"Richard Riley" wrote in message ... On Tue, 2 Oct 2007 21:27:02 -0600, "Bill Daniels" bildan@comcast-dot-net wrote: I just read an article that said these things are going to be consumerized soon. Essentially, they take a PC CAD drawing and, using plastic resin, make a 3Dpart. I'm not sure what kind of resin but there are engineering expoxies that can be hardened with a UV LED or laser. My question is will they be useful for homebuilders. I can see making plastic sand cast cores and maybe custom knobs but could they make structural items? Bildan This isn't going to help much, but "it depends." The FDM (Fused Deposition Modeling) machine I use at work is usually set up to work with ABS plastic. The parts are pretty fragile, I wouldn't even want to use them for knobs. But it can also work with polycarbonate - lexan - and that's useful. You're not going to make gear legs out of it, but ducts and lids would be fine. OTOH, the same basic concept is used to scinter powdered steel with lasers, or powdered titanium with electron beams. So it's probably just a matter of time. Actually, after I started the thread I realized that I was thinking of wax casting cores. If the 3D printer could make 3D parts out of wax that could be used in 'lost wax' aluminum casting that might indeed be useful. |
| Thread Tools | |
| Display Modes | |
| Machine shop information needed. | Dave[_16_] | Owning | 8 | October 14th 07 05:16 AM |
| deHavilland Devon VP 979 Information needed | [email protected] | General Aviation | 0 | July 8th 06 02:29 PM |
| Pirep needed for Gulf Shores (JKA) Paint Shop | David | Owning | 0 | July 1st 04 03:12 PM |
| CH/MH-53E information needed - Maintainers? | Sherman C | Rotorcraft | 0 | June 27th 04 03:17 AM |
| NEEDED: Aircraft Ground Handling Information | Jarry Clausing | Products | 0 | August 9th 03 04:24 PM |
