are travelling in a straight line
(rare for IFR aircraft, but even rarer for vehicles on the ground) the Baron
is faster by nearly a factor of 3. Perhaps you are not flying the Baron
properly to achieve maximum performance.
It's not a race, and there are many parts of the flight that are not
performed at maximum speeds. The route is usually close to being a
straight line, but not exactly.
I should be able to take a commercial flight from KPHX to KSAN and be
there in about 40 minutes. In fact, it takes several hours.
I want to build the most EVIL plane EVER !!! Eliot Coweye Home Built 237 February 13th 06 04:55 AM
Washington DC airspace closing for good? tony roberts Piloting 153 August 11th 05 01:56 AM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 May 1st 04 08:29 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 2 February 3rd 04 12:41 AM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 1 January 2nd 04 10:02 PM
