The Lexington ATC was NOT doing traffic count after he cleared Comair 5191 for takeoff
Old February 1st 07, 03:27 AM posted to rec.aviation.ifr
Steven P. McNicoll
Default The Lexington ATC was NOT doing traffic count after he cleared Comair 5191 for takeoff
"Sam Spade" wrote in message
I have been reviewing the transcript and actual tape of the Lexingon tower
during the period pertinent to the crash of Comair 5191. The tower
controller called the center for a release for each IFR departure on the
tape.
Wrong. The tower controller did not call the LEX sector at ZID for an IFR
release of any of the five aircraft on the tape. He called ZID TMU for flow
releases on SKW6819 to ORD and COM191 to ATL. TMU is Traffic Management
Unit, aka flow control.
  #62
Old February 1st 07, 03:30 AM posted to rec.aviation.ifr
Steven P. McNicoll
I guess that was the case. The local controller was using the ASR and did
approve a heading change for weather for one aircraft but he let the
Center know about that.
It sounds confusing. A G/A pilot could show up VFR 25 miles out and call
LEX Approach for an ILS. Would the local controller ship him off to Indy
Center or would he call Indy for permission to vector the guy onto the
ILS?
He would do neither, ZID had not assumed the LEX approach airspace.
  #63
Old February 1st 07, 03:32 AM posted to rec.aviation.ifr
Steven P. McNicoll
This is from the NTSB ATC Chairman's report about Comair 5191 and
confirmed by the transcript and ATC tape:
"At 0447 (UTC), all LEX tower and radar positions were combined and being
worked from the local control position in the tower cab. In addition to
those functons, the tower controller was responsible for obtaining
releases from the Indianapolis (ZID) Air Route Traffic Control Center
(ARTCC) Traffic Management Unit (TMU), and recording the ATIS broadcast
and all other operational and administrative duties required of a
tower/radar facility."
An IFR tower does not call for an IFR release, it may have to call for a
flow release if the aircraft is going to an applicable destination such as
ORD or ATL.
  #64
Old February 1st 07, 03:34 AM posted to rec.aviation.ifr
A Lieberma
"Steven P. McNicoll" wrote in
hlink.net:
"A Lieberma" wrote in message
8...
FSS gives releases?????
I was always told FSS passes on FSS clearances and you get a ATC
clearance through FSS.
What's an FSS clearance?
FSSs relay ATC clearances to aircraft and they may very well include a
release window.
Then it's an ATC clearance. FSS do not give clearances or releases.
In fact it's required that FSS says ATC clears you, and gives you the CRAFT
which may or may not include a void time.
Allen
  #65
Old February 1st 07, 03:41 AM posted to rec.aviation.ifr
Steven P. McNicoll
My knowledge of how ATC operates is limited, as I am not a controller. I
am a professional pilot and work with TERPs criteria.
Based on the knowledge of flying and TERPS you've displayed in these forums
I find that very hard to believe.
Those two areas are your areas of limited knowledge.
Ya think? What do you base that on?
  #66
Old February 1st 07, 03:50 AM posted to rec.aviation.ifr
Steven P. McNicoll
. 18...
hlink.net:
8...
release window.
CRAFT
FSSs gives clearances and releases to aircraft that they've obtained from
ATC.
Obtain clearance from ATC + give clearance to aircraft = relayed clearance.
  #67
Old February 1st 07, 05:24 AM posted to rec.aviation.ifr
A Lieberma
nk.net:
. 18...
hlink.net:
8...
a release window.
CRAFT
from ATC.
clearance.
Call it whatever you want Steve.
FSS does not ISSUE clearances. They don't give CRAFT assignments. Yes,
they may relay clearances, but they don't issue them.
Please see http://www.faa.gov/ATpubs/ATC/Chp4/atc0402.html 4-2-2 b where
it clearly states ATC clears.
Allen
  #68
Old February 1st 07, 12:00 PM posted to rec.aviation.ifr
Steven P. McNicoll
8...
Nobody said otherwise.
No need, I'm completely familiar with FSS's role.
  #69
Old February 1st 07, 09:37 PM posted to rec.aviation.ifr
Steven P. McNicoll
tape.
You performed a rather poor review. The tower controller did not call the
center for any IFR releases.
  #70
Old February 2nd 07, 03:34 PM posted to rec.aviation.ifr
Sam Spade
Default The Lexington ATC was NOT doing traffic count after he clearedComair 5191 for takeoff
Steven P. McNicoll wrote:
How is 3-1-4 pertinent in this case? Nothing in the transcript suggests the
controller failed to comply with anything you pasted above.
a. Local controllers shall visually scan runways to the maximum extent
possible.
Nearly had my life terminated today Michelle P Piloting 11 September 3rd 05 03:37 AM
Washington DC airspace closing for good? tony roberts Piloting 153 August 11th 05 01:56 AM
Riddle me this, pilots Chip Jones Instrument Flight Rules 137 August 30th 03 05:02 AM
Riddle me this, pilots Chip Jones Piloting 131 August 30th 03 05:02 AM
