Back in the air.
Old March 4th 07, 10:35 AM posted to rec.aviation.piloting
Oz Lander[_2_]
Default Back in the air.
Well, it's almost 2 months since I last flew, due to maintenance issues
and a holiday interstate.
I had a lesson today, and was feeling fairly confident that I hadn't
become too rusty, due to constant visualisation and going over stuff in
my head. I was slightly nervous about the a/c as it's wings were only
reattached yesterday, and the prop had also been removed for
re-dressing. I was a little surprised at the prop, because I had
expected the resin leading edge inserts to have been replaced, but they
weren't. They had just re-coated the prop itself with that varnish
stuff, whatever they call it! :-)
We started the a/c, after a couple of tries with and without choke. She
was running very rough, and didn't sound right at all. I shut her dwn
again, and tried again to start it. This time all sounded and felt just
right. Must have just been too much fuel in the previous attempts to
start it.
Taxiied and took off. Pulling back the throttle to begin decent for the
first touch and go delivered another nervous moment. A fairly strong,
unusual vibration was felt. As we were not on the ground, my mouth
instantly did an impression of a cats bum, and gauges were frantically
checked. My instructor suggested that the prop may not be 100% balanced
properly after being re-dressed. Turned out that must have been
correct, as it did it every time we throttled back, and caused no ill
effects other than the unusual vibration.
We did 2 touch and goes and a full stop with the instructor with me,
and then I did 5 touch and goes and a full stop on my own. One of my
aproaches was a little high, so I thought it was the perfect
opportunity to have a go at a side slip. I'd been shown how twice, done
it once with assistance, and done it once or maybe twice without
assistance. Well, I gave myself a little bit of a scare, as it didn't
go quite to plan. Discussions with my instructor once on the ground
revealed that I simply didn't have quite enough rudder applied, but I
was applauded for trying to practice it. I was't happy with any of my
approaches, most of them were too low, and I needed to apply power to
get back on the correct glide slope, and a couple of the landings were
a bit ordinary too, however I did have a bit of a last minute crosswind
to contend with on the last few approaches from about 300 feet and
below. I', now at 1.3hrs solo, and need 3 hours solo before we move on
to the next section of the syllabus.
I'm booked in again for next Saturday morning, so we'll try and whittle
away that time then.
Oz Lander.
I'm not always right,
But I'm never wrong.
Old March 4th 07, 12:29 PM posted to rec.aviation.piloting
Not4wood
Sounds good there CL.
Not4wood
"Oz Lander" wrote in message
start it.
Oz Lander.
Old March 4th 07, 02:58 PM posted to rec.aviation.piloting
Jay Honeck
Oz, I'm trying not to read too much into this, but it seems to me that
you and your instructor should have landed the plane after
experiencing a "fairly strong, unusual vibration".
I've found that "strong, unusual vibrations" usually lead to bad
things happening in airplanes.
Otherwise, glad you're back in the air!
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old March 4th 07, 07:38 PM posted to rec.aviation.piloting
Shirl
Congrats at getting back up. Glad the "vibration" didn't lead to
anything more, but after two unrelated, back-to-back engine problems,
I'm with Jay about making assumptions re the cause while in the air.
Quick comment: a "side slip" is for crosswind correction (lowered wing
into the wind w/rudder to keep the longitudinal axis of the plane lined
up with the runway;a "forward slip" is for losing excess altitude (wing
low w/opposite rudder so as to descend in line with the runway but with
the longitudinal axis exposed to the oncoming air to produce more drag
for descent). It *does* seem like they were named incorrectly.
Old March 4th 07, 11:30 PM posted to rec.aviation.piloting
Crash Lander[_1_]
"Jay Honeck" wrote in message
Jay Honeck
Hi Jay,
It should be noted, that ANY unusual vibration to me, a student pilot with
only 10.3 hours, is fairly strong. ;-)
My instructor didn't seem phased by it, and I'm sure she would not have let
me go if she was concerned about it, but I do understand your comment.
Crash Lander
Old March 4th 07, 11:32 PM posted to rec.aviation.piloting
Crash Lander[_1_]
"Shirl" wrote in message
My bad! I meant forward slip. We've only learned the one so far. I didn't
know there was a difference, as we haven't covered the other type yet. I now
look forward to learning all about 'side slipping'! ;-)
Crash Lander
Old March 5th 07, 05:06 AM posted to rec.aviation.piloting
Jose
There is no difference.
It =seems= like there is a difference, only because the perspective of
what you want to accomplish is different. However, as far as the way
the airplane goes through the air is concerned, they are completely
identical. The only difference is the way you think of the airplanes
motion with respect to the ground.
The airplane doesn't care about the ground though.
Jose
Humans are pack animals. Above all things, they have a deep need to
follow something, be it a leader, a creed, or a mob. Whosoever fully
understands this holds the world in his hands.
Old March 5th 07, 05:22 AM posted to rec.aviation.piloting
Crash Lander[_1_]
"Jose" wrote in message
what you want to accomplish is different. However, as far as the way the
airplane goes through the air is concerned, they are completely identical.
The only difference is the way you think of the airplanes motion with
Aha! Now I understand. Thankyou.
Oz/Crash Lander
Old March 5th 07, 08:09 AM posted to rec.aviation.piloting
Shirl
Jose wrote:
[re side slip vs. forward slip]
The difference is that when the longitudinal axis of the airplane is not
lined up with the runway centerline (forward slip), there is much more
drag. If you're too high, a side slip doesn't help you lose excess
altitude as effectively as a forward slip. If you're doing an emergency
landing off field, landing on a short strip, or landing with a
crosswind, the difference between the two slips can be quite significant.
Old March 5th 07, 02:20 PM posted to rec.aviation.piloting
Jose
drag.
This is true of a side slip too. I suppose if you want to lose
altitude, you cross your controls more, but again, the =airplane=
doesn't see the runway, so the =airplane= can't tell the difference.
It's just cross controlled.
The only difference between the two slips is what you are looking at out
the window.
Jose
Hey, all I am back for a bit. NW_Pilot Piloting 10 December 11th 06 01:22 AM
How to back out FPL changes on GNX-480? Roy Smith Instrument Flight Rules 13 September 30th 06 12:00 PM
I am back [email protected] Home Built 15 April 22nd 06 09:15 AM
I take it all back Jay Honeck Piloting 9 January 19th 05 02:33 AM
they took me back in time and the nsa or japan wired my head and now they know the idea came from me so if your back in time and wounder what happen they change tim liverance history for good. I work at rts wright industries and it a time travel trap tim liverance Military Aviation 0 August 18th 03 01:18 AM
