Flight Lessons
Old August 12th 03, 01:55 AM
Tarver Engineering
"Tarver Engineering" wrote:
I don't mind if you can learn Mike, but so far, you are just another
dip****.
Coming from you (of all people!) that's incontrovertible proof that
I'm in good company.
You caught the attention of ram's peanut gallery, but insulted the
professionals.
Fluff you are, then.
  #102
Old August 12th 03, 04:23 AM
Tarver Engineering
Speaking of "fluff," you need some fresh bait.
I'm trying to fend you off from the boat with an oar already, lune.
  #103
Old August 12th 03, 06:01 AM
Harry Andreas
In article , "Paul J. Adam"
In message ,
Harry Andreas writes
Of course, if the GPS co-ordinates are wrongly calculated, wrongly
entered, or the GPS battery fails midflight, that's a very lost
formation... with no navigators to rescue them.
Military aircraft GPS use aircraft power with transient backup, not
batteries.
Assuming a fully integrated GPS, rather than a civilian handheld
attached to the glareshield as an Urgent Operational Requirement
solution pending the procurement of the fully integrated navigation
upgrade.
Life is rarely as perfect as you'd like.
Yet airborne GPS systems have been around for a long time.
check out the MAGR system
http://gps.losangeles.af.mil/user/products/magr2000/
and here is a photo of all the platofrms it's used on
http://gps.losangeles.af.mil/user/pr...0/m-images.htm
the virtual gamut of all first line US aircraft, with the exception of the
F-15C/D/E.
(I wonder why that is?)
Harry Andreas
Engineering raconteur
  #104
Old August 12th 03, 06:05 AM
Tarver Engineering
"Harry Andreas" wrote in message
snip
upgrade.
Adam just keeps getting more clueless.
Here is a nice picture of a PDI designed to be driven from a civilian
FMS/GPS, designed circa 1996.
http://www.skylight-avionics.com/panel1s.jpg
  #105
Old August 12th 03, 08:04 AM
Keep trying. You haven't drawn any high-intensity flames yet...
-Mike (having a slap fighting contest against a man w/no arms) Marron
  #106
Old August 12th 03, 08:05 AM
Michael Williamson
F-15C/D/E.
Not a single Transport aircraft? Missing every major airlifter,
not to mention the minor airlifters as well.
Mike Williamson
  #107
Old August 12th 03, 11:59 AM
Cub Driver
as long as the GPS is working. But it's a low-powered signal from orbit
and it's easily jammed.
How true is this, really? In an aircraft, you are between the ground
and the satellite. How does someone on the ground interfere with the
signal?
all the best -- Dan Ford
email: www.danford.net/letters.htm#9
see the Warbird's Forum at www.warbirdforum.com
and the Piper Cub Forum at www.pipercubforum.com
  #108
Old August 12th 03, 04:02 PM
Michael Williamson
signal?
I don't believe that the antenna for the GPS is directional enough
that someone off axis couldn't put a signal into your system- after
all, a single antenna is used to pick up every satellite above the
horizon.
Mike Williamson
  #109
Old August 12th 03, 05:11 PM
Michael Williamson
signal?
horizon.
Mike Williamson
While this is true (the receiver antennas need to be and are
omni-directional) the satellites broadcast on ~1.5 gigahertz
therefore are very much 'line-of-sight' so any interference must
be transmitted within 'line-of-sight' to the 'interferee'. IOW,
to block a gps receiver you gotta be relatively close to it when
you're on the ground...if you're inflight then....you know...
-Gord.
  #110
Old August 12th 03, 07:06 PM
Harry Andreas
In article , Michael Williamson
F-15C/D/E.
I only put in a link for one example system, there are many more.
We very recently won a contract to upgrade the entire C-130 fleet.
Harry Andreas
new theory of flight released Sept 2004 Mark Oliver Aerobatics 1 October 5th 04 11:20 PM
Flight Simulator 2004 pro 4CDs, Eurowings 2004, Sea Plane Adventures, Concorde, HONG KONG 2004, World Airlines, other Addons, Sky Ranch, Jumbo 747, Greece 2000 [include El.Venizelos], Polynesia 2000, Real Airports, Private Wings, FLITESTAR V8.5 - JEP vvcd Home Built 0 September 22nd 04 08:16 PM
FAA letter on flight into known icing C J Campbell Instrument Flight Rules 78 December 22nd 03 08:44 PM
Sim time loggable? [email protected] Instrument Flight Rules 12 December 6th 03 08:47 AM
