On May 20, 9:37 am, Bullwinkle wrote:
On 5/20/07 6:24 AM, in article om, "Doug Hoffman" wrote: On May 18, 7:05 am, Dan G wrote: I think it's important to be clear what we're talking about here. A VW Passat TDi station wagon has a combined mpg of 48 and a long-run mpg of 58, with 236lbs/ft of torque at 1,750rpm. The car has a kerbweight of 3,500lbs and using the figure of 85%* of kerbweight to give towing capacity, that allows trailers of up to 3,000lbs to be towed comfortably. The maximum towing capacity is specified by the vehicle manufacturer. The Passat TDi may or may not be rated for up to 3,000lbs. My Neon 2.0L with manual transmission (less than $14,000 new) routinely gave me 33-38 mpg depending on driving cycle. It could easily pull my 15m glider with its 2,000lb towing rating. I wonder how much a Prius is rated for towing? gasoline-elctric hybrids The Prius stickers at around $24,000. The full government rebate is limited to the first 60,000 Prius per model year (about $3,000): http://hybridcars.about.com/od/news/...dtaxcredit.htm If I miss out on the full government rebate then I would pay up to $10,000 more than the Neon to drive a vehicle which I doubt will tow my glider. Let's not even consider the extra cost for maintenance and repairs or battery replacement costs. For $10,000 I can drive my conventional technology Neon over 87,000 miles, assuming gasoline is $4/gal and 35mpg. And still tow my glider most places (albeit less than 35mpg while towing). Btw, I think vehicles like the Prius are great. But they are no silver bullet (I know you didn't claim they were). (Going a bit further OT): If we truly believe what Al Gore is saying, then we would all immediately stop using anything that creates CO2 and other greenhouse gases (I guess we should still allow ourselves to breath as our bodies do create CO2 and water vapor, both GHGs). Park all cars and trucks permanently. Ground all airplanes and so forth. As far as inconvenience to daily life, so what? We are talking about saving the planet, right (at least according to Gore and some others)? Maybe even if Gore believed what he is saying he would stop living in a huge house that consumes many times the energy of the average US house. Or is that four houses he owns? Regards, -Doug Apologize if I missed this elsewhere in the thread, but FYI the Prius is prohibited from towing, per the owner's manual. The Highlander Hybrid is OK for towing, per its owner's manual. Regards, Bullwinkle Actually the biggest advantage of the hybrids (for towing) is that the electric drive gets its best torque at 0 rpm. This allows you to get a good start without overtaxing your engine or transmission. This also improves the highway mileage because a smaller gas engine can power the car -- most of the power in a conventional car is used for low speed torque and power, and only around 15% is needed for maintaining your highway speed. The hybrids wind up wearing much more slowly as a result. When I did my first oil change at 5K miles on mine the oil looked unused. I've also seen picture of the brake pads on a hybrid that showed no wear after 110K miles, since most of the braking effort comes from electrical generation. The brake pads only get used once your speed drops to around 6mph or less. |
| Thread Tools | |
| Display Modes | |
| Flying Cars | bryan chaisone | Home Built | 2 | September 10th 04 08:01 PM |
| Flying Cars | bryan chaisone | Rotorcraft | 0 | September 10th 04 02:57 PM |
| Air cars ? | Felger Carbon | Home Built | 9 | January 3rd 04 08:41 AM |
| Air cars will never fly (911 more reasons) | [email protected] | Piloting | 36 | October 4th 03 04:26 PM |
| (was) Air cars will never fly (911 more reasons) | Montblack | Owning | 6 | September 29th 03 09:56 PM |
