#31
On Thu, 2 Nov 2006 22:02:09 +1300, Dave Doe wrote in
: fly at 65kts, and you get the longest time in the air That is incorrect. Flying at best glide speed will give you the maximum (no wind) distance over the ground just as Vy (velocity along the Y axis: best rate of climb) does. Flying at minimum sink speed will give you the most time before landing just as Vx (velocity along the X axis: best angle of climb speed) provides the maximum height in the shortest time (regardless of wind). |
#32
"Mxsmanic" wrote in message
... It amazes me that students are being advised here to accept misinformation and inaccuracy just for a piece of paper. They're not; your characterization is misinformed and inaccurate. The advice was to make a substantial effort to persuade the instructor, and (if unsuccessful) to show the instructor that yes, you are able to fly the procedure as he wishes (which is not hazardous in a practice situation, and does not require conceding error). --Gary |
#33
Mxsmanic wrote in
: That is far less likely than a student pilot being killed by his unquestioning acceptance of misinformation from a flight instructor whom he has been told not to question. It amazes me that students are being advised here to accept misinformation and inaccuracy just for a piece of paper. However, it does explain the misdeeds of some pilots. And it does resemble the credentialism that afflicts society in general--a belief that the paper is more important than what it putatively represents (because restrictions address the paper, not the qualities it is supposed to document). Are you reading the same thread as everyone else here? Where did you come up with this crap? |
#34
"d&tm" wrote in message
... You could have a similar argument about weight as the best glide speed will be significantly lower if you are flying solo and especially if the reason for engine failure was no fuel! But are you going to get out the calculator and calculate the weight corrected best glide speed when the noise stops? Should an instructor tell you that flying a Warrior solo would have a best glide speed closer to 65 kts than the published 73kts? Yes, students should definitely be taught which V-speeds need to be weight-adjusted and which do not (and why). If you're 30% below gross weight, the required 15% speed adjustment is nonnegligible. (Adjust Vs, Vs1, Vl/d, Vx, Vy, Va. Do not adjust Vne, Vno, Vfe, Vle. See http://www.av8n.com/how/htm/aoa.html#sec-ias-aoa for a detailed explanation.) But no, you don't do the calculation when an emergency arises. You should do it in advance, as part of your W&B calculation. If you precompute the adjustment factor, you can easily apply it in real time. --Gary |
#35
Back to the drawing board Dunc!
Karl "Curator" N185KG "Dave Doe" wrote in message z... In article . com, says... Ok, my instructor did a simulated engine failure in the pattern; winds were around 20kts in the air and 13kts on the ground. Did everything perfectly; however after we took off again, he told me to maintain 65 kts next time, and I totally disagreed. The manual says 65 kts for best glide speed; however that is in calm air. As a glider person, I know adding about 1/2 the headwind component will give the greatest distance. Yes, the greatest *distance* - if you *need* it. Otherwise, I think he's right - fly at 65kts, and you get the longest time in the air (something you're short of usually, when the fan dies). But yep, you're right, *if* you need to get the distance to make the field. -- Duncan |
#36
To prove the point to your instructor.
Ask him/her to consider a headwind of 65kts. What are the chances of reaching the field with a GS=0 ?? What are the chances if GS0 ?? "Nik" wrote in message ups.com... Ok, my instructor did a simulated engine failure in the pattern; winds were around 20kts in the air and 13kts on the ground. Did everything perfectly; however after we took off again, he told me to maintain 65 kts next time, and I totally disagreed. The manual says 65 kts for best glide speed; however that is in calm air. As a glider person, I know adding about 1/2 the headwind component will give the greatest distance. After the flight I pulled up the Glider Flying handbook online and it says: "...it is apparent that flying a faster airspeed as the headwind increases will result in the greatest distance over the ground. If this is done for the polar curves from many gliders, a general rule of thumb is found, namely, add half the headwind component to the best L/D for the maximum distance." But even after telling him that he said that doesn't apply to power planes, also saying that manuals never give best glide, and there has to be a reason for that. Do you guys have any ideas on how I can really convince him? Any good sources? Thanks! -Nik |
#37
Ask him if 65kts is the best glide speed to get to the airport into a
65kt head wind. I myself would use at least 90 as I am sure you would as well. Brian CFIIG/ASEL Nik wrote: Ok, my instructor did a simulated engine failure in the pattern; winds were around 20kts in the air and 13kts on the ground. Did everything perfectly; however after we took off again, he told me to maintain 65 kts next time, and I totally disagreed. The manual says 65 kts for best glide speed; however that is in calm air. As a glider person, I know adding about 1/2 the headwind component will give the greatest distance. After the flight I pulled up the Glider Flying handbook online and it says: "...it is apparent that flying a faster airspeed as the headwind increases will result in the greatest distance over the ground. If this is done for the polar curves from many gliders, a general rule of thumb is found, namely, add half the headwind component to the best L/D for the maximum distance." But even after telling him that he said that doesn't apply to power planes, also saying that manuals never give best glide, and there has to be a reason for that. Do you guys have any ideas on how I can really convince him? Any good sources? Thanks! -Nik |
#38
"Gary Drescher" wrote in message snip Yes, students should definitely be taught which V-speeds need to be weight-adjusted and which do not (and why). If you're 30% below gross weight, the required 15% speed adjustment is nonnegligible. (Adjust Vs, Vs1, Vl/d, Vx, Vy, Va. Do not adjust Vne, Vno, Vfe, Vle. See http://www.av8n.com/how/htm/aoa.html#sec-ias-aoa for a detailed explanation.) But no, you don't do the calculation when an emergency arises. You should do it in advance, as part of your W&B calculation. If you precompute the adjustment factor, you can easily apply it in real time. Gary , I dont disagree with you . I do actually have a best glide speed wt adjustment in my Excel wt and balance spreadhseet but as a student we were not taught to adjust these speeds for weight, although we understood they change with wt. and we certainly knew the non -negotiable ones like Vne and Vfe etc. Again I figure their reason was to keep things simple, better to overstimate than underestimate stall speeds. . although in hindsight it had a lot to do with my early landing problems in the Warrior where it just seemed to want to float for ever. I did actually post about this on this group some years ago, because I thought the approach speeds I was being taught were too high relative to the stall speed for the wt I was carrying The 12 hour formal theoretical training I recieved for PPL was typical of what seems to be happening with science education in our schools and Australian society in general at the moment... a dumbing down to take maths out of everything. But being a scientist myself I believe in the Lord Kelvin theory. " if you cant explain what you know with numbers, your knowledge is of a meagre and unsatisfactory kind" .. or something like that. I have probably gone the other way now having set up spreadsheets to do my Navigational wind triangle calculations ,great circle distance calculations, calculating wt adusted stall speeds , wt and balance, turn physics ( radius and time) , load and stall speed increase in turns , and my latest additon is my energy balance to answer the question of how much ht I can actually gain by turning speed to height. ( not much in a Warrior - 250 ft from cruise to best glide speed after engine failure . but I havent allowed for drag so it will be a bit less.). You know that Count character in Sesame Street.. he's my hero. terry |
#39
Judah wrote: Mxsmanic wrote in : It amazes me that students are being advised here to accept misinformation and inaccuracy just for a piece of paper. [...] Are you reading the same thread as everyone else here? Where did you come up with this crap? Eh? What he said is _exactly_ what the thread was about. I.e. letting the instructor's misinformation slide just long enough to get the license more easily, and then perhaps arguing the point later. Is it the right thing to do? No. Does everyone have to do it? Probably, unless you had one amazingly knowledgable CFI. I suspect most people here have some story about a fact they knew was true, but their instructor didn't believe it right away. Whether you should change instructors or not depends on how dangerous or obvious the error is, and whether he's willing to accept evidence to the contrary. Inexperienced CFIs aren't going to know everything, but they should know they don't. Kev |
#40
| Thread Tools | |
| Display Modes | |
| Washington DC airspace closing for good? | tony roberts | Piloting | 153 | August 11th 05 01:56 AM |
| Air Force seeks to increase military participation in 8th annual . | Otis Willie | Military Aviation | 0 | June 18th 04 11:53 PM |
