Gentle take-offs at high speed
Old November 12th 06, 02:36 AM posted to rec.aviation.student,rec.aviation.piloting
TxSrv
Default Gentle take-offs at high speed
Mxsmanic wrote:
Recent versions do simulate ground effect, as I recall. I'm not sure
of the details. I know that the aircraft I fly will hover for an
unusually long time just above the ground, which sounds an awful lot
like ground effect.
Airplanes don't hover, and "I recall" isn't proof of anything.
If ground effect is modeled, you can prove with flight testing
and reporting back the numbers. How would you know you're in
ground effect in MSFS? Why would the programmers waste valuable
CPU time doing something 99% of simmers don't understand?
F--
I want to build the most EVIL plane EVER !!! Eliot Coweye Home Built 237 February 13th 06 04:55 AM
Crosswind Landings... But airspeed? Jmarc99 Soaring 21 October 4th 05 08:54 PM
Space Elevator Big John Home Built 111 July 21st 04 05:31 PM
IVO pireps wanted.. high performance/high speed... Dave S Home Built 8 June 2nd 04 05:12 PM
High Speed Passes & the FAA (long) JJ Sinclair Soaring 17 October 15th 03 01:16 AM
