Myth: 1 G barrel rolls are impossible.
Old June 12th 07, 02:16 AM posted to rec.aviation.piloting
Bertie the Bunyip[_2_]
Default Myth: 1 G barrel rolls are impossible.
"Maxwell" wrote in
"Bob Moore" wrote in message
46.128...
My name is Bob Moore :-)
Just what is a barrel roll has been debated between "Big John",
Dudley, and myself at least twice in the past. It IS difficult to
describe without having a model airplane in one's hand and flying it
through the maneuver.
How come you don't seem to belive the following from Wikipedia?
Barrel roll
From Wikipedia, the free encyclopedia
This article is about the aerial sport. For the military operation,
see Operation Barrel Roll.
A barrel roll occurs when an object (usually an airplane or roller
coaster)
makes a complete rotation on its longitudinal axis while following a
helical path, approximately maintaining its original direction. The G
load is kept positive (but not constant) on the aircraft throughout
the maneuver, commonly not more than 2-3 G.
In aviation, the maneuver includes a constant variation of attitude
in all three axes, and at the midpoint (top) of the roll, the
aircraft is flying inverted, with the nose pointing at a 90-degree
angle ("sideways") to the general path of flight. The term "barrel
roll" is frequently used, incorrectly, to refer to any roll by an
airplane (see aileron roll), or to a helical roll in which the nose
remains pointed generally along the flight
path. In fact, the barrel roll is a specific and difficult maneuver;
a combination of a roll and a loop. It is not used in aerobatic
competition.
http://acro.harvard.edu
The Barrel Roll is a not competition maneuver. The barrel roll is a
combination between
a loop and a roll. You complete one loop while completing one roll at
the same time.
The flight path during a barrel roll has the shape of a horizontal
cork screw. Imagine a big
barrel, with the airplanes wheels rolling along the inside of the
barrel in
a cork screw path.
During a barrel roll, the pilot experiences always positive G's. The
maximum is about 2.5 to
3 G, the minimum about 0.5 G.
Then would you label the roll that Jim has described here as a form of
aileron roll, instead of a barrel roll? Or do you think it is
possible to do a 1g aileron roll?
It's less of a roll than it is a loop.
In fact, that's how I used to teach it. Get a hula hoop, cut it and pull
the ends apart. you are now looking at the path of a barrel roll. A
skewed loop
Bertie
Dispelling the Myth: Hillary Clinton and the Purple Heart Otis Willie Naval Aviation 0 February 21st 06 06:41 AM
Impossible to ditch in a field (almost) mindenpilot Piloting 29 December 12th 04 12:45 AM
bush: impossible to be AWOL (do vets give a sh!t) B2431 Military Aviation 7 September 8th 04 05:20 PM
cheap, durable, homebuilt aircrafts- myth or truth? -=:|SAJAN|:=- Home Built 27 January 8th 04 10:05 AM
The myth that won't die. Roger Long Piloting 7 December 19th 03 07:15 PM
