F-35 Joint Strike Fighter
Old January 10th 07, 12:14 AM posted to alt.binaries.pictures.aviation
Default F-35 Joint Strike Fighter
Copied from Lockheed site...s'more cheerleadin', interesting tho'
sojourner
"The maturity of this highly integrated aircraft for its second flight is
dazzling - when it's time to fly it is always ready and takes minimal time
to get out of the chocks," said Jon Beesley, F-35 Chief Test Pilot. "The
flight underscores that the Lightning II flies just as our engineers
predicted. This was the first time that we have retracted the landing gear
and the aircraft handling qualities were outstanding. I continue to be
impressed by this marvelous airplane's performance and handling
characteristics."
Approximately 10 minutes into the flight, Beesley retracted the landing gear
and climbed from 15,000 to 20,000 feet to evaluate handling qualities and
engine operation in the cruise mode at Mach 0.6 (~ 450 m.p.h.) and Mach 0.7
(~ 530 m.p.h.). The handling tests included rolls, turns, angle-of-attack
changes and engine throttle changes. The flight lasted 62 minutes and was
executed exactly as planned. It followed the aircraft's successful first
flight on Dec. 15, when the F-35 demonstrated unprecedented engine
performance and handling qualities. The F-35 is a supersonic, multi-role,
5TH Generation stealth fighter designed to replace a wide range of existing
aircraft, including AV-8B Harriers, A-10s, F-16s, F/A-18 Hornets and United
Kingdom Harrier GR.7s and Sea Harriers.
Lockheed Martin is developing the Lightning II with its principal industrial
partners, Northrop Grumman and BAE Systems. Two separate, interchangeable
F-35 engines are under development: the Pratt & Whitney F135 and the GE
Rolls-Royce Fighter Engine Team F136.
"With this successful flight and its broad array of test points, F-35 flight
test has really begun," said Dan Crowley, Lockheed Martin executive vice
president and F-35 program general manager. "The ease of starting and flying
this aircraft is a reflection of the quality of the team who designed and
built it."
The F-35 is a supersonic, multi-role, 5TH Generation stealth fighter
designed to replace a wide range of existing aircraft, including AV-8B
Harriers, A-10s, F-16s, F/A-18 Hornets and United Kingdom Harrier GR.7s and
Sea Harriers.
Click image for larger version
Name:	Lightning II AA-1 2ND Flight010807 (1415 x 940).jpg
Old January 10th 07, 03:20 AM posted to alt.binaries.pictures.aviation
Mitchell Holman Mitchell Holman is offline
Banned
First recorded activity by AviationBanter: Nov 2006
wrote in :
sojourner
and Sea Harriers.
Which raises the question, who is it supposed to be
used against?
Banned
wrote in :
sojourner
and Sea Harriers.
used against?
Old January 10th 07, 03:56 AM posted to alt.binaries.pictures.aviation
Alan Erskine
"Mitchell Holman" wrote in message
wrote in :
sojourner
and Sea Harriers.
used against?
Anyone who is currently faced with AV-8B Harriers, A-10s, F-16s, F/A-18
Hornets and United Kingdom Harrier GR.7s and Sea Harriers.
Personally, I wouldn't replace the A-10 with the F-35 - it's the wrong
aircraft all the way - too fast; too 'fragile'; payload's too small etc.
Only aircraft to replace the A-10 would be a two-seat A-10.
Alan Erskine
Alan Erskine
wrote in :
sojourner
and Sea Harriers.
used against?
Alan Erskine
Old January 10th 07, 04:11 AM posted to alt.binaries.pictures.aviation
miket6065
I think that they are planning on using the new small diameter bombs for
ground support. Certainly no plane can carry that massive GAU8 rotary
cannon. But with the radar and computers of the JSF it can easily ID
several targets and program a single SDB against each.
miket6065
Old January 10th 07, 05:08 AM posted to alt.binaries.pictures.aviation
Alan Erskine
"miket6065" wrote in message
. net...
Not at the speed it will be travelling at. It will cover the battlefield in
half the time of the A-10; that's a major problem.
And don't forget battle damage; no aircraft flying can absorb the amount of
damage an A-10 can survive.
Alan Erskine
Alan Erskine
. net...
Alan Erskine
Old January 10th 07, 09:43 AM posted to alt.binaries.pictures.aviation
Korben Dallas[_1_]
amount of
Something that can be said about Su-25. Except that in case of Su-25
there's more combat-based evidence that supports that statement.
F-35 Joint Strike Fighter No Name Aviation Photos 0 January 10th 07 12:11 AM
CRS VIEWS THE JOINT STRIKE FIGHTER Mike Naval Aviation 13 June 10th 06 01:37 AM
Joint Strike Fighter under attack on Capitol Hill Henry J Cobb Military Aviation 2 March 27th 04 09:07 PM
Joint Strike Fighter focus sparks concern Otis Willie Military Aviation 0 March 19th 04 10:19 PM
