Jabiru V Rotax reliability?
Old September 3rd 03, 06:06 AM
Dave Grosvenor
Joe, what aeroplane are you using the engine on? Although you
correctly say that the Jab runs at lower rpm, with no gearbox the prop
rpm is high. You need to make sure you can turn a relatively small
prop at 3300rpm to extract all the hp out of the Jab. This doesn't
work on slow draggy aircraft with large frontal area.
Dave
"Michael Coates" wrote in message
Answer = Buy the Rotax.......
Joe wrote:
Looking to buy either a Jabiru or Rotax 4 stroke engine.
RELIABILITY is the most important factor.
Seems like the Jabiru should be better with lower RPM but
believe that
Rotax
have more engines in service and therefore more development
time and
hence
reliability.
Any comments welcomed.
Phil
Ellison TBI and ROTAX 582 Bill Elliott Aerobatics 0 December 22nd 03 06:58 PM
Using 100LL in a Rotax 912 Engine Yosimite Sam Home Built 3 August 16th 03 05:00 PM
Rotax 912 Full Throttle Springs Mark Callahan Home Built 0 July 5th 03 02:31 PM
