Contact Approach -- WX reporting
Old December 14th 06, 02:27 PM posted to rec.aviation.ifr
Ron Natalie
Default Contact Approach -- WX reporting
Steven P. McNicoll wrote:
SVFR is
also not available at airports outside of a surface area, but neither
is a contact approach. Surface areas and contact approaches both
require weather observations.
A surface area isn't necessary for a contact approach.
Old December 14th 06, 02:48 PM posted to rec.aviation.ifr
Steven P. McNicoll[_2_]
I didn't say it was.
Old December 14th 06, 02:51 PM posted to rec.aviation.ifr
Jim Macklin wrote:
Gee, there sure are a lot of contact approaches made to
airports.
It would do you well to actually read what you copy and paste.
Old December 14th 06, 03:02 PM posted to rec.aviation.ifr
Ron Natalie
You said:
SVFR is also not available at airports outside of a surface area, but
neither is a contact approach.
The "but neither is a contact approach" seems to imply that.
Old December 14th 06, 03:05 PM posted to rec.aviation.ifr
Upon further review, I did misspeak. I wrote, "SVFR is also not
available at airports outside of a surface area, but neither is a
contact approach. Surface areas and contact approaches both require
weather observations." If you're approaching an airport where SVFR is
not available it's probably because it's outside of a surface area. I
see no advantage then in picking up an IFR clearance in order to
request a contact approach as the minimums for a contact approach are
the same as VFR in Class G airspace.
Old December 14th 06, 03:07 PM posted to rec.aviation.ifr
You're right. I was apparently writing my followup as you were writing
what's above.
  #28
Old December 14th 06, 04:31 PM posted to rec.aviation.ifr
Dan[_1_]
Good point... Most of the approaches I fly do not involve vectoring
close to the airport before going back out and coming in again, so I
did not think of this.
--Dan
Dan wrote:
Since a contact approach requires the airport to have an IFR approach,
I fail to see the advantage of a contact approach. If visibility is at
1 mile, I think I would rather just fly the approach than pick around
for the airport in those conditions - too risky. Where is the
advantage? Following other traffic visually?
Suppose you're abeam the runway while being vectored for an IFR
approach when you sight the field. The current weather observation is
below VFR minimums so a visual approach is not available. Would a
contact approach present an advantage in that situation?
  #29
Old December 14th 06, 05:04 PM posted to rec.aviation.ifr
Jim Macklin wrote:
A visual approach may be instigated by the controller if the
weather is good VFR.
What is good VFR?
Just VFR?
I thought MVFR or better was required for PIC request?
Is that the requirement for ATC to assign? That is to say they won't
assign in MVFR?
Thanks,
ak.
VFR position reporting Mxsmanic Piloting 154 November 26th 06 05:45 PM
OLV GPS 36 approach question A Lieberma Instrument Flight Rules 59 August 15th 06 01:32 AM
Trust those Instruments.... Trust those Instruments..... A Lieberman Instrument Flight Rules 1 May 2nd 06 04:54 PM
Nearly had my life terminated today Michelle P Piloting 11 September 3rd 05 03:37 AM
"Cleared Straight-In Runway X; Report Y Miles Final" Jim Cummiskey Piloting 86 August 16th 04 07:23 PM
