Slow Flight
Old September 9th 07, 11:49 PM posted to rec.aviation.piloting
B A R R Y
Default Slow Flight
On Sun, 09 Sep 2007 11:24:20 -0700, wrote:
Did you pull the nose up a little more to get the stall in that
situation? That's where it can get interesting. Departure stall. A 150
does it real well. Better be prepared for spin recovery.
Seen a Private Pilot PTS lately? As interesting as it is, shouldn't
a pilot be able to fly to at least PTS (the minimum) standards?
"C. TASK: POWER-ON STALLS (ASEL and ASES)
NOTE: In some high performance airplanes, the power setting may have
to
be reduced below the practical test standards guideline power setting
to
prevent excessively high pitch attitudes (greater than 30° nose up).
REFERENCES: FAA-H-8083-3, AC 61-67; POH/AFM.
Objective. To determine that the applicant:
1. Exhibits knowledge of the elements related to power-on stalls.
2. Selects an entry altitude that allows the task to be completed no
lower than 1,500 feet (460 meters) AGL.
3. Establishes the takeoff or departure configuration. Sets power to
no
less than 65 percent available power.
4. Transitions smoothly from the takeoff or departure attitude to the
pitch attitude that will induce a stall.
5. Maintains a specified heading, ±10°, in straight flight; maintains
a
specified angle of bank not to exceed 20°, ±10°, in turning flight,
while inducing the stall.
6. Recognizes and recovers promptly after the stall occurs by
simultaneously reducing the angle of attack, increasing power as
appropriate, and leveling the wings to return to a straight-and-level
flight attitude with a minimum loss of altitude appropriate for the
airplane.
7. Retracts the flaps to the recommended setting; retracts the landing
gear if retractable, after a positive rate of climb is established.
8. Accelerates to VX or VY speed before the final flap retraction;
returns
to the altitude, heading, and airspeed specified by the examiner."
The whole shebag is he
http://www.faa.gov/education_research/testing/airmen/test_standards/pilot/media/FAA-S-8081-14A.pdf
Overweight? Out of CG? Stalled? Too slow? Flyingmonk Piloting 41 June 25th 06 08:08 PM
Running slow Jamie Nicholl Simulators 2 February 16th 06 10:57 PM
why so slow??!! Heino & Deanne Weisberg Home Built 6 November 6th 05 07:22 PM
Flightgear really this slow on XP? [email protected] Simulators 6 May 9th 05 03:55 PM
Flying Slow [email protected] Piloting 61 January 17th 05 06:23 PM
