Gentle take-offs at high speed
Old November 11th 06, 10:12 PM posted to rec.aviation.student,rec.aviation.piloting
Mxsmanic
Default Gentle take-offs at high speed
"Jim Macklin" writes:
In the real world, there is no way in hell to keep a Baron
on the ground at 100 knots.
I'm sure that pushing the stick forward works well. If there were no
way to keep a Baron on the ground at 100 kts, then no Baron could ever
crash at a speed of more than 100 kts, since its intense desire to fly
would keep it from contacting the ground.
  #32
Old November 11th 06, 10:31 PM posted to rec.aviation.student,rec.aviation.piloting
Mxsmanic
TxSrv writes:
Enjoy wasting your time. MSFS doesn't know ground effect.
Recent versions do simulate ground effect, as I recall. I'm not sure
of the details. I know that the aircraft I fly will hover for an
unusually long time just above the ground, which sounds an awful lot
like ground effect.
  #33
Old November 11th 06, 11:09 PM posted to rec.aviation.student,rec.aviation.piloting
Jim Macklin
At light weight, the 90 thru E90 King Airs do pretty well on
take-off with an engine loss, but at gross they are
definetly under-powered. The F90 has 750 hp and is still a
handful on one engine. I really like the 300-350 King Air,
it will perform just like advertised. An engine failure
before V1 and you stop on the runway. Past V1 you have
performance to continue into the air and to a safe landing.
Having 1050 hp gearbox and a 1700 hp gas generator really
helps. At a light weight, climb rate on two engines is over
4,000 fpm, can't say how much, that is because the rate is
pegged. Didn't have a stopwatch running.
Took off solo one day at Wichita for a short trip south, had
only 2 hours fuel. Departed 1 R at Wichita (1330 MSL) and
did a chandelle on take-off to the right. Rolled out at
9,000 feet MSL still over the airport.
It was very gentle, except I did have to go back to the
baggage compartment after landing in Oklahoma to get my
chart bag, the steep deck angle made it fall down the aisle.
"karl gruber" wrote in message
| "Jim Macklin" wrote
in message
| I sure hope you're talking about a "game" or PC sim
Baron.
Baron
| on the ground at 100 knots. They want to fly. Fifty
years
| ago, the manual said you lifted off in 600 feet at 60
mph.
| That was well below Vmc and if an engine died, so did
you.
| I remember the day Beech sent out a new revision for our
King Air A90. All
| it did was remove the short field takeoff section. Just as
you suggest for
| the Baron.
| Karl
| "Curator" N185KG
  #34
Old November 12th 06, 12:28 AM posted to rec.aviation.student,rec.aviation.piloting
karl gruber[_1_]
I've actually had two PT6A-41s quit on me, both at cruise in a straight
KA200.
Both were non-events, but it certainly has changed the way I think of the
Pilatus PC-12, and what's that other single, TBM 700?
The failure rate for PT6s is unknown since the vast majority are on King
Airs and they simply fly home on one and get the fuel control unit
replaced...............which is the cause of 95% of the failures. So much so
that the singles have manual fuel control units and great big emergency pull
handles.
The other reason the King Air is so good on one engine is the nice big high
lift wing. It's not fast but is sure hauls the load, although I've seen our
350 at 305 Kts @ FL310
Karl
"Curator"
"Jim Macklin" wrote in message
news
| "Jim Macklin" wrote
in message
Baron.
Baron
years
mph.
you.
King Air A90. All
you suggest for
| the Baron.
| Karl
| "Curator" N185KG
  #35
Old November 12th 06, 12:36 AM posted to rec.aviation.student,rec.aviation.piloting
Jim Macklin
So far, the only engine failure I've had on a King Air was
caused by a broken nacelle tank vent on an F90, discounting
a flameout due to no fuel on board even though the gauges
showed almost two hours fuel. But manual fuel control does
make sense and is a requirement on the singles, I think.
I do like the big tail surfaces, great control and VG range.
in a straight
| KA200.
I think of the
control unit
big emergency pull
| handles.
the nice big high
| Karl
| "Curator"
| "Jim Macklin" wrote
in message
| news | At light weight, the 90 thru E90 King Airs do pretty
well on
still a
Air,
landing.
really
over
is
had
and
aisle.
message
| | "Jim Macklin"
wrote
| in message
| Baron.
| Baron
Fifty
| years
60
| mph.
did
| you.
our
| King Air A90. All
Just as
| you suggest for
| | the Baron.
| | Karl
| | "Curator" N185KG
  #36
Old November 12th 06, 02:36 AM posted to rec.aviation.student,rec.aviation.piloting
TxSrv
like ground effect.
Airplanes don't hover, and "I recall" isn't proof of anything.
If ground effect is modeled, you can prove with flight testing
and reporting back the numbers. How would you know you're in
ground effect in MSFS? Why would the programmers waste valuable
CPU time doing something 99% of simmers don't understand?
F--
  #37
Old November 12th 06, 03:31 AM posted to rec.aviation.student,rec.aviation.piloting
karl gruber[_1_]
You believed the fuel gauges on a King Air? Ha Ha
Ha!...........What-a-Gotcha. They are so totally unreliable. Your engine
failure was weird, and written up in the airframe logs for the fix.
Best,
Karl Curator
in a straight
| KA200.
I think of the
control unit
big emergency pull
| handles.
the nice big high
| Karl
| "Curator"
| "Jim Macklin" wrote
in message
well on
still a
Air,
landing.
really
over
is
had
and
aisle.
message
| | "Jim Macklin"
wrote
| in message
| Baron.
| Baron
Fifty
| years
60
| mph.
did
| you.
our
| King Air A90. All
Just as
| you suggest for
| | the Baron.
| | Karl
| | "Curator" N185KG
  #38
Old November 12th 06, 11:06 AM posted to rec.aviation.student,rec.aviation.piloting
Mxsmanic
TxSrv writes:
If you don't know the numbers, and you don't know how to determine
that you're in ground effect in the simulator, then you cannot know
whether it simulates ground effect or not, unless you've read the
code.
Why would the programmers waste valuable CPU time doing
Most of the simulation aspect of the product covers areas with which
many of the product's users are unfamiliar. That is the nature of
simulation. You don't leave something out just because a user might
not be aware of it--on the contrary, the idea is to simulate it,
anyway, so that he can discover it.
  #39
Old November 12th 06, 12:32 PM posted to rec.aviation.student,rec.aviation.piloting
mike regish
I always thought I was the only one who sweated takeoffs more than landings.
I consider a perfect takeoff (at least from smooth pavement) one in which
you don't know you've left the ground until you look down.
mike
"A Lieberma" wrote in message
. 18...
"P S" wrote in news:1163209397.165388.182990
@k70g2000cwa.googlegroups.com:
Most of the posters have been flying for too long and they forgot
how takeoff feels for a non-pilot or a new pilot.
Not this pilot. I call it magic EVERYTIME the wheels leave terra firma.
Especially when the air is calmer then calm and the plane pretty much does
what it was designed to do so effortlessy as the ground falls away from
me....
Allen
  #40
Old November 12th 06, 12:38 PM posted to rec.aviation.student,rec.aviation.piloting
mike regish
Hover? What kind of wind? What kind of craft? Alien?
mike
"Mxsmanic" wrote in message
like ground effect.
I want to build the most EVIL plane EVER !!! Eliot Coweye Home Built 237 February 13th 06 04:55 AM
Crosswind Landings... But airspeed? Jmarc99 Soaring 21 October 4th 05 08:54 PM
Space Elevator Big John Home Built 111 July 21st 04 05:31 PM
IVO pireps wanted.. high performance/high speed... Dave S Home Built 8 June 2nd 04 05:12 PM
High Speed Passes & the FAA (long) JJ Sinclair Soaring 17 October 15th 03 01:16 AM
