Matt Whiting wrote:
Ray Andraka wrote: Matt Whiting wrote: This is only true for engines that have very advanced ignition timing, which isn't true for most GA piston engines, or engines with very high compression ratios, again, not true for most GA piston engines. Keep in mind that most were designed to run on 80 octane avgas... I don't disagree with the fact that in normal conditions, and a normal engine, the power of an engine running 100LL or mogas should be virtually the same. Yes, I can't imagine many GA piston engines where this wouldn't be the case. Maybe a turbocharged engine running very hot. Matt There are plenty of high compression GA piston engines that can't use mogas because the octane requirement is too high. The majority of GA engines are lower octane (something like 78% of the engines IIRC). The majority of the hours flown in piston aircraft however is done by the 21% of aircraft that have higher octane requirements than mogas can offer, my 260 HP O-540-E4B5 included. It is a normally aspirated 6 cylinder engine, but with high enough compression that there is not sufficient detonation margin with less than 96 octane fuel. I'd like to see your source of these statistics. Matt I believe the numbers were from AOPA. I'd have to do some digging to find them now. Those are the approximate numbers they were throwing around about a year ago. |
Fuel Prices For The July Pilgrimage | RST Engineering | Piloting | 46 | June 15th 07 10:45 PM |
Fuel Prices For The July Pilgrimage | RST Engineering | Owning | 46 | June 15th 07 10:45 PM |
Fuel Prices | Ross Richardson | Owning | 60 | September 30th 05 02:06 AM |
Fuel Prices | ~R | Rotorcraft | 0 | September 10th 05 03:56 PM |
Fuel Prices | S Green | Piloting | 0 | May 9th 04 09:47 PM |
