"John Freck" wrote in message om... "Keith Willshaw" wrote in message ... Why ? Why what to which line I wrote? The one which read The RAF had bomber production going during the BoB. Yes, the RAF did think fighters were more important than bombers. I would for the sake of the game eliminate new bomber construction, or only go with the hottest 2-engined bombers that are in fact or could nearly be top fighter-bombers if configured that way. You cant rapidly switch factories building Whitleys or Wellingtons to building Spitfires and Hurricanes and new shadow factories for those aircraft were already entering production, the RAF had no shortage of airframes in any event. You can to rapidly decrease production of one plane type and increase production of another. No sir you cant, retooling a factory and re-training its workforce takes considerable time during which you produce nothing at all. You may be thinking of a short time frame for the BoB which is just 3 months. Given that this is the subject of the discussion thats not a reasonable assumption During W.W.II USA production jumped hugely in time measured in months. Some planes were discontinued and others started up with pretty high numbers off the bat. When a plane was discontinued the numbers produced dropped to zero in a day, and the factory would be open the next day getting started making whatever was next, and the numbers of the new plane jumped up pretty quickly as I recall. This is simply wrong. Consider as an example the TBM Avenger The first prototype flew in 1940, the first production models entered service in 1942 but it took the best part of a year for GM to produce the first Avenger . They were given a contract to build 1200 at their Eastern Aircraft plant in Trenton, New Jersey in March 1942. The first aircraft rolled off the production lines in March 1943. Even that was a tremendous achievement and required Grumman to deliver TBF's assembled with sheet metal screws rather than rivets so they could be repeatedly assembled and dismantled by the workers in training Consider further the second Spitfire production plant at Castle Bromwich in the West Midlands. On April 12,1938 a contract was placed for 1,000 Spitfires to be built at this new factory, aircraft first came off the production line in September 1940 Yes, the 3 month time frame of the BoB is very tight, and this is why I say my commentary in response to Herbert Pocket's is really more for down stream. But, without hesitation fighter command can take fuel from bomber command, spare engines, sheet metal, knobs, and such, and raw materials. No they cant, there was no shortage of fuel, the bombers mostly used different engines and the rest of the stuff is just silly. Once more there was no shortage of aircraft, the RAF had seveal hundred complete spares in stock and production was running at 300 a month by September. Building a whole new factory to make fighters can be done in weeks, transferring workers can be done in weeks, diverting raw materials can be done in 1 day, and the machines used to make fighters and bombers and all the same, just different patterns of the same thing. It is really no different that having more shirts and less pants. You must admit that operationally fighters and bombers consume pretty much the same stuff in terms of material, skilled workers, and management. Yes? You really are totally clueless about production engineering. An aircraft is an incredibly complex product, even in WW2 it took around 2 years to go from prototype to production. I could go down to the library get direct quotes from the 1947 USA Almanac. The assessment in 1947 lead to the USAAF, USN, USMC, and USA Army spending very heavily in other directions than strategic bombers, not that the strategic bomber is absent even today. The USAAF ceased to exist in 1947 and from that date on the US Army has not operated significant numbers of fixed wing aircraft The United States Army Air Force = The United States Air Force = The United States of America Air Force The USAAF merely changed its name to USAF and became a full independent branch of the US military establishment. Thats hardly a merely. The USAF and Strategic Air Command on the other hand ordered and operated large numbers of strategic bombers including the B-29, B-50, B-36, B-47, B-52, B-1 and B-2 The B-29 pre-dates 1947. The total number of bombers produced of B-50, B-36, B-47, B-52, B-1, and B-2 don't add up to 1,000, I don't believe. The number of fighter bombers built since 1947 is over 10,000 as I recall. The ratio is about the same as I recommend for SimWWII. I cut back and not out. Again your lack of a clue is showing The USA produced 370 B-50's, 380 B-36's, 1300 B-47's and 740 B-52's Perhaps the 4-engined bombers were most effective when deployed at low altitude. What sort of altitude were the attacks on Germany's oil production carried out at? Of course, 4-engined bomber can run low. It is just that it is better to use 1 and 2-engined planes. There are awesome things the Allied could have done if 4-engined bombers are cut back around 75% or more. And awesome things they couldnt have done, fact is a single heavy bomber can carry more bombs than 6 fighter bombers of WW2 and do so over a longer distance While a B-29 can deliver 20,000lbs of bombs and a Coursair only 1 2,000lbs bomb, and yes, the B-29 can fly 3,000+ miles and the F-4 only 1,000+ miles, the F4 can deliver the bomb more accurately. Which is bloody useless if the target is over a 1000 miles away and even if its in range you need 10 times the number of aircraft and 5 times the number of pilots. Add in the ground staff and the logistics are impossible. The F4 can also strafe enemy trucks, bomb enemy ships, and rocket or bomb tanks. Heavy fighter cover can mean the enemy has viturally 100% of trucks operating during daylight or any ground vehicle opeating during the day in a battle destoyed. Fighter bombers are simply the best. Figther bomb cant deliver supply to ground units which is wht a transport can do and some bombers too. Fighter bombers are an absolute requirement for ground support but they wont demolish the oil plants which proved to be a decisive move in WW2. Nor will they destroy the enemys transport infrastructure For example, what-if the the Allies funded, resourced, the dreams of the airborne generals. In some alternative history story or war-game we can explore 100,000 strong airborne armies backed by thousands of transport planes. Imagine D-day with a lot more and better supported airborne troops! Airborne troops dont do well against armoured formations, see Arnhem for an example. The USAAF stated that 95% of strategic bombing missions were useless, and that only 5% of the runs made a difference, and that those sorts of runs can be better done by fighter bombers. Cite please, I have read the strategic bombingg survey and I dont recall that as being its conclusions They then followed up and built fighter bombers in greatest numbers: I think the USA military has more transports than bombers, I just think that to be the case. US Army tank units didn't do that well against German armor either. Irrelevant. address the issue please , how do you propose to destroy the German oil industry with fighter bombers Ordinary light infantry did get better and better against armor, as I'm sure you know. I know the precise opposite. Unsupported infantry gets chopped up without anti-tank guns and air cover. Ask the paras who got caught at Arnhem. For highly motivated infantry dealing with tanks that have had protecting infantry killed there are many methods where-by ordinary infantry can disable an enemy tank. And how do you propose to kill the enemy infantry ? Wave a magic wand ? In this war-game the airborne have not only more men, but more money and resources per man. The airborne will have more supply and heavier supply. What were those best Allied anti-tank guns called? The 7 pounders, or was it 75 pounders? They were 75 mm, I think. Geez you really know nothing do you. The best British gun was the 17 pounder and the Americans used their own 3" gun I bet one of those could be air delivered by glider, or parachute, or airplane. You'd lose, the 17 pounder weighed 2100 kg, was 4.2 m long needed a truck to tow it and each round including packing weighed around 50 pounds. The largest air portable AT gun was the 6 pounder but damm few of them got into action. This idea would be an interesting thread by itself; a really, really robust and huge airborne Allied army with huge air support for close fire support and logistical support. You have to dream a little for an interesting war-game variation. That would be 100,000 troops with 2x the real world's funding, and heavy support from the Air Force too. In addition, Allied fighter bombers were a major anti-tank weapon. Trouble is you are using them strategically and havent a hope of training enough pilots to fly em all. Snip But 500 fighter bomber sorties will deliver only 10% of the bomb load of a 1000 bomber Lancaster raid and in any event neither the USSAF nor the RAF had 500 P-51's in 1943. My little book of W.W.II Aircraft indicates that the P-51 was in Europe from 1942. In small numbers as the Mustang I with an Allison engine in RAF service, I suggest you rely on something a little less lightweight than the 'little book of WW2 aircraft' My specifics are less important than the overview point, which is that fighter bombers can bomb very effectively. I could have used just 'Allied fighters' and not 'Mustang' or 'Hurricane' or 'Hurricane Super Marine fighter'. The generalize point is the subject. My book states that the Mustang was in service in 1942, and my book states that the Mustang was great on ground attack, and it could carry a 2,000lbs bomb. The devil is in the details, the Mustang was NOT great in ground attack, it was intensely vulnerable to ground fire and was not used in that role in WW2. Any way, the 500 fighters cost something like 1/8 the cost of the 1,000 bombers, and the real bomb load of a Mustang (Ok, my stats are for a D) is 2,000lbs. So you spend more money per ton of bombs dropped and risk 5 times as many pilots. RAF losses per ton of bombs dropped were lowest for the Lancaster bomber and highest for the light bombers. The USAAF in 1947 states in an after action review of Allied bombing of German that fighter bombers worked best. Cite please, page number and chapter heading Losses on the famous precision raids such as those by Mosquito's on the prison at Amiens and the Shell centre in Copenhagen varied between 20 and 40 percent. German flak was too good to routinely operate large numbers of bombers at low level attacking defended targets Evaluation of the attrition factors indicates that fighter bombing was the most effective bombing method in W.W.II. It says no such thing, take a look at its conclusions Quote CONCLUSION The foregoing pages tell of the results achieved by Allied air power, in each of its several roles in the war in Europe. It remains to look at the results as a whole and to seek such signposts as may be of guidance to the future. Allied air power was decisive in the war in Western Europe. Hindsight inevitably suggests that it might have been employed differently or better in some respects. Nevertheless, it was decisive. In the air, its victory was complete. At sea, its contribution, combined with naval power, brought an end to the enemy's greatest naval threat -- the U-boat; on land, it helped turn the tide overwhelmingly in favor of Allied ground forces. Its power and superiority made possible the success of the invasion. It brought the economy which sustained the enemy's armed forces to virtual collapse, although the full effects of this collapse had not reached the enemy's front lines when they were overrun by Allied forces. It brought home to the German people the full impact of modern war with all its horror and suffering. Its imprint on the German nation will be lasting. /Quote The Mustang also has 6 50cals for ground attack, say for peppering a locomotive. 500*2000=1,000,000 and 1,000*4,000=4,000,000. Plus the fighters will be much much harder to shoot down, and their bombing will be more accurate as extremely low altitude bombing is possible which is very accurate. You are in error once more, review the data for aircraft losses in the ground attack role and you'll find Mustangs suffered heavily due to their liquid cooling system. I read it from a book. Dont tell me , the boys book of wonder weapons right ? The Mustang is considered a potent ground attack weapon: it was not a failure as a weapon as you state by my book. Please provide evidence that the Mustang was a failed ground attack weapon in W.W.II. It wasnt used as a ground attack weapon in WW2, it was in Korea and took horrible casualties from a much less effective defense than the German had. In November 1950 the USAF 95 of the 131 F-51's in combat almost all to ground fire when strafing. The comparative figures for the F-80 jets were 44 out of 169 These details are irrelevant, perhaps, to a war-game that might only have 'fighters'. I would imagine that a future SimWWII would allow for details such as you mention to be relevant. A Mustang also escorted bombers, but not on all days, and the Mustang has very good range. And vulnerable cooling system The P-47 was far better suited to the ground attack role but NEITHER was well suited to strategic roles such as the oil campaign.. ... Fighter bombers devastated fuel farms in W.W.II... Fuel farms give in to the bombs of bombers and well to the bombs of fighter bombers. John Freck Utter nonsense, the US Strategic Bombing Survey says the precise opposite stating that large bombs (2000-4000 lb) were many times more effective than small bombs and that visual aiming was all but impossible due to the heavy flak and smoke screens. Read it for yourself at http://members.tripod.com/~Sturmvogel/ussbsgensum.html Keith |
| Thread Tools | |
| Display Modes | |
| #1 Piston Fighter was British | Kevin Brooks | Military Aviation | 170 | August 26th 03 07:34 PM |
