Contact Approach -- WX reporting
Old December 14th 06, 07:37 PM posted to rec.aviation.ifr
Steven P. McNicoll[_2_]
Default Contact Approach -- WX reporting
karl gruber wrote:
No. You can just get one from tower, JUST lke special VFR.
So all towers can issue SVFR and contact approach clearances?
  #52
Old December 14th 06, 07:44 PM posted to rec.aviation.ifr
Newps
Jose wrote:
Right, they are just not allowed to land if the viz requirements
aren't met. Routinely disregarded.
Yes, but for 91, it's flight visibility. The pilot can evaluate that.
Exactly, routinely disregarded.
  #53
Old December 14th 06, 07:52 PM posted to rec.aviation.ifr
Newps
Jim Macklin wrote:
Once past the FAF, the pilot becomes the sole authority on
the landing since only the pilot can determine flight
visibility. An aircraft using an N number can be issued an
approach clearance right down to zero-zero. A Tango
November or airline call sign will prompt a denial or query
about the legal status of the flight.
No, it won't. If you want an approach clearance you will get one. The
legality is not ATC's problem.
  #54
Old December 14th 06, 10:31 PM posted to rec.aviation.ifr
Steven P. McNicoll wrote:
So did approach control screw up? I'm sure they had the last ATIS
report some 70 to 80 minutes old at the time of my request, and the
weather was good in that report.
If the tower had closed just fifteen minutes earlier approach may have
had a weather observation less than 30 minutes old.
Well, the tower doesn't issue a new ATIS (on the recording) just before
they leave, but I suppose they probably do make a weather report that
goes to FSS. I'm not sure if that ends up at the ARTCC or not. But
they are not there to issue a special observation after they leave,
which is when the fog rolled in.
So I'd guess that for this clearance to have been "proper" the weather
observers would have to still be there and ready to issue a special
regardless of how old the last scheduled observation was. But, from
the discussion so far, it appears that such a requirement is not
actually spelled out in the regs.
Interestingly, both the AIM and the 7110.65 say that a requirement for
ATC authorization of a contact approach is that "The reported ground
visibility is at least 1 statute mile."
But the AIM starts out by saying: "Pilots operating in accordance with
an IFR flight plan, provided they are clear of clouds and have at least
1 mile flight visibility and can reasonably expect to continue to the
destination airport in those conditions, may request ATC authorization
for a contact approach."
Well, a reported ground visibility of at leats one statute mile and a
flight visibility of at least one statute mile are not mutually
exclusive. While ground visibility can be determined quite accurately,
flight visibility is just a guess.
Yes, but I found it interesting that the AIM specifically says that a
pilot may request a contact approach (flight viz 1) in conditions
when the controller may not approve it (ground viz 1). I suppose
that wording is left over from the days when the controller had more
access to weather observations than the pilot?
  #55
Old December 14th 06, 10:38 PM posted to rec.aviation.ifr
Newps wrote:
A class C tower could easily do that. Call up about 6 miles out and if
there's no traffic I can issue you a clearance as the tower controllers
at class C's are approach controllers. However you still have to meet
the normal constraints of an IFR clearance.
That makes sense with a traditional Class C (dedicated approach
control). Is this still the case at facilities like SJC and BUR where
the ARTCC is located in another metropolitan area?
  #56
Old December 14th 06, 10:47 PM posted to rec.aviation.ifr
karl gruber[_1_]
I believe all towers can issue SVFR, and I know for sure that PDX tower can
issue a contactapproach.
Karl
"Curator"
  #59
Old December 15th 06, 01:01 AM posted to rec.aviation.ifr
All towers cannot issue SVFR.
How can you tell if a tower is issuing a clearance for an IFR operation
or if it is relaying the clearance received from whatever facility has
responsibility and authority for IFR operations?
  #60
Old December 15th 06, 01:02 AM posted to rec.aviation.ifr
VFR position reporting Mxsmanic Piloting 154 November 26th 06 05:45 PM
OLV GPS 36 approach question A Lieberma Instrument Flight Rules 59 August 15th 06 01:32 AM
Trust those Instruments.... Trust those Instruments..... A Lieberman Instrument Flight Rules 1 May 2nd 06 04:54 PM
Nearly had my life terminated today Michelle P Piloting 11 September 3rd 05 03:37 AM
"Cleared Straight-In Runway X; Report Y Miles Final" Jim Cummiskey Piloting 86 August 16th 04 07:23 PM
