Steve Fossett missing?
Old September 7th 07, 01:58 AM posted to rec.aviation.homebuilt
Ken Finney
Default Steve Fossett missing?
"J. Severyn" wrote in message
Thanks!!!! This APRS system is outta-sight. As a retired EE, I've toyed
with getting a ham ticket since I was a kid...and this might just do it.
This has wide coverage....and does not depend on a G-switch like an
ELT.....even the new 406MHz units depend on a G-switch to trip if the
victim cannot trigger the unit manually.
I like the continual tracking feature.....just look where the signal
stopped.
I've spent some time in the past half-hour and understand the electronics.
But has someone put together a small transmitter with an embedded GPS, to
make the whole unit a "one box" solution? I have no problem building a
APRS transmitter myself, but it seems a single small package has a better
chance of always being in the plane, say mounted on a door post or under a
glass turtledeck. Maybe with a rechargable battery, external power plug
(to keep it charged from the ship's power).
OK..... tell me more. What class ham license do I need?
John Severyn
KLVK Livermore, Ca.
Fairly simple. The (2m) tracking unit has a small gps that feeds
digital signals to the attached transmitter. The signals include
latitude, longitude, speed, altitude, direction and are picked up by a
host of volunteer ham towers - digital repeaters and/or iGates. That
info is transferred to internet servers and you can easily see the
results on a Google (or other type) map on places like www.findu.com -
simplicity itself for users. I suggest that you pay another $15/yr for
a private website YourPlaneName.com where your relatives or FAA can go
to find the latest tracking.
A lot of automobile users use the system so their wives can tell where
they are (hmm?) . But their signals are often blocked by terrain. The
best performance is from aircraft - any ham digi or igate tower within
couple of hundred miles can see the signal. I have flown cross country
- remote areas - and there is rarely a break in 1 or 2 minute
reporting intervals.
Are you still gawking around. Memorize answers to some 100 ham
questions, pay the $20? fee and get a APRS tracker. It may save your
life.
Check out these folks:
http://www.byonics.com/
In particular:
http://www.byonics.com/microtrak/mt8000.php
You only need the Technician license. Details at www.arrl.org
Lots of study guides are available on-line.
Old September 7th 07, 03:22 AM posted to rec.aviation.homebuilt
ULWA
Maybe.. maybe not...
Lets see, been 4 days, No plane radio, no ELT, no Cell phone, no Personal
tracker.
The chances of having so many com avenues fail without injury sure worry's
one.
I personally think of 2 guestamated probabilities.
Either he chose to disappear or he went into the water.
Seen as I'm sure he had lots of adrenaline yet to be tapped for future
records.
Hmmm,
I sure wish him well and a speedy recovery with condolences to his family.
Fossett had a typical ELT that apparently did not turn on or was out
of range.
I have a APRS tracker that continuously sends position/velocity info
on the ham frequency. Worked very well so far and gives peace of mind
to relatives - and useful to FAA on a flight plan. If Fosset had a
continuous tracker, the job of finding him might have been a lot
easier.
You can build an APRS tracker for about $250. A basic ham license is
easy to get.
For more info http://www.abri.com/sq2000/GPStrack.html
SQ2000 canard, http://www.abri.com/sq2000/
On Sep 4, 2:13 pm, "Rob Turk" wrote:
CNN reports Steve Fossett is missing.
Fossett took off from a private air strip known as Flying M Ranch, near
Smith Valley, 30 miles south of Yerington, Nevada, on Monday, with enough
fuel for four to five hours of flight, according to the Civil Air Patrol.
Yerington is south of Carson City, near the California border."
Let's hope for the best
Old September 7th 07, 05:33 AM posted to rec.aviation.homebuilt
Dave S
John Severyn
KLVK Livermore, Ca.
Just a technician license, which is entry level. (novice no longer
exists for new licenses). If you are knowledgeable about radio
communications you could even possibly pass the test cold turkey. But
there are enough specific knowledge items there that most of the time
you will need to study a bit to pass.
Morse Code is no longer required to obtain a Tech license
Lets not kid ourselves here. What we are essentially doing is using APRS
as an equivalent to "flight following" in the commercial (as opposed to
ATC sense). Another party is able to track your progress and if you are
overdue, able to use your last known position as the starting point to
initiate a search or report you missing.
APRS (automated packet/position reporting system) is nice for this
purpose, and when the digipeaters are networked onto the net, the data
is accessible to all. for free.
Its not perfect. There IS a limit to the amount of traffic it can carry,
and these limits are reached quite often because of the way individuals
configure their own APRS beacons. This results in lost data and less
than continuous tracking. Its not perfect. As few as 100 users in a
region can saturate the system. The issue is a result of indiscriminate
"repeating" of messages 2 or 3 or more times when one will suffice.
There is no regulatory guidance on this issue, so you are at the mercy
of your peers. BUT.. even if only one out of every 3-4 burst goes
through, thats better than nothing, with regards to a starting point.
If you are flying in a straight line, its pretty easy to look at the
track and know where to look for someone.
One limiting factor is that there is usually but ONE frequency available
for APRS use, and if I am not mistaken this is not necessarily uniform
across the country. So you have to know, and keep up with any frequency
changes in order to enable this flight following.
I'm new to HAM radio.. got my ticket this spring, and obtained it for
one purpose - to be in communication as a motorcycle marshal escort for
charity bike rides. Our rides go into the country, cell phones are
spotty, but Amatuer bands enable communications continuity, and dont
need to rent public safety/business band radios. APRS allows us to track
key vehicles and marshals. I dont rag chew. I dont do any of the field
days. Dont belong to the ham club. I do HAM on the motorcycle during
rides only.
If your radio is not APRS-ready out of the box (look for the term TNC as
part of installed equipment), you will need an external TNC (terminal
node controller). Tiny Trak is about the size of a pager, and hugely
capable. Kingwood has 2 packet-ready (tnc installed radios), the TM-D700
which is a dash mount and there is a handheld that I believe is a TH-D7
or something like that. Give it an NMEA gps data stream and you are in
business.
Dave
Old September 7th 07, 09:37 AM posted to rec.aviation.homebuilt
J. Severyn
"Dave S" wrote in message
John Severyn
KLVK Livermore, Ca.
Just a technician license, which is entry level. (novice no longer exists
snip
Dave
Thanks Dave. Great post! I understand completely. Now I have a very good
reason to get a ham ticket. A close friend has been bugging me for many
years to do just that. Of course he has been a ham for about 50 years (no
lie). The APRS system is very well thought out....and I realize that each
packet is not 100% reliable......but that is so much better than just an ELT
running off a G-switch. You guys are really doing a service by educating
us......and hopefully saving lives in the future.
Many Thanks!!
John Severyn
Old September 7th 07, 12:47 PM posted to rec.aviation.homebuilt
Scott[_1_]
One possible problem might be when flying in places like dry lake beds.
If you're flying at say 500 feet will there always be a ham within
range to get the aprs report? At 100 MPH you might cover a lot of
potential ground without an aprs report getting received by someone.
The satellite unit can see the vast majority of Earth's surface from
space. But, I agree, the satellite method relies on that little
G-Switch to indicate trouble...
Scott
N0EDV
Basically the APRS tracker is a small gps receiver / 2M ham
transmitter which sends digital position signals to nearby digital ham
station, which in turn send the info to internet servers and you can
see your last reported position on google (or other) maps on sites
like
www.findu.com. It is simplicity itself for end user.
I also suggest you invest $15/yr in a MyPlanexxx.com website where
your relatives (and FAA) could easily click to link to findu.com with
google map to see your location.
If some of you want the finished product I am willing to put it
together for you - you pay for expenses and labor - see
But you still need a ham license, which is easy to get.
APRS is superior to 406 unit since it is real time and does not depend
on "going off" in a crash.
On Sep 5, 11:32 pm, "Montblack" Y4_NOT!...
wrote)
You can build an APRS tracker for about $250. A basic ham license is easy
to get.
For more infohttp://www.abri.com/sq2000/GPStrack.html
http://www.abri.com/sq2000/APRSBasics.txt
Interesting...
Bring a Pilot to School Day:
Can you explain how this works, like we're a class of 8th graders? We'll,
7th graders, really. See, 8th grade just started, but we're still reviewing
from last year...
Paul-Mont
Scott
http://corbenflyer.tripod.com/
Gotta Fly or Gonna Die
Building RV-4 (Super Slow Build Version)
Old September 7th 07, 12:55 PM posted to rec.aviation.homebuilt
Scott[_1_]
Technician Class. Morse code tests are NOT required by any class any
more, so being you are an EE, I would try for the Extra Class so you
would have all available privileges. You may want to ultimately do more
than just aprs!
Scott
N0EDV
ELT.....even the new 406MHz units depend on a G-switch to trip if the victim
stopped.
make the whole unit a "one box" solution? I have no problem building a APRS
transmitter myself, but it seems a single small package has a better chance
of always being in the plane, say mounted on a door post or under a glass
turtledeck. Maybe with a rechargable battery, external power plug (to keep
John Severyn
KLVK Livermore, Ca.
life.
Scott
Old September 7th 07, 06:23 PM posted to rec.aviation.homebuilt
Al G[_1_]
"Steve S." wrote in message
This happens to be a topic near and dear to my uber-geeky heart. On
the one hand we have ELTs, which *hopefully* kick off when a plane
crashes. If it isn't damaged in the crash . . . if the batteries are
still good . . . if the antenna leads stay attached . . . etc. On
the other hand we have a system that is designed to tell you where the
plane is at all times, and hey, if the guy doesn't come home--play
back the recorded position data and go look in the area where the
signal stopped.
--Air-side cost . . . compared to an ELT, the things are quite
reasonable. Compared to a 406 ELT, they're peanuts.
--Ground-side cost . . . the ground side would need to get built--I
would speculate that a receiver/recorder per ATC sector would do
nicely. You could build the ground side for the entire nation for
next to nothing (when measured by gov't standards). There are guys on
this group, right now, that could design and deploy the whole ground
side without even thinking hard.
--Position data recording . . . compared to what a TIVO packs away,
setting up a system to record, say, the last 72 hours worth of
reported positions for airplanes in a given region is pretty darn
approachable. Lat/Lon, speed & altitude. That is not a lot a data.
Don't even record all of it, just record 5 minute intervals or
similar. Get fancy and make the intervals speed-sensitive. It's just
software on a PC, darn it. The amount of data is so small you could
do this on the computer the average junior high kid threw away last
week.
--Traffic avoidance . . . not only could your little ground recorder
get the signal, by golly other planes could too. Be a nice cheap way
to have live traffic in the cockpit without the ADS-B expense,
complexity and hassle.
--No electrical system? Guys at my airport without starters and
alternators are still using a little 12v batt for a radio.
--This system is a bit similar to something commercial shipping has
started doing. It's a transponder system for shipping, but instead of
being assigned a different squawk every time they go out, the have a
permanently assigned squawk. N-number anyone?
--Change the freq so you don't need the Ham ticket.
This stuff breaks my heart. It would be so simple, so cheap, so
effective, it might actually save a life (over and above the poor
track record ELT's have) and it ain't never going to happen. No one
will make money off it so no one will advocate it. I have to go for a
walk to calm down.
Stay safe, folks.
Steve.
And, it is a built in "Anti-theft" tracker. If your airplane gets
stolen, and the thief doesn't turn it off, you can probably find the
aircraft and thief.
Our flight school should have one to track students on x-c. I once had a
student who almost tried to cross the Big Lake in a 150, we never would've
found him.
Al G
  #28
Old September 7th 07, 07:41 PM posted to rec.aviation.homebuilt
Dave S
aircraft and thief.
found him.
Al G
Here's the catch. If the transmitter is operating, there needs to be a
licensed amatuer radio operator with direct control of it. By the rules,
cant just leave it transmitting blind unattended or attended by an
unlicensed operator.
Now.. there is NO reason something similar cant be devised on a business
or aviation frequency for a given local operator. You put a reciever on
top of a 1000 ft tall antenna somewhere and you will pick up airborne
traffic for hundreds of miles. Do the same in a few key cities and you
can blanket an entire area.
Dave
  #29
Old September 7th 07, 09:25 PM posted to rec.aviation.homebuilt
Al G[_1_]
aircraft and thief.
had a student who almost tried to cross the Big Lake in a 150, we never
would've found him.
Al G
Dave
Oops, you're right. The neat deal here is that all of the antennas
already exist, in the Ham network. They are the ones providing a real
service.
Al G
  #30
Old September 7th 07, 10:11 PM posted to rec.aviation.homebuilt
Bill Daniels
"Al G" wrote in message
Since the main benefit of APRS is to the pilot, it seems logical that the
small effort required to obtain the Technician's License is in order. I
just downloaded the exam study guide. Getting 26 out of 35 questions right
doesn't seem that hard.
I do have a question. In the APRS map displays I have looked at, the
symbols all contained the Ham license call sign. That's a little cryptic
for non-hams. Is there a way to display an "N" number or other identifier
instead?
Bill Daniels
Steve Fossett - Missing [email protected] Soaring 18 September 6th 07 09:16 PM
new world-record for Steve Fossett (USA) and Terry Delore [email protected] Soaring 19 July 24th 07 04:39 AM
New Steve Fossett Book - and other new stuff Paul Remde Soaring 3 November 17th 06 05:50 PM
Steve Fossett-Fuel? SA General Aviation 1 March 8th 05 09:39 PM
