Roger writes:
The only thing I found was slightly different. "These corrections messages are then broadcast to receivers onboard the aircraft using the frequency as the GPS". It said nothing about being broadcast through communications satellites, or I missed it. As I recall, the WAAS correction data are broadcast over large areas by relaying them through communication satellites. However, these communication satellites are not part of the GPS system, and they are not GPS satellites. IF correction messages can be sent from local areas back to satellites that would make they very vulnerable to tampering with the data. Yes. But the satellites in question are not part of GPS, fortunately. It _is_ a bit unfortunate that WAAS is using the same frequencies to create pseudosatellites, which is essentially spoofing GPS, and it's not a good idea to have spoofing technology in such widespread use, no matter what the justification. -- Transpose mxsmanic and gmail to reach me by e-mail. |
Mxsmanic wrote:
It _is_ a bit unfortunate that WAAS is using the same frequencies to create pseudosatellites, which is essentially spoofing GPS, and it's not a good idea to have spoofing technology in such widespread use, no matter what the justification. WAAS does not use pseudolites. It merely uses the L1 frequency to transmit the WAAS data. |
New transponder mode S vs. mode C | Tom N. | Soaring | 39 | November 7th 06 07:40 AM |
Mode S to become requirement? | Bob Chilcoat | Owning | 6 | July 14th 04 11:25 PM |
Zinni: The nail in the neocon coffin | Garamondextended | Military Aviation | 1 | May 25th 04 07:47 AM |
Got a nail biter you want to share? | pdxflyer | Piloting | 0 | January 8th 04 07:28 AM |
VNE and the "coffin corner"? | Jim | Soaring | 13 | December 17th 03 06:07 AM |
