What's the best auto gas for a/c use in California?
Old September 16th 03, 07:36 PM
Orval Fairbairn
(Corky Scott) wrote:
On Tue, 16 Sep 2003 02:14:15 GMT, Orval Fairbairn
The corrosiveness is not due to the alcohol, per se, but due to
alcohol's affinity for water that causes the corrosion. It will soak the
water right out of the air and deposit it in your tank, wher the water
will star the corrosive process.
Perhaps there's more to it Orval. When I was an auto mechanic, I
recall seeing a Chrysler come in to the shop that was running poorly.
The car was pretty new, this was probably around 1979 or '80. We
opened the hood up to look and were all horrified to see that every
single rubber hose was swelled up like it was bursting. We started
asking questions and it was finally decided that the owner had been
using gas that had a higher ratio of Ethanol to gas than it was
supposed to have.
Think about it, every single piece of rubber that the fuel touched,
from the tank to the lines in the belly, to the engine compartment and
inside the carburator, ALL had to be replaced. It took us days. The
hoses were soft and slimy.
Corky Scott
There is even more to the story. Remember when cars were suddenly
catching on fire from fuel lines leaking after MTBE was introduced?
I have a book, put out by Ethyl Corp., about 1953, and sponsored by the
AF and Navy, titled "Aviation Fuels and Their Effects on Engine
Preformance," NAVAER-06-5-501; USAF T.O. No. 06-5-4.
In it it says that you can expose fuel hoses, rubber, etc. to
hydrocarbon-based fuels and be OK, but, if you switch to naptha-based
fuels, you can run into problems. The converse is also true -- you can
run the same type materials with naptha-based fuels and be OK, but will
run into problems if you then switch to hydrocarbon-based fuels.
Apparently, the material takes a "set" with one type of fuel. The cars'
fuel lines leaked when a new formulation was introduced.
Old September 16th 03, 11:40 PM
Barnyard BOb --
On Tue, 16 Sep 2003 17:48:24 GMT, "Bruce A. Frank"
Yep, I am sure GW called up the proper agencies and said, "Now, you guys
better mandate alcohol in fuel so my good buddies at ADM can get
fat(er)." Puhleeeeese!
Yeah.
GWB USE to be an alcohol man.
Now he is an oil man....
just like his VeePee.
Barnyard BOb --
Old September 17th 03, 08:47 PM
Peter Dohm
Ron Natalie wrote:
"Treetopper" wrote in message ...
I understand no auto gas is safe for use in california (AGL) between Sept
and Feb. due to pumping it full of air or some other oxygenating process.
This tends to cause the engine to run extremely lean beyond managmento
levels in flying 2 stroke engines and some 4 stroke engines. Pistons are not
in themselves all that expensive to replace, its the repair to the landing
gear and airframe and hospital bills that kill you.
How about some facts? The oxygenates aren't "pumping things full of air."
It's a specific additive (reformuation) to the fuel. Currently threre are two
popular ones. MBTE and Ethanol. Ethanol is NOT approved for autogas
STC'd aircraft. There are problems with both corrosiveness and interaction
with rubber to solve. MBTE is fine, but it's disappearing because it's a lot
more toxic and due to he absolutely abysmal status of most underground
gas storage tanks, it's a significant pollution risk.
Goodness! This must be Alice's world "behind the looking glass." Who would
have though that crummy and unsafe old leaky tanks would give me a warm, fuzzy
feeling?
---California International Air Show Pics Posted!!!! Tyson Rininger Aerobatics 0 February 23rd 04 11:51 AM
2004 California airshow schedule taking shape! Wings Of Fury Aerobatics 0 December 31st 03 05:32 AM
Salinas California Air Show yesterday BattMeals Aerobatics 0 October 20th 03 04:58 AM
Steen Skybolt pre-purchase, northern California Barnyard BOb -- Home Built 17 August 31st 03 08:21 PM
Barnyard--- Auto engines Jerry Springer Home Built 10 August 8th 03 06:38 PM
