500 km Triangle at 306 km/hr in Argentina
Old December 24th 06, 08:05 PM posted to rec.aviation.soaring
Capt. Geoffrey Thorpe
Default 500 km Triangle at 306 km/hr in Argentina
"Charles Crosby" wrote in message
Greg Arnold wrote:
When you are cruising at 20,000' to 30,000', doesn't the effect of
altitude cause IAS to be substantially less than ground speed?
That is indeed true. However, there are aeroelastic concerns (such as
flutter) which may result in a lower indicated vne at high altitude.
Charles
http://home.comcast.net/~johan.larso...ride-home.html
The Long Ride Home
Harold Peterson
This article originally appeared in the August 1, 1966 issue of Sports
Illustrated. David Stevenson provided the issue of SI for scanning.
' "We're plagued with people who want to emphasize the danger," George said.
"Just flying a sailplane around is safer than power flying. One fundamental
safety factor is the soft landing. You have marvelous control-anywhere
between a 40 degree approach with full dive breaks to 3 degrees with none.
In contest or record flight, of course, you're definitely stretching a
little. On a glide you may easily reach 150 mph where the placard speed is
listed at 86." Placard speed is that beyond which the manufacturer makes no
guarantee that things will not start coming off. '
[Quoting George Moffat. G.T.]
Geoff
Question, Diamond distance as unsuccessful triangle. Roger Aviation Marketplace 1 November 22nd 04 08:34 PM
Question, Diamond distance as unsuccessful triangle. Roger Soaring 1 May 13th 04 02:31 AM
Argentina ! Frank Noort Military Aviation 0 January 27th 04 10:47 PM
Flying in Argentina Jay Soaring 1 November 25th 03 05:52 AM
new records (Out&Return) for Delore-Fossett in Argentina cernauta Soaring 0 November 17th 03 03:06 PM
