Hi Ted.
It's important that: 1. You use the same method for calculating distances (there's two ways to do that according to SC03, you can change that in Tools Options General Distance calculation) 2. Make sure that the start and finish cylinders are defined in the same way in WinScore and SeeYou (particularly the "Move Origin" checkbox for the start sector where you can define whether or not the distance starts in the middle of the sector or on its perimeter) If you need more help - please don't hesitate to use our support forum as well: http://www.naviter.si/component/opti...mf/Itemid,158/ Regards, Andrej Kolar -- glider pilots use http://www.SeeYou.si Tuno je napisal: Can anyone give me a clue on the task settings to use in SeeYou to make it give me the same speed and distance scores that WinScore gives for USA Regional contests? I've tried everything but I cannot get SeeYou and WinScore to agree on the distance. And I doubt the speed will match until the distance does. Anyone hacked this out yet? ~ted/2NO |
| Thread Tools | |
| Display Modes | |
| Seeyou NMEA to Winpilot/Seeyou | Jean | Soaring | 4 | June 3rd 06 12:38 PM |
| New DMSt task: 4 TPs | Klaus T. | Soaring | 0 | January 9th 06 01:03 AM |
| 1000k comp task | Mel Dawson | Soaring | 0 | July 5th 05 09:22 PM |
| SeeYou to LX7000 Waypoint Task Files | Ken Kochanski (KK) | Soaring | 1 | May 28th 05 01:22 AM |
| New Task | JJ Sinclair | Soaring | 5 | October 23rd 03 02:36 AM |
