Glue it to it
Old December 7th 06, 09:16 PM posted to rec.aviation.homebuilt
Morgans[_2_]
Default Glue it to it
wrote
Once the early designers appreciated the advantage of the one over the
other they moved immediately to true monocoque structures of molded
plywood, welded steel tubing and so forth, but the structural integrity
of the 'box' structures combined with their simplicity of fabrication
makes the method ideal for homebuilders even today.
Correct me if I'm wrong, but isn't epoxy for homebuilders considered much more
"user friendly" than Resorcinol, because Resorcinol is very particular about
having uniform, tight fitting joints, and the correct clamping pressure?
Jim in NC
resorcinol = Carpenter's glue [email protected] Home Built 13 June 13th 05 12:01 AM
Removable glue Lou Home Built 2 April 14th 05 07:57 AM
Glue question [email protected] Owning 1 December 6th 04 04:25 PM
Drywall Gussets Veeduber Home Built 5 October 27th 03 10:03 PM
Qn: Casein Glue recognition Vassilios Mazis Soaring 0 August 20th 03 11:00 PM
