Billy Beck wrote in message . ..
"The Raven" wrote: Try living in a motel at the end of a SAC runway (for 3 months). Triple buff takeoffs at 5am, full noise, about 200ft over your head. By November of 1972, Barksdale was *too quiet* for me to sleep. That was very wierd. Billy http://www.two--four.net/weblog.php Read recently (in an article I cannot now find) about an airplane designed and built in the '60s or '70s that had a turbojet engine in the tail and a huge turboprop in the nose. Supposed to be a fighter or fighter-bomber. Only two were built, and after one flight the test pilots didn't want to fly them any more. They were LOUD in the cockpit or anywhere else. It hurt bad. Very few test flights were carried out. I imagine they were designed to defeat the enemy through intimidation alone. Apparently most of the noise came from the prop tips, which were running supersonic or transonic, even in static runups. One of the pilots lived ten miles from the airbase, and he could hear the techs running it up, on the ground, all the way from his home. That has to be pretty bad. Anyone here remember what it was? Dan |
"Dan Thomas" wrote in message Read recently (in an article I cannot now find) about an airplane designed and built in the '60s or '70s that had a turbojet engine in the tail and a huge turboprop in the nose. Supposed to be a fighter or fighter-bomber. Only two were built, and after one flight the test pilots didn't want to fly them any more. They were LOUD in the cockpit or anywhere else. It hurt bad. Very few test flights were carried out. I imagine they were designed to defeat the enemy through intimidation alone. Apparently most of the noise came from the prop tips, which were running supersonic or transonic, even in static runups. One of the pilots lived ten miles from the airbase, and he could hear the techs running it up, on the ground, all the way from his home. That has to be pretty bad. Anyone here remember what it was? Dan You may have read about it in "Air and Space Magazine", if I remember correctly. Not exactly sure if this is the aircraft in question but would almost bet money on it. According to a senior curator I met at the Air Force Museum when it was tested there it was painful to be anywhere near. http://www.wpafb.af.mil/museum/resea...hter/f84sp.htm Tex |
"Tex Houston" wrote in message ...
"Dan Thomas" wrote in message Read recently (in an article I cannot now find) about an airplane designed and built in the '60s or '70s that had a turbojet engine in the tail and a huge turboprop in the nose. Supposed to be a fighter or fighter-bomber. Only two were built, and after one flight the test pilots didn't want to fly them any more. They were LOUD in the cockpit or anywhere else. It hurt bad. Very few test flights were carried out. I imagine they were designed to defeat the enemy through intimidation alone. Apparently most of the noise came from the prop tips, which were running supersonic or transonic, even in static runups. One of the pilots lived ten miles from the airbase, and he could hear the techs running it up, on the ground, all the way from his home. That has to be pretty bad. Anyone here remember what it was? Dan You may have read about it in "Air and Space Magazine", if I remember correctly. Not exactly sure if this is the aircraft in question but would almost bet money on it. According to a senior curator I met at the Air Force Museum when it was tested there it was painful to be anywhere near. http://www.wpafb.af.mil/museum/resea...hter/f84sp.htm Tex That's the one. Thanks! Dan |
In article , Tex Houston
writes "Dan Thomas" wrote in message Read recently (in an article I cannot now find) about an airplane designed and built in the '60s or '70s that had a turbojet engine in the tail and a huge turboprop in the nose. Supposed to be a fighter or fighter-bomber. Only two were built, and after one flight the test pilots didn't want to fly them any more. They were LOUD in the cockpit or anywhere else. It hurt bad. Very few test flights were carried out. I imagine they were designed to defeat the enemy through intimidation alone. Apparently most of the noise came from the prop tips, which were running supersonic or transonic, even in static runups. One of the pilots lived ten miles from the airbase, and he could hear the techs running it up, on the ground, all the way from his home. That has to be pretty bad. Anyone here remember what it was? Dan You may have read about it in "Air and Space Magazine", if I remember correctly. Not exactly sure if this is the aircraft in question but would almost bet money on it. According to a senior curator I met at the Air Force Museum when it was tested there it was painful to be anywhere near. http://www.wpafb.af.mil/museum/resea...hter/f84sp.htm Tex ISTR it was nicknamed "Thunderscreech" because of its awful noise, and caused pain and severe nausea to ground personnel in the vicinity when the prop was turning. -- Peter Ying tong iddle-i po! |
Peter Twydell wrote: In article , Tex Houston writes You may have read about it in "Air and Space Magazine", if I remember correctly. Not exactly sure if this is the aircraft in question but would almost bet money on it. According to a senior curator I met at the Air Force Museum when it was tested there it was painful to be anywhere near. http://www.wpafb.af.mil/museum/resea...hter/f84sp.htm ISTR it was nicknamed "Thunderscreech" because of its awful noise, and caused pain and severe nausea to ground personnel in the vicinity when the prop was turning. I'd put an F-106 at takeoff up against almost anything. It was pretty loud in general, but there were some godawful high harmonics in there that made you feel like someone was ripping giant sheets of canvas *in* your chest. When I worked F-4s, we had an ANG F-106 alert unit sitting at the end of one runway, and when they took off, we'd go into the EOR shack and hide for extra protection - after standing 100 feet away from multiple F-4 launches on full afterburner all day... -- Remember: Objects in rearview mirror may be hallucinations. Slam on brakes accordingly. |
om... Read recently (in an article I cannot now find) about an airplane designed and built in the '60s or '70s that had a turbojet engine in the tail and a huge turboprop in the nose. Supposed to be a fighter or fighter-bomber. Only two were built, and after one flight the test pilots didn't want to fly them any more. They were LOUD in the cockpit or anywhere else. It hurt bad. Very few test flights were carried out. I imagine they were designed to defeat the enemy through intimidation alone. Apparently most of the noise came from the prop tips, which were running supersonic or transonic, even in static runups. One of the pilots lived ten miles from the airbase, and he could hear the techs running it up, on the ground, all the way from his home. That has to be pretty bad. Anyone here remember what it was? Dan IIRC, the Ryan "Fireball" was a prop up front and a jet out the rear... But, I think it was built before the 60's/70's time frame... FWIW... |
| Thread Tools | |
| Display Modes | |
