Questions for Jim Weir
Old September 6th 07, 10:18 AM posted to rec.aviation.homebuilt
George McLeod
Default Questions for Jim Weir
Hello Jim,
Would appreciate your comments, if any, on the following but only if it it
will only take about a minute of your time.
Re Collions 476X-3 Transponder Test Set
What is difference between the -1 and the -3 units?
Is the interrogation process initiated by an internal timer in the test set
as there appears to be not any "press to test"?
AND if RST is involved with magnetoes, what equipment do you use to comply
with the 50 Gohm capacitor leakage test required by Slick?
With thanks
Old September 6th 07, 04:06 PM posted to rec.aviation.homebuilt
RST Engineering
Sorry, I have absolutely no answers to either of these two questions...would
if I could.
"If you think you can, or think you can't, you're right."
--Henry Ford
"George McLeod" wrote in message
u...
Hello Jim,
set
With thanks
Get Rid of Jim Weir at Oshkosh Bret Ludwig Home Built 26 August 28th 06 03:00 PM
Damn the Jim Weir! Ken Finney Home Built 4 July 5th 06 09:33 PM
To Jim Weir/Others James Lloyd Home Built 5 February 25th 04 05:49 AM
Jim Weir for Governor or RAP R. Hubbell Piloting 0 November 25th 03 04:34 AM
Mig-29 questions & general aviation questions 2003 Steven Military Aviation 1 October 20th 03 06:06 AM
