Traditionally, in GA aircraft, is the COM
mounted above or below the transponder. |
Jim Stewart wrote: Traditionally, in GA aircraft, is the COM mounted above or below the transponder. Usually above, because it is set more and should be more in the pilot's line of sight. |
Orval Fairbairn wrote:
In article , Jim Stewart wrote: Traditionally, in GA aircraft, is the COM mounted above or below the transponder. Usually above, because it is set more and should be more in the pilot's line of sight. Makes sense. Thanks. |
| Thread Tools | |
| Display Modes | |
| audio panel/impedance mismatch question | Peter R. | Owning | 9 | June 24th 06 11:53 PM |
| Audio panel observation/question | Mike Noel | Owning | 0 | January 12th 06 04:35 AM |
| Expertise Needed: TU-154 Panel Question | GlaringTruth | Simulators | 1 | October 5th 03 06:54 AM |
| Panel on C-130 vertical stab question | B2431 | Military Aviation | 22 | September 27th 03 08:47 PM |
| Garmin audio panel question | Brinks | Owning | 1 | September 10th 03 09:41 PM |
