-----Original Message----- From: Newps ] Posted At: Saturday, August 18, 2007 8:21 PM Posted To: rec.aviation.owning Conversation: Mixture--science vs witchcraft? Subject: Mixture--science vs witchcraft? 250 HP needs about 20-22 gph for takeoff. After takeoff and throughout the climb set mixture to achieve 1250-1300 EGT, any altitude. For landing leave the mixture where it was for cruise. If you need to do a go around then make sure to advance the mixture a little as you ease the power in. The engine won't generate 250 HP at altitude will it? Isn't that a sea level rating based on the pressure of the air available at sea level? So the 20-22 gph would be for sea level wouldn't it? At FL180 the pressure is 1/2 of sea level so we can interpolate that at 9000' the pressure would be only 3/4 of sea level, then factor in the temperature for the density altitude the engine will really breathe. Doesn't this mean that the normally aspirated engine in the OPs question will produce significantly less than 250 HP? I'm not going to do the math because I'm sure to get it wrong and there are many others on here more qualified than I, so I'm only guessing that we might see 200 HP. If that's the case then instead of 20-22 gph wouldn't we be looking for around 16 gph? |
| Thread Tools | |
| Display Modes | |
| X-Prize is currently live on Discovery Science Channel | Roger Halstead | Home Built | 50 | October 10th 04 12:49 PM |
| TSA Rocket Science | Judah | Piloting | 11 | January 15th 04 12:59 AM |
| TALK OF THE NATION: SCIENCE FRIDAY | EDR | Piloting | 0 | December 11th 03 10:35 PM |
| Science, technology highlighted at hearing | Otis Willie | Military Aviation | 0 | July 23rd 03 11:30 PM |
| X-Plane in Popular Science Magazine | Danay Westerlage | Simulators | 0 | July 13th 03 08:04 PM |
