On Mar 28, 4:35 pm, Alphonse Le Creur wrote:
"BobR" wrote roups.com: On Mar 28, 12:40 pm, Alphonse Le Creur wrote: "BobR" wrote in news:1175092590.355514.234030 @y80g2000hsf.googlegroups.com: On Mar 28, 8:51 am, Nathan Young wrote: I have a Cherokee 180, with the short hershey bar wing. While I love the plane, I always wish it could go a bit faster, or use a bit less fuel to get to my destination. I have followed the composite homebuilding movement for many years, and am amazed at the sleekness of a composite wing. The wings on most composites tend to be the complete opposite of a Hersey bar wing: high aspect ratio, low thickness, no rivets, no screws for fuel tanks,smooth curves faired into airframe, and streamlined landing gear structure. So my question: How much drag does a wing on a Hersey Bar Cherokee generate, and and hypothetically speaking, how much faster could the plane go if it was retooled with a sleek, composite wing? I can't remember if it was Kitplanes or SportAviation that had a recent article on a Piper knockoff being produced as a kitplane in South Africa. That might be a good starting point for the difference in performance between the different planes as well as a discussion of the differences in design and construction. Much of the difference has to do with better airfoil designs being used but also weight differences. Well, that airplane is "inspired" by the Commanche and it's really just comparing apples and oranges since there are so many other differences in the two airplanes, but having said that, it's better than comparing a cherokee to a Cozy, for instance.. In any case, the Ravin Commanche is herehttp://www.saravin.com/review.htm ALC- Hide quoted text - - Show quoted text - It's about as close a comparison as can be made. I am building the KIS Cruiser which uses a hershey bar style wing as well but the airfoil is different. The comparison from a performance standpoint is much faster than the Commanche for the same power (180 hp). The difference must be attributed to several differences beyond just the wing, weight being the most obvious. Well, the Ravin is actually a couple hundred pounds heavier than the original Commanche empty and has a higher gross. It also has a much smaller fuselage cross section. I'm certainly not saying that the Ravin is not a better airplane. It is. I'd sure like to have one! I'm just saying that while it is probably one of the better comparisons, no absolute conclusion may be made from it. There's too many other things going on there. The Commanche uses what was a then state of the art NACA 6 series laminar flow airfoil. It was streets ahead of what was on any lightplane of the time, but it's use was most probably not dictated by the material of which it was made. I have no idea what the Ravin is using for an airfoil. If Piper were to set out to make the same airplane again today using aluminum for the wing, they could still build a more efficient wing than they did in the fifties by simple virtue of the fact that fifty years later there's been quite a lot of innovation in airfoils, structures and what not. Again, I'm not saying that the Ravin isn't a better airplane, nor am I denying that composites might be a better way to build an airplane, just saying (at the risk of flogging the proverbial dead horse) that the comparison , while it is as good as you're going to get, is still flawed. ALC- Hide quoted text - - Show quoted text - Agreed, you will always be dealing with differences that can skew the comparison including differing prop combinations. Another good comparison might be VANS RV-10 which does use a metal wing. The performance numbers on that plane are also better than the Commanchee. The RV-10 is probably a good comparison to the Ravin since both would probably be about the same weight, size, and use the same engine. The RV-10 with the O-360 combination might be a good comparison to the commanchee. |
| Thread Tools | |
| Display Modes | |
| Hershey bar wing vs composite wing - how much drag? | Nathan Young | Owning | 33 | March 30th 07 08:47 AM |
| High wing to low wing converts...or, visa versa? | Jack Allison | Owning | 99 | January 27th 05 12:10 PM |
| composite wing, wing spars | Dave Schneider | Home Built | 4 | May 21st 04 06:35 AM |
| Fuel Dip Tube for Hershey-bar Wing Cherokees? | Bob Chilcoat | Owning | 3 | May 3rd 04 11:29 PM |
| Mylar tape wing seals - effect on wing performance | Simon Waddell | Soaring | 8 | January 1st 04 04:46 PM |
