Jeroen Wenting wrote: Indeed they would be jettisoned only if doing so would be critical to either the mission of the survival of the aircraft. The situation you mention is one, another is where the pylon itself is heavily damaged causing a lot of drag which would prevent the aircraft from reaching home. Or you might think of an F-22 carrying external fuel to penetrate into enemy territory jettisoning those tank and pylons to decrease its radar cross section for the commencement of the combat part of its mission (and meeting a tanker on the way out). "Jeremy Thomson" wrote in message m... In my 'Great Planes' video of the Northrup F5 Freedom Fighter it talked of the 'Scochi Tiger's being brought up to USAF standard with among other things 'Jettisonable Pylons'. I guess that meant the pylons with which the bombs, rockets & fuel tanks were attached. I suppose if an aircraft had taken a hit in a fuel tank & you absolutely must wring out every last bit of range to get you out of indian country, jettisoning the pylons would save a little weight & drag. Under what conditions would plyons be jettisoned? I dont know but is it usual these days for fighters to return to base keeping their empty drop tanks with them? Are plyons still jettisonable as USAF standard? Jeremy Thomson I recall seeing an account somewhere -- might have been the A-4 Squadron Signal volume -- of a Skyhawk pilot providing cover for a pilot rescue in Vietnam in which he had expended all his ordnance, and as a desperation measure to keep the bad guys' heads down, made a pass and released his multiple ejector racks. For whatever it's worth, he said it worked. |
| Thread Tools | |
| Display Modes | |
