Contact Approach -- WX reporting
Old December 14th 06, 07:40 AM posted to rec.aviation.ifr
Jim Macklin
Default Contact Approach -- WX reporting
The OUT is that you are in the system and can resume IFR.
S&R is a function of a flight plan. Commercial flights are
required to be "on a flight plan" and canceling IFR even for
the last few minutes of a charter flight puts you in
violation.
Flight visibility is solely judged by the pilot on an IFR
approach, once the first step is passed. ATC will clear any
airplane to make any approach the pilot requests. The pilot
is not supposed to request or begin an approach if the
weather is below visibility minimums. But any pilot, Part
91,121, 125, or 135 is the only person who can judge flight
visibility and that is the controlling visibility on an IFR
approach.
How do you judge visibility? Standard approach lights are
of a certain size as are the runway lights. You learn how
to judge, 91.175 (c)(2) The flight visibility is not less
than the visibility prescribed in the standard instrument
approach being used; and
1.1
Flight visibility means the average forward horizontal
distance, from the cockpit of an aircraft in flight, at
which prominent unlighted objects may be seen and identified
by day and prominent lighted objects may be seen and
identified by night.
| Jim Macklin wrote:
| At airports without official weather reporting,
| the pilot can report to ATC that visibility is such and
such
| and he can maintain VMC and request a contact approach,
| pilot become the weather observer.
| Can you really do that? A pilot's guess of ground
visibility from
| aloft is good enough for the FAA?
| The advantage is that
| the IFR clearance is still in the system and the pilot
has
| the "out." It keeps an active flight plan, which is
nice er
| than canceling IFR and then nobody will look for you.
| I wouldn't consider search-and-rescue an "out." The only
thing I can
| think of is that staying IFR keeps other IFR traffic out
of your hair.
| Is there another advantage?
Old December 14th 06, 08:25 AM posted to rec.aviation.ifr
I didn't ask about flight visibility. The rules clearly state that ATC
can only authorize a contact approach if GROUND visibility is reported
to be at least one statute mile.
So, let me ask again. Can you report GROUND visibility from thousands
of feet above the airport? How about if you're still 10 miles out?
And, further, is that report something a pilot can do anyway, or does
it have to be an official weather report?
violation.
approach.
1.1
such
visibility from
has
nice er
thing I can
of your hair.
Old December 14th 06, 01:16 PM posted to rec.aviation.ifr
Steven P. McNicoll[_2_]
It was briefly mentioned in one of the longer threads that a contact
approach requires 1 sm reported ground visibility. It reminded me that
I had flown a contact approach some 8 months ago to an airport about 15
minutes after the tower had closed (there is no automated weather
available) and couldn't land because fog and low clouds had rolled in.
So did approach control screw up? I'm sure they had the last ATIS
report some 70 to 80 minutes old at the time of my request, and the
weather was good in that report.
If the tower had closed just fifteen minutes earlier approach may have
had a weather observation less than 30 minutes old.
Interestingly, both the AIM and the 7110.65 say that a requirement for
ATC authorization of a contact approach is that "The reported ground
visibility is at least 1 statute mile."
But the AIM starts out by saying: "Pilots operating in accordance with
an IFR flight plan, provided they are clear of clouds and have at least
1 mile flight visibility and can reasonably expect to continue to the
destination airport in those conditions, may request ATC authorization
for a contact approach."
Well, a reported ground visibility of at leats one statute mile and a
flight visibility of at least one statute mile are not mutually
exclusive. While ground visibility can be determined quite accurately,
flight visibility is just a guess.
Old December 14th 06, 01:51 PM posted to rec.aviation.ifr
Newps wrote:
So you're saying that the controllers are the weather observers there?
That would put it in a gray area. The book states that weather must be
available. If you received the clearance before the tower closed that
would be OK.
The book states only that "The reported ground visibility is at least 1
statute mile." The gray area is whether the last hourly observation is
still valid 15 minutes after the weather observer departs. It isn't
yet time for another hourly observation, but he isn't there to issue a
special observation if weather conditions change significantly.
Flight viz is irrelavant. The determining factor is reported ground viz.
The book (FAAO 7110.65) also states, "When executing a contact
approach, the pilot is responsible for maintaining the required flight
visibility, cloud clearance, and terrain/obstruction clearance." It
doesn't provide a hint where the requirement for flight visibility can
be found, however. The AIM states in paragraph 5-4-24 that pilots must
have at least one mile flight visibility, but it also states the
following in Flight Information Publication Policy:
"This publication, while not regulatory, provides information which
reflects examples of operating techniques and procedures which may be
requirements in other federal publications or regulations. It is made
available solely to assist pilots in executing their responsibilities
required by other publications."
Old December 14th 06, 01:57 PM posted to rec.aviation.ifr
Dan wrote:
Since a contact approach requires the airport to have an IFR approach,
I fail to see the advantage of a contact approach. If visibility is at
1 mile, I think I would rather just fly the approach than pick around
for the airport in those conditions - too risky. Where is the
advantage? Following other traffic visually?
Suppose you're abeam the runway while being vectored for an IFR
approach when you sight the field. The current weather observation is
below VFR minimums so a visual approach is not available. Would a
contact approach present an advantage in that situation?
Old December 14th 06, 02:02 PM posted to rec.aviation.ifr
Jim Macklin wrote:
In any case, the pilot doing a contact approach must
maintain a flight visibility of 1 sm while the controller
can't issue the clearance unless the visibility is reported
as 1 sm. At airports without official weather reporting,
the pilot can report to ATC that visibility is such and such
and he can maintain VMC and request a contact approach, the
Negative. Issuance of clearance for a contact approach requires a
reported ground visibility is at least 1 statute mile. At airports
without official weather reporting a contact approach is not available.
Old December 14th 06, 02:03 PM posted to rec.aviation.ifr
Can you really do that? A pilot's guess of ground visibility from
No and no.
Old December 14th 06, 02:14 PM posted to rec.aviation.ifr
Jim Macklin
Gee, there sure are a lot of contact approaches made to
airports.
Section 5. Pilot/Controller Roles
and Responsibilities
5-5-1. General
a. The roles and responsibilities of the pilot and
controller for effective participation in the ATC system are
contained in several documents. Pilot responsibilities are
in the CFRs and the air traffic controllers' are in the FAA
Order 7110.65, Air Traffic Control, and supplemental FAA
directives. Additional and supplemental information for
pilots can be found in the current Aeronautical Information
Manual (AIM), Notices to Airmen, Advisory Circulars and
aeronautical charts. Since there are many other excellent
publications produced by nongovernment organizations, as
well as other government organizations, with various
updating cycles, questions concerning the latest or most
current material can be resolved by cross-checking with the
above mentioned documents.
b. The pilot-in-command of an aircraft is directly
responsible for, and is the final authority as to the safe
operation of that aircraft. In an emergency requiring
immediate action, the pilot-in-command may deviate from any
rule in the General Subpart A and Flight Rules Subpart B in
accordance with 14 CFR Section 91.3.
c. The air traffic controller is responsible to give
first priority to the separation of aircraft and to the
issuance of radar safety alerts, second priority to other
services that are required, but do not involve separation of
aircraft and third priority to additional services to the
extent possible.
d. In order to maintain a safe and efficient air
traffic system, it is necessary that each party fulfill
their responsibilities to the fullest.
e. The responsibilities of the pilot and the
controller intentionally overlap in many areas providing a
degree of redundancy. Should one or the other fail in any
manner, this overlapping responsibility is expected to
compensate, in many cases, for failures that may affect
safety.
f. The following, while not intended to be all
inclusive, is a brief listing of pilot and controller
responsibilities for some commonly used procedures or phases
of flight. More detailed explanations are contained in other
portions of this publication, the appropriate CFRs, ACs and
similar publications. The information provided is an
overview of the principles involved and is not meant as an
interpretation of the rules nor is it intended to extend or
diminish responsibilities.
5-5-2. Air Traffic Clearance
a. Pilot.
1. Acknowledges receipt and understanding of an ATC
clearance.
2. Reads back any hold short of runway instructions
issued by ATC.
3. Requests clarification or amendment, as
appropriate, any time a clearance is not fully understood or
considered unacceptable from a safety standpoint.
4. Promptly complies with an air traffic clearance
upon receipt except as necessary to cope with an emergency.
Advises ATC as soon as possible and obtains an amended
clearance, if deviation is necessary.
NOTE-
A clearance to land means that appropriate separation
on the landing runway will be ensured. A landing clearance
does not relieve the pilot from compliance with any
previously issued altitude crossing restriction.
b. Controller.
1. Issues appropriate clearances for the operation to
be conducted, or being conducted, in accordance with
established criteria.
2. Assigns altitudes in IFR clearances that are at or
above the minimum IFR altitudes in controlled airspace.
3. Ensures acknowledgement by the pilot for issued
information, clearances, or instructions.
4. Ensures that readbacks by the pilot of altitude,
heading, or other items are correct. If incorrect,
distorted, or incomplete, makes corrections as appropriate.
5-5-3. Contact Approach
a. Pilot.
1. Must request a contact approach and makes it in
lieu of a standard or special instrument approach.
2. By requesting the contact approach, indicates that
the flight is operating clear of clouds, has at least one
mile flight visibility, and reasonably expects to continue
to the destination airport in those conditions.
3. Assumes responsibility for obstruction clearance
while conducting a contact approach.
4. Advises ATC immediately if unable to continue the
contact approach or if encounters less than 1 mile flight
visibility.
5. Is aware that if radar service is being received,
it may be automatically terminated when told to contact the
tower.
REFERENCE-
Pilot/Controller Glossary Term- Radar Service
Terminated.
b. Controller.
1. Issues clearance for a contact approach only when
requested by the pilot. Does not solicit the use of this
procedure.
2. Before issuing the clearance, ascertains that
reported ground visibility at destination airport is at
least 1 mile.
3. Provides approved separation between the aircraft
cleared for a contact approach and other IFR or special VFR
aircraft. When using vertical separation, does not assign a
fixed altitude, but clears the aircraft at or below an
altitude which is at least 1,000 feet below any IFR traffic
but not below Minimum Safe Altitudes prescribed in 14 CFR
Section 91.119.
4. Issues alternative instructions if, in their
judgment, weather conditions may make completion of the
approach impracticable.
5-5-4. Instrument Approach
a. Pilot.
1. Be aware that the controller issues clearance for
approach based only on known traffic.
2. Follows the procedure as shown on the IAP,
including all restrictive notations, such as:
(a) Procedure not authorized at night;
(b) Approach not authorized when local area altimeter
not available;
(c) Procedure not authorized when control tower not in
operation;
(d) Procedure not authorized when glide slope not
used;
(e) Straight-in minimums not authorized at night; etc.
(f) Radar required; or
(g) The circling minimums published on the instrument
approach chart provide adequate obstruction clearance and
pilots should not descend below the circling altitude until
the aircraft is in a position to make final descent for
landing. Sound judgment and knowledge of the pilot's and the
aircraft's capabilities are the criteria for determining the
exact maneuver in each instance since airport design and the
aircraft position, altitude and airspeed must all be
considered.
REFERENCE-
AIM, Approach and Landing Minimums, Paragraph 5-4-20.
3. Upon receipt of an approach clearance while on an
unpublished route or being radar vectored:
(a) Complies with the minimum altitude for IFR; and
(b) Maintains the last assigned altitude until
established on a segment of a published route or IAP, at
which time published altitudes apply.
b. Controller.
1. Issues an approach clearance based on known
traffic.
2. Issues an IFR approach clearance only after the
aircraft is established on a segment of published route or
IAP, or assigns an appropriate altitude for the aircraft to
maintain until so established.
5-5-5. Missed Approach
a. Pilot.
1. Executes a missed approach when one of the
following conditions exist:
(a) Arrival at the Missed Approach Point (MAP) or the
Decision Height (DH) and visual reference to the runway
environment is insufficient to complete the landing.
(b) Determines that a safe approach or landing is not
possible (see subparagraph 5-4-21g).
(c) Instructed to do so by ATC.
2. Advises ATC that a missed approach will be made.
Include the reason for the missed approach unless the missed
approach is initiated by ATC.
3. Complies with the missed approach instructions for
the IAP being executed from the MAP, unless other missed
approach instructions are specified by ATC.
4. If executing a missed approach prior to reaching
the MAP, fly the lateral navigation path of the instrument
procedure to the MAP. Climb to the altitude specified in the
missed approach procedure, except when a maximum altitude is
specified between the final approach fix (FAF) and the MAP.
In that case, comply with the maximum altitude restriction.
Note, this may require a continued descent on the final
approach.
5. Following a missed approach, requests clearance for
specific action; i.e., another approach, hold for improved
conditions, proceed to an alternate airport, etc.
b. Controller.
1. Issues an approved alternate missed approach
procedure if it is desired that the pilot execute a
procedure other than as depicted on the instrument approach
chart.
2. May vector a radar identified aircraft executing a
missed approach when operationally advantageous to the pilot
or the controller.
3. In response to the pilot's stated intentions,
issues a clearance to an alternate airport, to a holding
fix, or for reentry into the approach sequence, as traffic
conditions permit.
5-5-6. Radar Vectors
a. Pilot.
1. Promptly complies with headings and altitudes
assigned to you by the controller.
2. Questions any assigned heading or altitude believed
to be incorrect.
3. If operating VFR and compliance with any radar
vector or altitude would cause a violation of any CFR,
advises ATC and obtains a revised clearance or instructions.
b. Controller.
1. Vectors aircraft in Class A, Class B, Class C,
Class D, and Class E airspace:
(a) For separation.
(b) For noise abatement.
(c) To obtain an operational advantage for the pilot
or controller.
2. Vectors aircraft in Class A, Class B, Class C,
Class D, Class E, and Class G airspace when requested by the
pilot.
3. Vectors IFR aircraft at or above minimum vectoring
altitudes.
4. May vector VFR aircraft, not at an ATC assigned
altitude, at any altitude. In these cases, terrain
separation is the pilot's responsibility.
5-5-7. Safety Alert
a. Pilot.
1. Initiates appropriate action if a safety alert is
received from ATC.
2. Be aware that this service is not always available
and that many factors affect the ability of the controller
to be aware of a situation in which unsafe proximity to
terrain, obstructions, or another aircraft may be
developing.
b. Controller.
1. Issues a safety alert if aware an aircraft under
their control is at an altitude which, in the controller's
judgment, places the aircraft in unsafe proximity to
terrain, obstructions or another aircraft. Types of safety
alerts a
(a) Terrain or Obstruction Alert. Immediately issued
to an aircraft under their control if aware the aircraft is
at an altitude believed to place the aircraft in unsafe
proximity to terrain or obstructions.
(b) Aircraft Conflict Alert. Immediately issued to an
aircraft under their control if aware of an aircraft not
under their control at an altitude believed to place the
aircraft in unsafe proximity to each other. With the alert,
they offer the pilot an alternative, if feasible.
2. Discontinue further alerts if informed by the pilot
action is being taken to correct the situation or that the
other aircraft is in sight.
5-5-8. See and Avoid
a. Pilot. When meteorological conditions permit,
regardless of type of flight plan or whether or not under
control of a radar facility, the pilot is responsible to see
and avoid other traffic, terrain, or obstacles.
b. Controller.
1. Provides radar traffic information to radar
identified aircraft operating outside positive control
airspace on a workload permitting basis.
2. Issues safety alerts to aircraft under their
control if aware the aircraft is at an altitude believed to
place the aircraft in unsafe proximity to terrain,
obstructions, or other aircraft.
5-5-9. Speed Adjustments
a. Pilot.
1. Advises ATC any time cruising airspeed varies plus
or minus 5 percent or 10 knots, whichever is greater, from
that given in the flight plan.
2. Complies with speed adjustments from ATC unless:
(a) The minimum or maximum safe airspeed for any
particular operation is greater or less than the requested
airspeed. In such cases, advises ATC.
NOTE-
It is the pilot's responsibility and prerogative to
refuse speed adjustments considered excessive or contrary to
the aircraft's operating specifications.
(b) Operating at or above 10,000 feet MSL on an ATC
assigned SPEED ADJUSTMENT of more than 250 knots IAS and
subsequent clearance is received for descent below 10,000
feet MSL. In such cases, pilots are expected to comply with
14 CFR Section 91.117(a).
3. When complying with speed adjustment assignments,
maintains an indicated airspeed within plus or minus 10
knots or 0.02 Mach number of the specified speed.
b. Controller.
1. Assigns speed adjustments to aircraft when
necessary but not as a substitute for good vectoring
technique.
2. Adheres to the restrictions published in the FAA
Order 7110.65, Air Traffic Control, as to when speed
adjustment procedures may be applied.
3. Avoids speed adjustments requiring alternate
decreases and increases.
4. Assigns speed adjustments to a specified IAS
(KNOTS)/Mach number or to increase or decrease speed using
increments of 10 knots or multiples thereof.
5. Advises pilots to resume normal speed when speed
adjustments are no longer required.
6. Gives due consideration to aircraft capabilities to
reduce speed while descending.
7. Does not assign speed adjustments to aircraft at or
above FL 390 without pilot consent.
5-5-10. Traffic Advisories (Traffic Information)
a. Pilot.
1. Acknowledges receipt of traffic advisories.
2. Informs controller if traffic in sight.
3. Advises ATC if a vector to avoid traffic is
desired.
4. Does not expect to receive radar traffic advisories
on all traffic. Some aircraft may not appear on the radar
display. Be aware that the controller may be occupied with
higher priority duties and unable to issue traffic
information for a variety of reasons.
5. Advises controller if service is not desired.
b. Controller.
1. Issues radar traffic to the maximum extent
consistent with higher priority duties except in Class A
airspace.
2. Provides vectors to assist aircraft to avoid
observed traffic when requested by the pilot.
3. Issues traffic information to aircraft in the Class
B, Class C, and Class D surface areas for sequencing
purposes.
5-5-11. Visual Approach
a. Pilot.
1. If a visual approach is not desired, advises ATC.
2. Complies with controller's instructions for vectors
toward the airport of intended landing or to a visual
position behind a preceding aircraft.
3. The pilot must, at all times, have either the
airport or the preceding aircraft in sight. After being
cleared for a visual approach, proceed to the airport in a
normal manner or follow the preceding aircraft. Remain clear
of clouds while conducting a visual approach.
4. If the pilot accepts a visual approach clearance to
visually follow a preceding aircraft, you are required to
establish a safe landing interval behind the aircraft you
were instructed to follow. You are responsible for wake
turbulence separation.
5. Advise ATC immediately if the pilot is unable to
continue following the preceding aircraft, cannot remain
clear of clouds, or lose sight of the airport.
6. Be aware that radar service is automatically
terminated, without being advised by ATC, when the pilot is
instructed to change to advisory frequency.
7. Be aware that there may be other traffic in the
traffic pattern and the landing sequence may differ from the
traffic sequence assigned by approach control or ARTCC.
b. Controller.
1. Do not clear an aircraft for a visual approach
unless reported weather at the airport is ceiling at or
above 1,000 feet and visibility is 3 miles or greater. When
weather is not available for the destination airport, inform
the pilot and do not initiate a visual approach to that
airport unless there is reasonable assurance that descent
and flight to the airport can be made visually.
2. Issue visual approach clearance when the pilot
reports sighting either the airport or a preceding aircraft
which is to be followed.
3. Provide separation except when visual separation is
being applied by the pilot.
4. Continue flight following and traffic information
until the aircraft has landed or has been instructed to
5. Inform the pilot when the preceding aircraft is a
heavy.
6. When weather is available for the destination
airport, do not initiate a vector for a visual approach
unless the reported ceiling at the airport is 500 feet or
more above the MVA and visibility is 3 miles or more. If
vectoring weather minima are not available but weather at
the airport is ceiling at or above 1,000 feet and visibility
of 3 miles or greater, visual approaches may still be
conducted.
7. Informs the pilot conducting the visual approach of
the aircraft class when pertinent traffic is known to be a
heavy aircraft.
5-5-12. Visual Separation
a. Pilot.
1. Acceptance of instructions to follow another
aircraft or to provide visual separation from it is an
acknowledgment that the pilot will maneuver the aircraft as
necessary to avoid the other aircraft or to maintain
in-trail separation. Pilots are responsible to maintain
visual separation until flight paths (altitudes and/or
courses) diverge.
2. If instructed by ATC to follow another aircraft or
to provide visual separation from it, promptly notify the
controller if you lose sight of that aircraft, are unable to
maintain continued visual contact with it, or cannot accept
the responsibility for your own separation for any reason.
3. The pilot also accepts responsibility for wake
turbulence separation under these conditions.
b. Controller. Applies visual separation only:
1. Within the terminal area when a controller has both
aircraft in sight or by instructing a pilot who sees the
other aircraft to maintain visual separation from it.
2. Pilots are responsible to maintain visual
separation until flight paths (altitudes and/or courses)
diverge.
3. Within en route airspace when aircraft are on
opposite courses and one pilot reports having seen the other
aircraft and that the aircraft have passed each other.
5-5-13. VFR-on-top
a. Pilot.
1. This clearance must be requested by the pilot on an
IFR flight plan, and if approved, allows the pilot the
choice (subject to any ATC restrictions) to select an
altitude or flight level in lieu of an assigned altitude.
NOTE-
VFR-on-top is not permitted in certain airspace areas,
such as Class A airspace, certain restricted areas, etc.
Consequently, IFR flights operating VFR-on-top will avoid
such airspace.
REFERENCE-
AIM, IFR Clearance VFR-on-top, Paragraph 4-4-7.
AIM, IFR Separation Standards, Paragraph 4-4-10.
AIM, Position Reporting, Paragraph 5-3-2.
AIM, Additional Reports, Paragraph 5-3-3.
2. By requesting a VFR-on-top clearance, the pilot
assumes the sole responsibility to be vigilant so as to see
and avoid other aircraft and to:
(a) Fly at the appropriate VFR altitude as prescribed
in 14 CFR Section 91.159.
(b) Comply with the VFR visibility and distance from
clouds criteria in 14 CFR Section 91.155, Basic VFR weather
minimums.
(c) Comply with instrument flight rules that are
applicable to this flight; i.e., minimum IFR altitudes,
position reporting, radio communications, course to be
flown, adherence to ATC clearance, etc.
3. Should advise ATC prior to any altitude change to
ensure the exchange of accurate traffic information.
b. Controller.
1. May clear an aircraft to maintain VFR-on-top if the
pilot of an aircraft on an IFR flight plan requests the
clearance.
2. Informs the pilot of an aircraft cleared to climb
to VFR-on-top the reported height of the tops or that no top
report is available; issues an alternate clearance if
necessary; and once the aircraft reports reaching
VFR-on-top, reclears the aircraft to maintain VFR-on-top.
3. Before issuing clearance, ascertain that the
aircraft is not in or will not enter Class A airspace.
5-5-14. Instrument Departures
a. Pilot.
1. Prior to departure considers the type of terrain
and other obstructions on or in the vicinity of the
departure airport.
2. Determines if obstruction avoidance can be
maintained visually or that the departure procedure should
be followed.
3. Determines whether a departure procedure and/or DP
is available for obstruction avoidance.
4. At airports where IAPs have not been published,
hence no published departure procedure, determines what
action will be necessary and takes such action that will
assure a safe departure.
b. Controller.
1. At locations with airport traffic control service,
when necessary, specifies direction of takeoff, turn, or
initial heading to be flown after takeoff.
2. At locations without airport traffic control
service but within Class E surface area when necessary to
specify direction of takeoff, turn, or initial heading to be
flown, obtains pilot's concurrence that the procedure will
allow the pilot to comply with local traffic patterns,
terrain, and obstruction avoidance.
3. Includes established departure procedures as part
of the ATC clearance when pilot compliance is necessary to
ensure separation.
5-5-15. Minimum Fuel Advisory
a. Pilot.
1. Advise ATC of your minimum fuel status when your
fuel supply has reached a state where, upon reaching
destination, you cannot accept any undue delay.
2. Be aware this is not an emergency situation, but
merely an advisory that indicates an emergency situation is
possible should any undue delay occur.
3. On initial contact the term "minimum fuel" should
be used after stating call sign.
EXAMPLE-
Salt Lake Approach, United 621, "minimum fuel."
4. Be aware a minimum fuel advisory does not imply a
need for traffic priority.
5. If the remaining usable fuel supply suggests the
need for traffic priority to ensure a safe landing, you
should declare an emergency due to low fuel and report fuel
remaining in minutes.
REFERENCE-
Pilot/Controller Glossary Item- Fuel Remaining.
b. Controller.
1. When an aircraft declares a state of minimum fuel,
relay this information to the facility to whom control
jurisdiction is transferred.
2. Be alert for any occurrence which might delay the
aircraft.
5-5-16. RNAV and RNP Operations
a. Pilot.
1. If unable to comply with the requirements of an
RNAV or RNP procedure, pilots shall advise air traffic
control as soon as possible. For example, ". . . N1234,
failure of GPS system, unable RNAV, request amended
clearance."
2. Pilots are not authorized to fly a published RNAV
or RNP procedure unless it is retrievable by the procedure
name from the aircraft navigation database and conforms to
the charted procedure.
3. Pilots shall not change any database waypoint type
from a fly-by to fly-over, or vice versa. No other
modification of database waypoints or the creation of
user-defined waypoints on published RNAV or RNP procedures
is permitted, except to:
(a) Change altitude and/or airspeed waypoint
constraints to comply with an ATC clearance/instruction.
(b) Insert a waypoint along the published route to
assist in complying with ATC instruction, example, "Descend
via the WILMS arrival except cross 30 north of BRUCE at/or
below FL 210." This is limited only to systems that allow
along-track waypoint construction.
4. Pilots of aircraft utilizing DME/DME for primary
radio updating shall ensure any published required DME
stations are in service as determined by NOTAM, ATIS, or ATC
advisory. No pilot monitoring of FMS navigation source(s) is
required.
5. Pilots of FMS-equipped aircraft, who are assigned
an RNAV DP or STAR procedure and subsequently receive a
change of runway, transition or procedure, shall verify that
the appropriate changes are loaded and available for
navigation.
6. While operating on RNAV segments, pilots are
encouraged to use flight director, in lateral navigation
mode.
7. For Type B RNAV DPs and STARs, pilots must use a
CDI/flight director and/or autopilot, in lateral navigation
mode. For Type A RNAV DPs and STARs, these procedures are
recommended. Other methods providing an equivalent level of
performance may also be acceptable.
8. For Type B RNAV DPs and STARs, pilots of aircraft
without GPS, using DME/DME/IRU, must ensure the aircraft
navigation system position is confirmed, within 1,000 feet,
at the start point of take-off roll. The use of an automatic
or manual runway update is an acceptable means of compliance
with this requirement. Other methods providing an equivalent
level of performance may also be acceptable.
9. RNAV terminal procedures may be amended by ATC
issuing radar vectors and/or clearances direct to a
waypoint. Pilots should avoid premature manual deletion of
waypoints from their active "legs" page to allow for
rejoining procedures.
10. While operating on RNAV segments, pilots operating
/R aircraft shall adhere to any flight manual limitation or
operating procedure required to maintain the RNP value
specified for the procedure.
state that ATC
is reported
from thousands
miles out?
anyway, or does
IFR.
are
for
| violation.
IFR
any
pilot
Part
flight
IFR
| approach.
are
how
less
instrument
| 1.1
identified
| wrote in message
and
| such
approach,
| the
| visibility from
pilot
| has
| nice er
you.
only
| thing I can
out
| of your hair.
karl gruber wrote:
One advantage (without looking at the regs so beat me up) is if you are VFR
and want to make a low weather scud run into an airport where "special VFR"
is NOT available.
Just ask the tower for a "Contact approach" instead.
Hmmmmm.......... What do you mean by airports where SVFR is not
available? SVFR is generally not available at airports in Class B
airspace and some of the busier Class C airspace areas. But at those
airports you're unlikely to even get a popup IFR clearance. SVFR is
also not available at airports outside of a surface area, but neither
is a contact approach. Surface areas and contact approaches both
require weather observations.
Think about the minimums for a contact approach, SVFR, and VFR
operations at an airport in Class G airspace for a moment.
Old December 14th 06, 02:17 PM posted to rec.aviation.ifr
approach.
You can't get a contact approach without a reported ground visibility
of at least one statute mile.
VFR position reporting Mxsmanic Piloting 154 November 26th 06 05:45 PM
OLV GPS 36 approach question A Lieberma Instrument Flight Rules 59 August 15th 06 01:32 AM
Trust those Instruments.... Trust those Instruments..... A Lieberman Instrument Flight Rules 1 May 2nd 06 04:54 PM
Nearly had my life terminated today Michelle P Piloting 11 September 3rd 05 03:37 AM
"Cleared Straight-In Runway X; Report Y Miles Final" Jim Cummiskey Piloting 86 August 16th 04 07:23 PM
