Replacing the stripes on a Cobra trailer
Old July 12th 07, 02:00 AM posted to rec.aviation.soaring
Andy[_1_]
Default Replacing the stripes on a Cobra trailer
On Jul 11, 11:37 am, Eric Greenwell wrote:
Ideas from people that have never done this are also welcome, as
I doubt there are many "stripe replacement" experts, and they might not be reading RAS.
Never done it but if I had to I'd try it this way. Rivet both ends of
the warm filler strip. Insert lower edge in channel. Run a tool
between the channel and the top edge of the strip while pressing the
strip inwards.
Imagine it's the inverse of installing a car windshield seal filler
strip (for those that remember before windshields were all bonded).
Andy
Old July 12th 07, 10:49 AM posted to rec.aviation.soaring
Lars Peder Hansen
In general, avoid red plastics for outdoor (uv exposed) use. Ever since
cadmium was banned as an additive in the late seventies (?), noone has found
a replacement that will make red last.
Lars Peder
Using, yes, blue on the Cobra
"Jack" wrote in message
t...
I also noted from looking at a lot of trailers that the red strips
weathered much faster than the blue so I changed mine to blue.
Red does that. Mine are 2001 vintage and there is no color left. Too
much FL sun, I suppose. I was going to paint them with something
rather than replace them. It seems cheaper, and perhaps easier.
I'm sticking with red because of the red logos on the glider.
Comments?
Jack
Old July 12th 07, 10:57 AM posted to rec.aviation.soaring
On Jul 11, 2:37 pm, Eric Greenwell wrote:
My 12 year old blue stripes turned brown several years ago, so I'm now
trying to install the new ones. It's not going well.
The factory instructions call for hot soapy water on the trailer and
stripe, then the end is pulled by one person while another feeds/pushes
it into the aluminum extrusions. This works until about 8 feet is on the
trailer, then it gets hard to go any farther. With 22 feet of trailer
left, I don't think we'll make it!
They do mention using an additional 1 or 2 people in the middle to help
push the stripe along, but we didn't have more people.
Does anyone have experience with this, and how did you get the stripe in
place? Ideas from people that have never done this are also welcome, as
be reading RAS.
* "Transponders in Sailplanes"http://tinyurl.com/y739x4
* "A Guide to Self-launching Sailplane Operation" atwww.motorglider.org
You guys have *way* too much time on your hands.
Don't you have blowholes to clean or something ?
See ya, Dave
PS: No, my glider does not have blowholes...
Old July 12th 07, 08:20 PM posted to rec.aviation.soaring
Eric Greenwell
be reading RAS.
When you have a 12 year old trailer with 120,000 miles on it, what are
you going to do? I've replaced 3 sets of tires, one set of brakes, one
tongue, both taillights (with LED units), glued and re-glued the carpet
pieces, and a new axle is on it's way. That leaves the stripes!
Maybe I should've done the stripes at Albert Lea, where I definitely had
*way* too much time on my hands.
Already did that in March (not sure which year, though).
Old July 12th 07, 09:56 PM posted to rec.aviation.soaring
be reading RAS.
Well anyway, pass my condolences to Jan...
Best Regards, Dave
PS: Great to see you at Albert Lea if only in the rain...
Old July 13th 07, 12:58 AM posted to rec.aviation.soaring
Eric Greenwell
Default Replacing the stripes on a Cobra trailer - success!
Since I had an abundance of soapy water and high temperatures (102 F), I
used that method to replace the right stripe. I did it out in the sun,
so the stripe was extra hot. The sun also made my wife extra hot, but in
a sweaty, "can't we do this any faster", kind of way.
The first 22 feet slide on before I couldn't pull it any farther. I had
to remove 8 feet of the stripe from the channel at the end I was pulling
on, then pull the rest of the stripe on. The 8 feet was then pushed on
the channel 1/4" at time with a screwdriver, so it was slow and tedious,
but at least I could do it in the garage in the shade.
Total time was about 1.5 hours.
The left stripe was installed using Pam cooking spray (basically, canola
oil in a spray can) sprayed on the stripe and the channel on the
trailer. That was lot easier - I was able to install the stripe by
myself in 30 minutes in the garage in only 90 F heat, except for the
last 5 feet. Putting the trailer in sunlight warmed the stripe up enough
to easily pull the last 5 feet into the channel.
The canola oil seemed slicker than the spray olive oil we had, but I'm
sure there is something even better than Pam. That would make it easy to
do at lower temperatures. A trailer for 15 meter gliders would be easier
than my 30 foot long trailer box (34 feet with the tongue) for an 18 M
glider.
I noticed the new vinyl stripe is almost twice as thick as the 12 year
old stripe, so someone that's replaced a stripe years ago might be
surprised by the (likely) extra effort required to replace a stripe now.
The trailer looks almost good as new now, with the new fenders (replaced
because one was destroyed by a tire tread) and stripes. Just wait until
it gets it's new axle and wheels!
* "Transponders in Sailplanes" http://tinyurl.com/y739x4
Old July 22nd 07, 04:57 AM posted to rec.aviation.soaring
Eric Greenwell
While the Pam (spray canola cooking oil) worked well, there was an
unexpected after-effect: the oil seeped out of the channel and ran down
the side of the trailer, which combined with the road dust to produce a
truly ugly sight! After a few days, when the seepage stopped, 5 minutes
with a foam brush at a car wash cleaned it all off.
Cobra Trailer [email protected] Soaring 22 December 8th 06 12:38 AM
Replacing Cobra trailer 13 inch tires with larger? Andy Blackburn Soaring 6 August 19th 04 04:15 AM
Replacing Cobra trailer wheels samcgiltner Soaring 8 August 12th 04 08:46 PM
Cobra Trailer Soaring 1 September 28th 03 02:14 PM
FS: Cobra Trailer Ed Byars Soaring 0 September 22nd 03 05:47 PM
