On 2007-04-24 14:47:11 -0700, "Friedrich Ostertag"
said: Neil Gould wrote: Recently, Friedrich Ostertag posted: Karl-Heinz Kuenzel wrote: Hi. Here in Germany we had an accident with a brand new DA 42 in Speyer (EDRY) on 3-4-07 during take off. It seems, that the battery was down and both engine were started with remote power. After take off when retracting the gear, the props feathered and both engines stopped. You can read about that accident in German (sorry) in www.pilotundflugzeug.de First hearing about that accident and the background, I could not believe it. I don't even know where to start. How can an aircraft, that depends on electrical power for the operation of it's engines, be airworthy without fully redundant electrical systems? While in this particular case the pilot might have noticed the problem, had he meticuously follow procedures and started the second engine at the plane's own power, it is quite easy to find failure modes that would go unnoticed inflight, yet cause double engine failure at the instant the gear is lowered on final. Lead batteries are known to occasionally go flat suddenly, once the buildup of oxide makes contact between the lead elements. Happened to me in the car once. The engine (a diesel with mechanical injection pump) ran happily without me even noticing the failure until I shut it down. When I turned the power back on again, not even the lights in the dashboard would light up, it was completely and utterly dead. I would never have thought that they cut corners like that at Diamond. I Hope this will not create a lot of mistrust in aerodiesels, as it is not a diesel issue. I guess you could call it a FADEC issue if you wanted, however it really is an issue of redundancy of essential systems, and easily solveable as such. I have a somewhat different take on this event. It appears to me that the pilot didn't sufficiently understand his aircraft or the implications of the symptoms he observed. Knowing that there was insufficient power to start the engines, that the engine & prop controls were dependent on electric power and that the landing gear used an electric motor would have stopped me from taking off until the battery/electrical system problem was addressed. Well said, and I wouldn't disagree. However, the very same potentially deadly failure could occur anytime the battery fails inflight, with no way for the pilot to know about it before he actually hits the button to lower the gear. No. This was not caused by a battery failure per se. It was a failure of the electrical excitation system which starts the alternators. That should prevent the engine from starting and it did. However, the pilot bypassed that by starting both engines (a big no-no) with external power. The battery is not actually used in-flight to keep the engines running. The alternators are used for that, with a generator backup, and finally a battery for backup, with warning lights all over the place. Once the plane is flying, assuming the alternators start out working, you would practically have to have a major electrical fire to duplicate the problem. But take off without a working alternator and you have a big problem. -- Waddling Eagle World Famous Flight Instructor |
| Thread Tools | |
| Display Modes | |
| F6F accident | Larry Cauble | Naval Aviation | 4 | October 14th 05 07:19 PM |
| Accident db? | [email protected] | Owning | 3 | July 25th 05 07:22 PM |
| C-130 accident | Jay Honeck | Piloting | 28 | January 11th 05 07:52 PM |
| MU2 accident | Big John | Piloting | 16 | April 13th 04 04:58 AM |
| KC-135 accident | Big John | Piloting | 3 | November 19th 03 05:36 PM |
