Carb Heat
Old January 20th 07, 05:53 AM posted to rec.aviation.piloting
vlado
Default Carb Heat
Is the need for carb heat affected by ambient humidity? In low
humidity conditions, and also at very low temperatures, is the
propensity for carb ice reduced thus 'eliminating' the need for carb
heat?
Just curious what the discussion might bring.
Thx.
Old January 20th 07, 06:11 AM posted to rec.aviation.piloting
Jose
Default Carb Heat
It sure is. I tried to take off once in Shenandoah on a humid day, and
the engine failed its runup - when I pulled the power back, it quit
entirely. I did this a few times and called the mechanic over. We
couldn't find anything - the final theory was that carb ice had built up
while I was taxiing and during the runup. This had never happend to me
before, in this aircraft, or any other.
I preflit and took off with carb heat, and had no problem.
Jose
He who laughs, lasts.
Old January 20th 07, 06:42 AM posted to rec.aviation.piloting
Robert M. Gary
Default Carb Heat
heat?
You may want to hang out behind the back of your local ground school
and grab one of the old Private Pilot manuals they are throwing out.
-Robert
Old January 20th 07, 03:59 PM posted to rec.aviation.piloting
vlado
Default Carb Heat
heat?
-Robert
OK OK. Here's the deal, Outside the weather is "frightful" with no
visible moisture, 30% humidity & -12 centrigrate. Any chance of carb
ice in this condition?
(The manuals are gone; they've gone to CDs if not on their iPods.)
Thx
Old January 20th 07, 06:09 PM posted to rec.aviation.piloting
nrp
Default Carb Heat
AOPA has an excellent chart showing the likelyhood (sp?) of carb ice at
http://flighttraining.aopa.org/membe...rticles/58.cfm
I'm surprised it isn't more widely published.
Old January 20th 07, 08:01 PM posted to rec.aviation.piloting
Jim Logajan
Default Carb Heat
at
http://flighttraining.aopa.org/membe...lo/articles/58.
cfm
I clicked through and got:
"The section that you're trying to access requires membership in AOPA."
Does this AOPA public link have the same chart you intended to
reference?:
http://www.aopa.org/asf/epilot_acc/nyc02fa025_1.html
The chart (if it is the same one you mean) also appears on these pages:
http://www.faa.gov/ats/afss/newyork/ENROUTE.htm
http://www.tc.gc.ca/CivilAviation/pu...71/AIR/2-1.htm
Old January 21st 07, 07:18 AM posted to rec.aviation.piloting
Newps
Default Carb Heat
Nope, way too cold.
Old January 21st 07, 06:39 PM posted to rec.aviation.piloting
vlado
Default Carb Heat
Nope, way too cold.
Newps.....Thanks for the quick answer.
The AOPA chart shows that as well. It is true, a good chart with not
enough distribution.
Thx again.
Old January 21st 07, 11:29 PM posted to rec.aviation.piloting
nrp
Default Carb Heat
Yes they appear to be similar charts. The AOPA chart actually shpws a
strange anomaly for pressure carbs that limits the severe icing to
about 80% humidity. I'm not sure why that is so, and it may only be an
artist's mistake.
At any rate the general trend for when to expect icing from those
charts is clear.
Old January 22nd 07, 04:08 PM posted to rec.aviation.piloting
Default Carb Heat
artist's mistake.
charts is clear.
The OP's post indicates the increasing trend to ignore
training about carb ice. There have been several accidents in the last
few years around our part of the country involving carb ice, and in my
teaching i find that pilots don't know the mechanism of carb ice, nor
do they know how to recognize and manage it.
Dan
Carb heat. sprung hot or cold? Hayden Home Built 0 June 1st 06 12:07 AM
Lycoming Carb Heat Mitty Instrument Flight Rules 19 September 21st 05 07:43 PM
Have you ever experienced carb ice with an injector carb? flybynightkarmarepair Home Built 1 January 31st 05 02:48 AM
Induction System Water Problem Mike Spera Owning 1 January 30th 05 06:29 AM
Use of Carb Heat John Kirksey Piloting 4 November 30th 04 08:26 PM
