Why don't all fighters have low Wing Loading?
Old September 21st 03, 08:51 PM
Nele_VII
Chad Irby wrote in message ...
Hobo wrote:
Chad Irby wrote:
Aerodynamic drag.
So if the F-15 had high wing loading it would be a Mach 3 rocket?
Hard to tell. You *can* have planes with higher wing loading that have
a better turn radius (the WWII Messerschmitt 109). The aspect ratio of
the wing is very important here, too.
Yes, but I've heard that Bf-109 was "bleeding" speed in turn much faster
than, f.e, Spitfire, so the Bf pilot had to "ease" on the stick. Something
like F-104 or MiG-21 behavior (although MiG-21 is loosing speed due to
dynamic drag of the delta-wing, not wing loading).
But if you keep everything else the same, you reduce drag (by some
amount) while also increasing the turn radius (by some amount).
Bf-109 had ot from both worlds, it seems.
cirby at cfl.rr.com
Remember: Objects in rearview mirror may be hallucinations.
Slam on brakes accordingly.
Nele
NULLA ROSA SINE SPINA
Props and Wing Warping... was soaring vs. flaping Wright1902Glider Home Built 0 September 29th 03 04:40 PM
Flexible Wing Flight patrick timony Military Aviation 6 September 16th 03 04:28 PM
Can someone explain wing loading? Frederick Wilson Home Built 4 September 10th 03 03:33 AM
Wing Extensions Jay Home Built 22 July 27th 03 01:23 PM
