![]() To enable the original recon machine loaded with fuel to outrun enemy fighters at 461 mph. But at least the Ar-234 has one small claim to fame. In March 1945 B-2s repeatedly hit the Remagen bridge with 2,000 lb bombs until it finally collapsed. The Germans had tried everything from frogmen to V-2s to collapse the bridge but failed until the Arados did the job. Bob, The Ar 234s never hit the Remagen Bridge, although they attacked it on a number of occasions. They sure as shootin' couldn't carry 2,000# (or more tp the point, 1,000 lg/2200# bombs.) - there just wasn't enough clearance between the racks & the ground. The Ar 234 wasn't a very big airplane - it's about 2/3 the size of a P-38 or Me 110. FYI, from 3/7-3/17/45 Ar 234B-2s from III/KG 76 hit the bridge several times using the "Egon" blind bombing system in horizontal attacks from 16-26,000 ft. Their cumulative attacks weakened the bridge to the extent that it finally collapsed 10 days after its capture. Some Fw-190s and a few Me-262s from KG 51 also targeted the bridge but failed to hit it. The Arados, however, did repeatedly. A total of fifty-five Ar 234B-2s attacked the bridge over a 10 day span with a loss of 5 aircraft. Heavywieght 234s could cary 3 500 kg/1100# bombs, one under each nacelle, and one semi-recesses under the fuselage, but I've seen no credible evidence that they were ever used on operations. The Ar-234B-2s of III/KG 76 used both the 500 kg bombs and the single PC 1400. Rob |
GPT (Gulfport MS) ILS 14 question | A Lieberman | Instrument Flight Rules | 18 | January 30th 05 04:51 PM |
VOR/DME Approach Question | Chip Jones | Instrument Flight Rules | 47 | August 29th 04 05:03 AM |
A question on Airworthiness Inspection | Dave S | Home Built | 1 | August 10th 04 05:07 AM |
Tecumseh Engine Mounting Question | jlauer | Home Built | 7 | November 16th 03 01:51 AM |
Question about Question 4488 | [email protected] | Instrument Flight Rules | 3 | October 27th 03 01:26 AM |
