Near miss from space junk.
  #11
Old April 3rd 07, 06:28 AM posted to rec.aviation.piloting
Maxwell
Default Near miss from space junk.
"Dylan Smith" wrote in message
On 2007-04-02, Maxwell wrote:
If you are planing a flight with so little reserve, which is obviously
considered both legal and acceptable
A one hour reserve is hardly "little reserve". It's quarter of the
duration of a 1960 Cessna 182 (which has relatively small tanks,
especially compared to later models of Cessna 182). A one hour reserve
is double the day VFR minimum requirement.
(My current aircraft carries only 2.5 hours of fuel! Although its fuel
gauge is a much simpler purely mechanical indicator which does work
properly and gives a reasonable indication of fuel remaining.)
gage, and physically _stick_ the tanks on preflight. My personal
experience
with fuel gages has been that they can cause more problems than they
solve,
if you try to rely heavily on them.
So does any instrument if you don't have a cross check. Fuel gauges in
particular ARE the cross check to your preflight visual check, and fuel
burn calculations. If you re-read my message, you'll see in the
particular example I gave that the fuel was visually inspected twice,
and calculations had been performed, and a landing short of the
destination was chosen because the fuel gauge showed less fuel than the
fuel calculations predicted. The error turned out to be in the fuel
level inspection, an easy mistake to make in an unfamiliar aircraft.
The only means of fuel cross check once in flight are the fuel gauges -
you can hardly stick the tanks in flight. Gauges that actually work and
reasonably indicate the fuel level remaining can provide a cross check
which can prevent the following situations:
- lack of experience with a particular aircraft type
- error in fuel burn calculations
- error in engine management (mixture too rich)
- mechanical failure (fuel leak)
- error in preflight (forgetting to do a visual check, or being fooled
because the aircraft was parked on a slope)
...from a normal landing at an airport short of your destination, into a
fuel exhaustion accident. Indeed, some years ago, a poster to this
newsgroup ran out of fuel due to a fuel leak. Perhaps the pilot had been
conditioned to believe that fuel gauges were utterly useless and did not
include them in a cross check, instead relying on a single source of
data (fuel calculations and time in flight).
Cross checks in aviation are a _good thing_. Failing to maintain a
basic instrument that can provide a useful cross check means there's one
less tool at your disposal to prevent an accident.
(In particular, never trust a fuel gauge if it says you have more fuel
than you think you have. However, ALWAYS trust a fuel gauge if it says
you have less fuel than you think you have! Landing to find out why is a
lot cheaper than pressing on, believing your fuel inspection and fuel
burn calculations - only to end up upside down in a field half an hour
later because your fuel was being pumped overboard. How are you going to
detect mechanical problems with the fuel system if the gauge isn't
working? This is why broken fuel gauges should be fixed).
We expect to have to do cross checks for everything else - navigational
cross checks (we never rely on a single source for navigation, whether
this be only using a single road to positively identify a ground feature
instead of the road and two other features), or for our instruments (we
don't just bore holes IFR looking only at the attitude indicator for
attitude information - we scan the other instruments to make sure that
the AI is telling the truth), and we fly approaches not only with the
ILS tuned in, but a timer running, or some other kind of cross check
like a crossing radial.
Why is it therefore deemed not only acceptable but entirely normal
that there is no in-flight fuel cross check in the form of a gauge that
at least gives a reasonable indication of how much fuel you have left?
First of all Dylan, I'm not trying to take issue with you post. Your use of
the fuel reserves are correct and I acknowledged that. I was just trying to
offer you another perspective that I have learned by experience, and thought
you might consider it and perhaps find it useful.
Increasing your reserve for 30 minutes to 1 hour in a 182, especially in an
aircraft you are unfamiliar with, is not a bad idea and will seldom add more
than one fuel stop to even the longest cross country flights. Besides, it's
a good excuse to take a whiz, grab an extra coke, and/or experience a small
airport you wouldn't have gotten to see otherwise. And it is of coarse,
another take off and landing than can make or break your currency
requirements sometimes, depending on how often you get to fly.
You also increase your odds of temporary fuel starvation when you get in the
habit of running your tanks real low, due to things like turbulence or
robust maneuvering. Not usually a problem unless you are held out on turning
base for landing, because some cowboy in a cub thinks he needs a one mile
final, but it does happen.
And your own example of misjudging the fill level on preflight is a great
example of why it's nice to use a stick. I don't find any of the Cessnas
hard to visual, but you will never miss with a stick if the tank design
allows it, and you have a good stick. Especially an error as much as 45
minutes.
Also, fuel leaks and fuel siphoning does obviously does occur, but it's very
rare and usually slight enough you won't be able to detect it in most fuel
gages. They simply are not USUALLY that accurate. I have never personally
seen a leak, and the only siphon issue I have ever seen was someone leaving
the cap loose on a Cessna. And they didn't detect it in the fuel gage, they
heard it banging away on top of the wing. So yes these things do happen, but
I'd bet it's seldom that a fuel gage is what makes or breaks the day.
But at any rate, we could argue _what ifs_ till the cows come home, but that
certainly wasn't my intention. My only point was that in my experience,
which although is less than a lot of the folks here, but it is considerable.
Fuel minimums are just what they say, MINIMUMS. And in my experience they
should be avoided if at all possible, it's just too easy to do. Far too many
GA fatalities are directly attributed to fuel starvation, and it's not
always because the pilot was stupid or fool hardy. It's quite often just
because -**** happens.
So let me leave you with a goofy saying - that with things go to pot, there
are a few things more useless to a pilot than the altitude above him, or the
air in his fuel tanks - and the most unreliable instrument in the cockpit
will always be the fuel gage.
Best wishes,
Max
Why Screeners Miss Guns and Knives (and why pilots miss planes and airports) cjcampbell Piloting 2 January 3rd 06 05:24 AM
Junk Yards NVArt Home Built 5 July 13th 05 08:35 PM
FS Aviation Junk Jim Aviation Marketplace 1 February 11th 05 11:57 PM
Space Junk & GPS Reliability Doug Carter Instrument Flight Rules 9 July 11th 03 02:38 PM
Space Junk & GPS Reliability Dan R Piloting 7 July 11th 03 02:38 PM
