NTSB Accidents & Incidents
Old August 22nd 07, 01:36 PM posted to rec.aviation.piloting
Ron Natalie
Default NTSB Accidents & Incidents
Ron Wanttaja wrote:
A 7AC Champ doesn't have any stall warning device.
Its Type Certificate pre-dates the period when stall warning devices were
required.
Incorrect!
The phrase from CAR 3 under which it was certified is almost identical
to today's passage in Part 23:
3.120(f) A clear and distinctive stall warning shall precede the
stalling of the airplane, with the flaps and landing gear in any
position, both in straight and turning flight.
23.207(a) There must be a clear and distinctive stall warning, with the
flaps and landing gear in any normal position, in straight and turning
flight.
The only difference is 23.207 goes on to say that it can either be
accomplished via aerodynamic qualities or a by a device. A visual
indicator by itself, by the way, doesn't qualify.
Old August 22nd 07, 02:22 PM posted to rec.aviation.piloting
Larry Dighera
On Wed, 22 Aug 2007 07:36:51 -0400, Ron Natalie
wrote in :
A visual indicator by itself, by the way, doesn't qualify.
Where does it say that?
The PA28-235 is equipped with only a red panel light.
Old August 22nd 07, 02:56 PM posted to rec.aviation.piloting
Bob Moore
wrote in :
(b) The stall warning may be furnished either through the inherent
aerodynamic qualities of the airplane or by a device that will give clearly
distinguishable indications under expected conditions of flight. However, a
visual stall warning device that requires the attention of the crew within
the cockpit is not acceptable by itself.
Bob Moore
Old August 22nd 07, 04:27 PM posted to rec.aviation.piloting
Larry Dighera
On 22 Aug 2007 12:56:36 GMT, Bob Moore
wrote in 28:
wrote in :
Bob Moore
There seems to be a bit of ambiguity in that quote: "a
within the cockpit is not acceptable by itself."
The stall warning light mounted in the center of the left hand panel
in the PA28-235 doesn't require the crew's attention; it gets it. So
I guess it's approved.
Old August 22nd 07, 07:01 PM posted to rec.aviation.piloting
Peter Clark
On Wed, 22 Aug 2007 14:27:52 GMT, Larry Dighera
Probably the light in association with airframe buffet is what gets it
approved.
Old August 22nd 07, 08:10 PM posted to rec.aviation.piloting
Bob Moore
There's a good chance that in the case of the PA28-235 that the light
is not required at all due to natural stall warning and Piper just
put the light there just for good measure.
Bob Moore
Old August 22nd 07, 10:19 PM posted to rec.aviation.piloting
Larry Dighera
On 22 Aug 2007 18:10:28 GMT, Bob Moore
wrote in 28:
Bob Moore
My experience is that the PA28 doesn't provide much aerodynamic
warning of a stall. It'll just smoothly mush along for a long time
before the nose finally drops.
  #28
Old August 22nd 07, 11:33 PM posted to rec.aviation.piloting
Montblack
("Larry Dighera" wrote)
My experience is that the PA28 doesn't provide much aerodynamic warning of
a stall. It'll just smoothly mush along for a long time before the nose
finally drops.
I counted two.
Paul-Mont
  #29
Old August 23rd 07, 12:27 AM posted to rec.aviation.piloting
Larry Dighera
On Wed, 22 Aug 2007 16:33:10 -0500, "Montblack"
wrote in
finally drops.
I counted two.
Two what?
  #30
Old August 23rd 07, 02:11 AM posted to rec.aviation.piloting
Montblack
of a stall. It'll just smoothly mush along for a long time before the
nose finally drops.
I counted two.
Two what?
Two aerodynamic warnings of a stall, in your post.
Paul-Mont
Physiology and accidents Bill Daniels Soaring 7 May 30th 07 03:14 PM
Aviation incidents [email protected] Piloting 2 June 22nd 06 07:45 AM
Accidents Big John Piloting 3 December 14th 05 02:19 PM
Accidents happen... Manuel Piloting 26 November 28th 04 12:32 PM
U.S. won't have to reveal other friendly fire events: Schmidt's lawyers hoped to use other incidents to help their case Otis Willie Military Aviation 0 December 18th 03 09:44 PM
