Garmin 396 Reception Problems - Latest Observations
Old November 20th 06, 05:38 AM posted to rec.aviation.owning
J. Severyn
Default Garmin 396 Reception Problems - Latest Observations
As other posters have noted, an external antenna will probably help. But
GPS operates at normal signal levels that are below the noise threshold.
Fancy software and hardware extracts the GPS signal.
Your Nav or Com is a superhet radio using a local oscillator (small
transmitter) to beat with the incoming nav or com signal and create an
intermediate frequency. The local oscillator (LO) has harmonics that extend
into the Ghz region, raising havoc with your GPS receiver. So even with an
external antenna you might still have problems. You might try an amplified
antenna, mounted away from your nav-coms. (most remote GPS antennae contain
an amplifier that will get its power from the 396). It will boost the GPS
signal.....and if mounted far away from the navcoms, the amplified antenna
might raise the S/N ratio high enough to allow GPS operation. Go for a unit
with at least 15db of gain, but remember the longer antenna coax will drop
the signal a few db (depending on quality of the coax cable).
Regards,
John Severyn
@KLVK
Pirep: Garmin GPSMAP 296 versus 295. (very long) Jon Woellhaf Piloting 12 September 5th 04 12:55 AM
more radial fans like fw190? jt Military Aviation 51 August 28th 04 05:22 AM
WAAS and Garmin 430/530 DoodyButch Owning 23 October 13th 03 05:06 AM
Real World Specs for FS 2004 Paul H. Simulators 16 August 18th 03 10:25 AM
And they say the automated Weather Station problems "ASOS" are insignificant because only light aircraft need Weather Observations and forecasts... Roy Piloting 4 July 12th 03 05:03 PM
