GPS altitude again is close to actual
Old November 18th 06, 10:18 PM posted to rec.aviation.piloting
Mxsmanic
Default GPS altitude again is close to actual
Ron Lee writes:
I suspect that Jon is far smarter on WAAS that either one of us Mx.
I don't have to be smart: I look things up.
  #83
Mxsmanic
Nomen Nescio writes:
Actually, at least for the most part, they are INTERpolations.
There's a big difference.
Not in terms of accuracy. Either way, they are _estimates_.
  #84
Old November 18th 06, 10:19 PM posted to rec.aviation.piloting
Mxsmanic
RomeoMike writes:
Go to http://www.garmin.com/pressroom/aviation/110906.html and read "enabled."
The new ones are enabled, the old ones upgradeable.
The new ones have a different model number, e.g., 530W instead of 530.
  #85
Mxsmanic
RomeoMike writes:
Look harder. Old ones are upgradeable, new ones are enabled, which means
enabled, not "equipped with."
The ones I referenced are upgradeable.
  #86
Old November 19th 06, 12:05 AM posted to rec.aviation.piloting
Mxsmanic wrote:
Ron Lee writes:
That explains a lot.
  #88
Old November 19th 06, 04:15 AM posted to rec.aviation.piloting
Newps
Mxsmanic wrote:
GPS errors can easily exceed 100 feet.
And it is exceedingly rare that they do.
And 100 feet sounds pretty
significant for RVSM.
It is not.
Unless death awaits above.
It does not.
How wasteful of manufacturers to produce altimeters that provide
accuracy better than the nearest 100 feet.
Irrelavant.
You make mistakes and die.
No, very few mistakes cause death.
I make mistakes and learn. Simulation
affords the opportunity to make mistakes safely and teaches humility.
So does actual flying.
  #89
Old November 19th 06, 04:20 AM posted to rec.aviation.piloting
Newps
Mxsmanic wrote:
Another problem, not actually part of GPS per se, is moving maps.
Your GPS position may be accurate, but that doesn't guarantee that the
map is accurate. If the mountain on the map is in the wrong place in
relation to its real-world position, having high accuracy from GPS
won't help you. Very often map errors are more of a problem than
errors in the GPS itself.
Once again you don't know what you're talking about. Even if the map
were out of spec a little it doesn't matter as you aren't flying that
close to the mountains if you are IFR. An actual pilot would know that.
Note that WAAS and LAAS will _not_ compensate for either of the above
types of error.
Doesn't matter.
Differential GPS systems like this work best when you
are at exactly the spot used as a reference for the corrections. If
you are anywhere else, the corrections may not be right for your
position. The further away you are from the surveyed reference
position used to generate the corrections, the more likely it is that
your position will be incorrect.
Completely irrelavant for aviation.
  #90
Old November 19th 06, 05:58 AM posted to rec.aviation.piloting
Dave Stadt
"Mxsmanic" wrote in message
One thing you keep missing as a "pretend" pilot is that an error of
+/- 100 ft is insignificant in the real world.
GPS errors can easily exceed 100 feet. And 100 feet sounds pretty
significant for RVSM. With errors that large, some aircraft may be
vertically separated by only slight more than the spans of their
wings.
But as I've said, as PIC, you do what you want.
If a 100 ft error on the GPS is the difference between life and death,
a real pilot will climb.
It matters very little that you show that you are 5500 ft msl when you
are actually
5400 ft. you ain't gonna crash and you're no more likely to have a
mid-air
than flying at 5500.
This is the difference between the REAL world that we live in, and the
FANTASY world that you live in. We live it and KNOW. You read it and
pretend to be an expert.
You make mistakes and die. I make mistakes and learn. Simulation
Your simulator affords you the opportunity to play a game........nothing
more, nothing less.
UAV's and TFR's along the Mexico boarder John Doe Piloting 145 March 31st 06 07:58 PM
It was really close... Jay Honeck Piloting 166 May 22nd 05 02:30 PM
Logging approaches Ron Garrison Instrument Flight Rules 109 March 2nd 04 06:54 PM
GPS Altitude with WAAS Phil Verghese Instrument Flight Rules 42 October 5th 03 01:39 AM
gps altitude accuracy Martin Gregorie Soaring 12 July 18th 03 09:51 PM
