ATC Handling of Low-Fuel American Flight
Old February 27th 07, 11:56 AM posted to rec.aviation.ifr
Steven P. McNicoll
Default ATC Handling of Low-Fuel American Flight
"Sam Spade" wrote in message
news
That is difficult to say. Perhaps he was sufficently higher passing Love
that it would have taken more time to land there.
An example I am familar with is passing Ontario Airport on the way into
Los Angeles. You are usually at 14,000 feet passing Ontario and on a fuel
efficent profile to land at LAX. That is a judgment call that can go
either way.
I wouldn't second guess his decision to stick with a company airport that
may have been on the best fuel-efficient descent profile.
It is part of the review that I am sure was conducted about his decisions.
Nonetheless, at the time, that decision was not for anyone in ATC to
question. Only after the fact was it reasonable to determine what, in
fact, were the nearest suitable airports.
DAL would have been only about 4 miles closer that DFW, but DFW has about
4600' more runway.
  #152
Old February 27th 07, 12:55 PM posted to rec.aviation.ifr
Matt Whiting
Jim Carter wrote:
If the aircrew "needed to get on the ground right away", why did they
overfly other suitable airports? That action alone could have suggested to
ATC that this wasn't that big an issue. Love Field has equipment to deal
with air carrier class aircraft and they flew right past it even after being
asked about landing there.
I don't know. It isn't relevant to what happened. During a declared
emergency the PIC gets what he or she needs. The questions come later.
That didn't happen in this case and that is all that matters.
Matt
  #153
Old February 27th 07, 03:00 PM posted to rec.aviation.ifr
Matt Barrow[_3_]
"Jim Carter" wrote in message
t...
being asked about landing there.
Between Tulsa and DFW, which airports would those be?
Matt Barrow
Performance Homes, LLC
Colorado Springs, CO
  #154
Old February 27th 07, 06:09 PM posted to rec.aviation.ifr
Sam Spade
Mxsmanic wrote:
Sam Spade writes:
Not me. I did most of my training and check rides in *real* flight
simulators.
Same thing. Another artificial distinction being made.
Please explain the artificial distinction?
  #155
Old February 27th 07, 06:11 PM posted to rec.aviation.ifr
Sam Spade
Jim Macklin wrote:
The FAA has a simulator for ATC training at OKC, they can
simulate traffic and weather to reproduce any condition at
any airport.
As they have a simulator at OKC to model and simulate TERPs criteria.
These types of simulators are carefully crafted, then certified in
accordance with professional protocols before they are used for
in-service purposes.
Bill Gates does not exactly do that for his PC game. ~
  #156
Old February 27th 07, 10:03 PM posted to rec.aviation.ifr
Mxsmanic
Sam Spade writes:
Real flight vs. simulation. Now "real" simulation vs. "unreal" (?)
simulation.
The real distinction, of course, is between "whatever Mxsmanic does" and
"whatever I do," so it's a bit of a moving target.
  #157
Old February 27th 07, 10:05 PM posted to rec.aviation.ifr
Mxsmanic
Sam Spade writes:
The main difference is certification, and certification is arbitrary.
MSFS is not certified for most uses because there's no market for it, it would
impose arbitrary and not necessarily useful or desirable constraints on the
product, and it would multiply the price by at least a factor of ten.
Certification doesn't mean realism, utility, or completeness. It just means
certification.
  #158
Old February 27th 07, 11:13 PM posted to rec.aviation.ifr
Sam Spade
Mxsmanic wrote:
Sam Spade writes:
certification.
O-kay
  #159
Old February 28th 07, 03:35 AM posted to rec.aviation.ifr
Sam Spade
Mxsmanic wrote:
Sam Spade writes:
simulation.
You have created your own "prison."
A $11 million Level D flight simulator is sufficently faithful to the
actual aircraft that no aircraft time is required to train and acquire a
type rating or conduct periodic training to maintain qualifications.
Level D has high-level visual simulation of good and minimum visibility
conditions, and so forth.
You seem to keep insisting that MSFS does good enough to be considered a
simulator not unlike a CERTIFIED Level D simulator.
Perhaps I am overstating your position in that respect.
Nonetheless, you insist in proclaiming MSFS as a faithful flight
simulator on some level, which is absolutely NOT! I have previously
provided you with fatal issues with MSFS, which, as I recall you stated,
"I will check those out." Of course, that meant you did not accept my
claims and, according to your form, you did not bother to report your
findings in the group.
  #160
Old February 28th 07, 04:07 AM posted to rec.aviation.ifr
Mxsmanic
Sam Spade writes:
As soon as I have $11 million, I'm going to get me one of those.
It all depends on what type of simulation you want.
And certification does not equate to realism, it just equates to ...
certification.
You are.
It absolutely is. It depends on the level you choose.
Why such hostility towards PC simulators, I wonder? Something tells me that
no matter how good they get, someone will always find a reason why they aren't
"good enough." I've been using them for a long time, and they've come a long
way.
I just finished a nice little trip from Phoenix to Payson, which taught me
that I'm not very good at recognizing landmarks, even in areas I know well. I
guess I'll have to practice that more. I know how to use all the fancy
navigation stuff, but I'm rather awkward when I have only a VOR/DME to guide
me (plus visual information).
Handling Characteristics of the Flight Design CTSW John Piloting 9 March 14th 07 04:38 AM
American Flight 191 - Recovery Procedure Rick Umali Piloting 17 November 5th 06 04:35 AM
Angel Flight fuel discounts John Doe Piloting 4 January 20th 06 02:24 PM
Passenger attempts to hijack American Eagles flight C J Campbell Piloting 5 January 11th 04 05:04 PM
American Safety Flight Systems seat belts -- Help! Paul Millner Owning 1 July 7th 03 11:10 PM
