New RAAF Air-To-Air Refuelling Capability
Old July 1st 03, 12:19 AM
Guy Alcala
JB wrote:
They've been orphans in QF operations for a very long time. Whilst I'm sure
there is a cost, I doubt that it's enough to really be a problem. There is
already plenty of expertise in place with regard to maintenance of these
engines.
I suspect it depends on exactly how the deal is structured. Are they going PFI,
is it going to be fully RAAF, some hybrid? On the orphan issue, does Qantas
want to get rid of them because they're too small, because they _are_ orphans
and not cost-effective, or some other reason? The other issue might be how
widely available parts will be for the JT9 for 20 years or so; after all, the
last new JT9D was produced in 1990. The JT9D seems likely to disappear from
service long before the other engines.
There are no pilot training/currency issues. If that's all the RAAF have,
then they won't have a currency or training problem. In practice, I operate
all three types of engine, and there aren't any practical issues, other than
remembering (or not) a few different limits. Procedurally more or less
identical.
Good to know. What's the thrust on the JT9s, compared to the other engines?
Payload capability operating from Learmonth and Tindal is likely to be a factor.
Guy
Old July 1st 03, 06:18 AM
matt weber
On Mon, 30 Jun 2003 22:19:42 GMT, Guy Alcala
engines.
identical.
Guy
JT9D's covered a wide range, but I believe the 767-200's have 7R's,
which in this application are 50,000 pounds thrust each. Runway
requirement/lift capability is rarely much of an issue with the -200.
You can get several variants of the CF6-80 for the 767-200ER, as well
as PW4000's. For thrust pick a number from 50,000 to about 57,000
pounds.
No RR engine was ever certified for the -200
Old July 1st 03, 11:35 AM
JB
"Guy Alcala" wrote in message
Do you happen to know why the -300s have less drag? Offhand I'd expect
opposite, given the larger wetted area.
Better fineness ratio.
Thanks for the info. I suspect FL330 is probably a good 8,000 feet higher
than
F-111s are likely to be cruising, or loaded F-18s. Certainly, that's far
higher
than the typical refueling altitudes the US uses in combat (FL210-250
being
quite typical), and most trans-oceanic ferry flights by U.S. fighters also
seem
to be done at FL250, presumably to prevent the need for constant climbs
from and
descents to refueling altitude.
I know. I chose the figure as it was about as high as they would reasonably
go at max weight. None of the engines are at their best when kept down low
though. I was a little surprised at just how well the PW compared in that
circumstance.
JB
Old July 1st 03, 11:42 AM
Guy Alcala
engines.
identical.
Guy
It appears that the Qantas 767-200ERs probably have a MTOW of 350,000 lb., judging by
a Boeing 767-200/200ER runway length takeoff chart* which shows a/c with the
JT9D-7R4D/7R4E or CF6-80A/A2 engines for that weight, and I agree that at that MTOW
takeoff distances should rarely be a problem, even in hot conditions.
*Found on the web some time back.
pounds.
Takeoff Runway length Charts for 200ERs with MTOWs of 380,000 (CF6-80C2-B2 or PW
4052) and 387,000 lb. (CF6-80C2-B4 or PW4056) on hot days (ISA +17C) show that runway
length is definitely becoming a factor. So, if they stick with lower gross weight
200ERs, no problem, but if they want to maximise payload and fuel offload in hot/high
conditions, the lower gross weight JT9D-powered a/c aren't going to cut it. While
the JT9D 767s shouldn't be anywhere near as limited in TOW as the USAF KC-135Es were
when based in the Gulf (or the really pitiful KC-135As), that still could be a
significant operational limitation. It will be interesting to see what the RAAF
decides to do (or rather, what the Government's willing to pay for), given that used
767 airframes seem to be relatively cheap and available these days. Guess it depends
what the market for freighter conversions is as well.
Guy
Old July 1st 03, 12:02 PM
JB
judging by
that MTOW
Their max t/o weight at the moment is 146,000 kgs. It used to be 155,000,
but was reduced when no longer needed for long haul ops. Registration fees
are based on this weight, so their is no point having more than you need.
or PW
that runway
gross weight
in hot/high
it. While
KC-135Es were
be a
the RAAF
that used
it depends
It all rather depends what you want to do with them. If you are buying
tankers, then with max fuel loads you will end up with t/o weights around
the 150 tonne mark. No performance problem at all. I you want to carry 30
tonnes of freight, and play tankers simultaneously, then you're looking at
the wrong aircraft. You will need something substantially bigger, and more
expensive.
As for 767s lying around the countryside...be interesting to see what
condition most of them are in. Remember, you can't look at 300s, as they'll
drag the refuelling boom on the ground when they lift off.
JB
Old July 1st 03, 12:03 PM
JB
"JB" wrote in message
are based on this weight, so there is no point having more than you need.
Damn, hate it when I do that...
JB
Old July 2nd 03, 01:28 AM
Guy Alcala
judging by
that MTOW
Thanks for the info. Even 155,000 kgs does seem rather lacking, although they
might be able to boost that during any freighter conversion.
or PW
that runway
gross weight
in hot/high
it. While
KC-135Es were
be a
the RAAF
that used
it depends
expensive.
They certainly should have more ability to act as deployment tankers (also
carrying freight/personnel) than anything based on a 707, so the higher gross
weights may well matter. Depends how often you think you'll need to operate out
of area, and how much tanking help (from allies) you can expect for the transit.
Has that actually been established, or is it more a question of 'yeah, you could
do it, but it will screw the takeoff and landing distances because you can't
rotate as much?' I wonder if the A330 has the same problem (a bigger
tanker/transport than the 767, but maybe too big/heavy for many of the bases the
RAAF might want to work from, in addition to the other issues).
Guy
Question on airplane's IFR capability Slav Inger Instrument Flight Rules 10 July 12th 03 04:48 PM
