Residue under fuselage from breather?
Old March 12th 07, 01:16 AM posted to rec.aviation.owning
Sweendawg
Default Residue under fuselage from breather?
I own a 2004 DA40 (my first plane) and on the left side under the
engine is a breather tube and some sort of overflow line for oil. I
noticed pushing the plane in yesterday that there is a sooty residue
under the airplane, only on the left side. I went an looked at another
DA40 of the same year and maybe a little less flown and didn't see
nearly as much of the blackish soot underneath.
I've got two questions:
1) Is this normal?
2) What may have caused it?
I've been flying in the last six weeks cold weather, and Diamond
suggests runing for five minutes after start at 1500 RMP, however I
usually lean it back about an inch (of travel on the lean lever) after
it starts, and during taxi to the run-up area. I had the oil changed
about 40 horus ago and am runnnig winter rated AeroShell.
Anyone have any thougths?
Old March 12th 07, 05:41 AM posted to rec.aviation.owning
karl gruber[_1_]
Oil out the breather is normal. The reason you didn't see it on the other
airplane is because they keep it clean.
Karl
"Sweendawg" wrote in message
1) Is this normal?
Old March 12th 07, 08:56 PM posted to rec.aviation.owning
dlevy
I wish my first plane was a DA-40...... better yet, a DA-50.
snip
Old March 14th 07, 12:48 AM posted to rec.aviation.owning
Steve - KDMW
1) Is this normal?
You can keep the oil staining to a minimum by not topping off the
sump. By FAA reg, engines must perform normally in all attitiudes and
at all altitudes with the sump half empty. I keep my plane half full
plus 1 quart and my belly stays nice and clean.
Mike Busch made the same point in an Avweb article a while back.
Breather Tube Size For IO-540? Scott Rodriguez Home Built 1 May 5th 06 01:06 PM
Looking for a fuselage Jay Honeck Home Built 79 March 7th 05 02:42 PM
Looking for a fuselage Jay Honeck Aviation Marketplace 72 March 7th 05 02:42 PM
Looking for a fuselage Jay Honeck Piloting 74 March 7th 05 02:42 PM
Auto Fuel Residue Stu Gotts Restoration 4 May 12th 04 09:52 PM
