#21
Aircraft using FADEC are relatively recent so why isn't power-loading
prioritized by the electrical system? When an electrical event occurs that overloads the system capacity, why isn't there enough built-in systems intelligence onboard to protect the FADEC? If we have enough smarts to design and build a FADEC why don't we have enough smarts to protect it? -- Jim Carter Rogers, Arkansas |
The message came as a PDF file. I don't think I can post such a file
to the newsgroup, so if you would like to see the file, let me know where to send it. Cary On Apr 23, 1:28 pm, "Neil Gould" wrote: Recently, Cary posted: I just received an e-mail today from Diamond explaining the situation. Since the engines are FADEC controlled, the dead battery did not have enough power to retract the landing gear and keep the engines going. The e-mail also stated that Diamond is looking into making some changes. Cary (DA42 owner) The actual wording of that email would be interesting. I'd think that the FADEC keeps the fuel flow and props configured, and that the current draw of the landing gear motor(s) probably shut the FADEC down due to low voltage. While that could be addressed with a different power configuration (a separate battery for the FADEC, for example), it may also introduce more failure modes and more factors to take into consideration during pre-flight. Neil (NOT a DA42 owner) |
But the point seems to be that even if you had a good electrical system and
a good battery on departure, if a total power failure occurs it appears that FADEC just packs it up and defaults to zero. Like Jim wrote "a damn unhandy failure mode". -- Jim Carter Rogers, Arkansas |
Cary wrote:
The problem, as I understand it, was the battery was dead. According to the POH, the battery is used to start the engine and is used as a backup during flight for all the electronic gear (including the FADEC). Although the investigation is still ongoing and other answers may be forthcoming, when they operated the landing gear they exceded the power available from the alternators and the backup system (the battery) was not available so the FADEC (engine computers) stopped. One of the lessons here is that one should not fly an airplane that relies on electricity if you don't have a battery to run the electricity! Cary On Apr 23, 4:35 pm, wrote: Gig 601XL Builder wrDOTgiaconaATsuddenlink.net wrote: Neil Gould wrote: A simple voltmeter with a "red line" should suffice, along with a caution; "Don't take off with the needle outside the green arc". Of course, that won't prevent someone from insisting on making a bad decision. I again agree but if you are going to have an sytem with FADEC it ought to have the authority to to clearly tell you that it is about to use its' authority to shut the engine off. From the description it sounds more like the FADEC didn't have the authority (or power) to do anything. More to the point, if all the power goes away, what happens to all the "settings" the FADEC controls? Do they go to zero, full, stay where they are? It appears that they go to zero, which is a damn unhandy failure mode. Well, we are all guessing here, but... A battery pack backup for the FADEC itself independant of the aircraft systems would be trivial technically. A bigger problem may be how much power does it take to actually control something with the FADEC? That is, while the FADEC itself probably doesn't require much in the way of power, how much power does it take to manipulate the throttle, mixture, and prop? -- Jim Pennino Remove .spam.sux to reply. |
The message came as a PDF file. I don't think I can post such a file to the newsgroup, so if you would like to see the file, let me know where to send it. No need, at this point. I was mainly curious about whether Diamond addressed the risk of taking off or flying with low voltage? Neil |
"Jim Carter" wrote in message et... Aircraft using FADEC are relatively recent so why isn't power-loading prioritized by the electrical system? When an electrical event occurs that overloads the system capacity, why isn't there enough built-in systems intelligence onboard to protect the FADEC? If we have enough smarts to design and build a FADEC why don't we have enough smarts to protect it? -- Jim Carter Rogers, Arkansas Well said. It should have some fall back. If the coffee maker shorts the engines quit? Al G |
Jim Carter wrote:
Aircraft using FADEC are relatively recent so why isn't power-loading prioritized by the electrical system? When an electrical event occurs that overloads the system capacity, why isn't there enough built-in systems intelligence onboard to protect the FADEC? If we have enough smarts to design and build a FADEC why don't we have enough smarts to protect it? That's really the question, though it wouldn't necessarily have gotten them home safe. Before the FADEC dropped out, there should have been an undervolt alarm and load shedding. Then they could have cranked the gear down if possible. |
#28
"Cary" wrote in message ... The message came as a PDF file. I don't think I can post such a file to the newsgroup, so if you would like to see the file, let me know where to send it. Some pdf readers come with a SELECT TEXT TOOL icon in the tool bar. Switch to this mode and you can copy and paste text in pdf doc like normal. |
#29
Thomas Borchert wrote: Blueskies, Doesn't the 1.7 have a throw away TBO-like limitation that is very low? No. it has a TBR (r for replacement) of 2400 hours, guaranteed by Thielert. When you buy the engine, that price buys you 2400 hours. Can you say that of any Lycosaurus or TCM? yes, they currently do replace the engines sooner than that - but you don't pay for it. They're working up to final TBR. What does it cost the owner at 2400 hours? |
#30
A battery pack backup for the FADEC itself independant of the aircraft systems would be trivial technically. A bigger problem may be how much power does it take to actually control something with the FADEC? That is, while the FADEC itself probably doesn't require much in the way of power, how much power does it take to manipulate the throttle, mixture, and prop? The answers to those kind of questions seem to be missing from the public record, and even the public discussion. I was asking just that when I inquired about any "Limp Home" capability of this fully FADEC system. I'm hoping a Mike Busch media type will attend one of the $4k three day Thielert maintenance seminars down in Texas and write some details. Thielert comes to aviation from the automotive industry's custom engine design and engineering world. And their ability to Design, Produce and STC the 4.0 diesel in a v8 block in a 2 year window shows they got that part of their business down. I just hope the Failure Analysis guys or the second contingency curmudgeons weren't asked to leave the design/production meetings. When those guys are ignored, they often make excellent "reluctant" witnesses for the Plaintiff. As much as I like the Thielert concept (with some healthy concerns), the SMA guys seem to be walking a much different road technology wise. They have designed their turbo diesel as an air cooled horiz opposed mostly mechanical controlled system. When I talked in detail to one of their engineers at SNF two years ago I walked away thinking that their design was pretty bullet proof. But, even though I haven't heard of any tech problems, SMA can't seem to get off the ground. |
| Thread Tools | |
| Display Modes | |
| F6F accident | Larry Cauble | Naval Aviation | 4 | October 14th 05 07:19 PM |
| Accident db? | [email protected] | Owning | 3 | July 25th 05 07:22 PM |
| C-130 accident | Jay Honeck | Piloting | 28 | January 11th 05 07:52 PM |
| MU2 accident | Big John | Piloting | 16 | April 13th 04 04:58 AM |
| KC-135 accident | Big John | Piloting | 3 | November 19th 03 05:36 PM |
