Regs regarding "VFR flight following?" (also: "need to vent")
Old October 27th 06, 07:02 PM posted to rec.aviation.owning
Newps
Default Regs regarding "VFR flight following?" (also: "need to vent")
A Lieberma wrote:
My question is where were you in relationship to the airport? Were you
under an approach or departure path? Where you near an initial approach
fix for IFR traffic?
Irrelavant. He was below the class C which puts him well away from
traffic at those points.
Old October 27th 06, 08:23 PM posted to rec.aviation.owning
Dave Butler wrote:
: If you really meant to ask "where are the regs?" I don't think you'll
: find anything specifically about flight following in the regulations.
: Look for "VFR advisories" in the AIM. That's the official name for what
: we informally call flight-following.
: I think Steven said it best (paraphrasing): don't ask, just tell them
: you're terminating radar services.
: Dave
Pretty much what I was doing (I thought). I think that that point he realized
that I was *trying* to be a nice guy by talking to him and acknowledging altitude,
etc, but yet I wasn't willing to accept vectors.
-Cory
* Cory Papenfuss, Ph.D., PPSEL-IA *
* Electrical Engineering *
Old October 27th 06, 08:24 PM posted to rec.aviation.owning
: I'm not actually sure that teh controllers know the specific boundaries
: of the airspace. When you get vectored around its usually because they
: have arrivals/departures, not because of the airspace.
I sure hope that's not the case. Normal (IFR) arrivals/departures should stay
within the boundaries of the controlled airspace... that's why they're there.
-Cory
Old October 27th 06, 08:37 PM posted to rec.aviation.owning
Steven P. McNicoll[_1_]
realized
altitude,
Class C services include separation between IFR and VFR aircraft, they are
provided to all aircraft within Class C airspace, and to all participating
aircraft within the outer area. When you contacted approach you became a
participating aircraft. If vectors are deemed necessary to provide
separation you will receive vectors. If you're not willing to accept them
don't be a participating aircraft.
Old October 27th 06, 08:47 PM posted to rec.aviation.owning
: Class C services include separation between IFR and VFR aircraft, they are
: provided to all aircraft within Class C airspace, and to all participating
: aircraft within the outer area. When you contacted approach you became a
: participating aircraft. If vectors are deemed necessary to provide
: separation you will receive vectors. If you're not willing to accept them
: don't be a participating aircraft.
Ah... there's the rub though. I was not, nor did I plan to actually enter the
Class C. I am certainly not advocating disregarding ATC requests when in the
controlled airspace. I'm arguing against the seemingly mandatory re-routing of VFR
traffic completely around the lateral boundaries of a Class C should the VFR traffic
want to cooperate with ATC by communicating with them.
I suspect you have it pretty much summarized though. Sad that the only
"solution" to this is just squawk 1200 and buzz through fat, dumb, and happy.
-Cory
Old October 27th 06, 08:55 PM posted to rec.aviation.owning
are
participating
a
them
actually enter the
re-routing of VFR
VFR traffic
only
happy.
I don't think you understand. Class C services are provided to all
aircraft within the Class C airspace itself, and to all participating
aircraft in the outer area associated with it. The outer area is not marked
on the chart, it is normally the area within a twenty mile radius of the
Class C primary airport and extends from the lower limits of radar/radio
coverage up to the ceiling of the approach control's delegated airspace
excluding the Class C charted area.
UAV's and TFR's along the Mexico boarder John Doe Piloting 145 March 31st 06 07:58 PM
Air Force One Had to Intercept Some Inadvertent Flyers / How? Rick Umali Piloting 29 February 15th 06 05:40 AM
terminology questions: turtledeck? cantilever wing? Ric Home Built 2 September 13th 05 10:39 PM
Real World Specs for FS 2004 Paul H. Simulators 16 August 18th 03 10:25 AM
