"Newps" wrote in message
. .. Jose wrote: It's not the gauges, it's the fuel distribution. In order to run LOP effectively each cylinder must peak at the same, or damned close, fuel flow and therefore at the same time. Yep, you're right. And this usually requires an engine mod, since stock airplane engines are not very uniform. In any case, don't these mods also come with a gauge for each cylender? No, the GAMI's are six injectors that replace the standard six. They reccomend an engine monitor but it's not necessary. As it happens I can run real nice LOP without having to buy the GAMI's. It's been much too long since I've known, and I'm too lazy to look it up on New Year's Eve, but aren't GAMI injectors usually installed using an engine monitor to obtain the best match for each injector and cylinder combination? After the inital shop work with an analyzer/monitor, the use of an engine monitor by the aircraft operator is recommended, but not required--exactly as you stated. BTW, I've always presumed that the advantage of a set of GAMI injectors was simply that they guaranteed a matched set; but you could also have a similarly matched set of stock injectors by carefull selection from a sizeable batch, or simply by fortunate happenstance. Is this your real world experience, or are you basically using the "hottest cylinder" method, or both? Peter |
| Thread Tools | |
| Display Modes | |
| Most reliable homebuilt helicopter? | tom pettit | Home Built | 35 | September 29th 05 03:24 PM |
| ROP masking of engine problems | Roger Long | Owning | 4 | September 27th 04 08:36 PM |
| Emergency Procedures | RD | Piloting | 13 | April 11th 04 09:25 PM |
| My Engine Fire!! | [email protected] | Piloting | 21 | April 2nd 04 06:02 PM |
| Autorotation ? R22 for the Experts | Eric D | Rotorcraft | 22 | March 5th 04 07:11 AM |
